8.2
cs_restart_map.c File Reference
#include <mpi.h>
#include "ple_locator.h"
#include "cs_array.h"
#include "cs_assert.h"
#include "cs_coupling.h"
#include "cs_io.h"
#include "cs_mesh_connect.h"
#include "cs_mesh_location.h"
#include "cs_preprocessor_data.h"
#include "cs_timer.h"
#include "cs_timer_stats.h"
#include "fvm_nodal.h"
#include "fvm_interpolate.h"
#include "cs_restart.h"
#include "cs_restart_map.h"
+ Include dependency graph for cs_restart_map.c:
void cs_restart_map_set_mesh_input (const char *mesh_path)
 Indicate restart files should be mapped to a given mesh input. More...
void cs_restart_map_set_options (bool apply_mesh_deformation, float tolerance_base, float tolerance_fraction)
 Set options relative to restart file mapping to a given mesh input. More...
void cs_restart_map_set_locations (bool map_cell_centers, bool map_vertices)
 Indicate whether location for restart file mapping is needed at cells or vertices. More...
void cs_restart_map_build (void)
 Build mapping of restart files to different mesh if defined. More...
void cs_restart_map_free (void)
 Free restart file mapping to different mesh. More...
◆ cs_restart_map_build()
void cs_restart_map_build ( void  )
[in]need_verticesindicate if location at vertices is needed
◆ cs_restart_map_free()
void cs_restart_map_free ( void  )
Revert restart reading to default behavior.
◆ cs_restart_map_set_locations()
void cs_restart_map_set_locations ( bool  map_cell_centers,
bool  map_vertices
By default, mapping is done for cell-based quantities, but not for vertex-based quantities.
Mapping of quantities at faces or particles is not handled yet, but will use the cell-center or vertex based mappings in the future in all cases:
  • interior faces may not be aligned with previous faces, so some sort of cell-based interpolation will be required
  • boundary faces can use the boundary face / cell adjacency to avoid an additional mapping
  • for particles, as the previous location is stored based on cell ids, updating particle locations will require locating them in the matching cell and completing a trajectory adjustment (direct location should be avoided in case of concave boundaries).
[in]map_cell_centerslocate cell centers in the previous mesh.
[in]map_verticeslocate vertices in the previous mesh.
◆ cs_restart_map_set_mesh_input()
void cs_restart_map_set_mesh_input ( const char *  mesh_path)
[in]mesh_pathpath to mesh input
◆ cs_restart_map_set_options()
void cs_restart_map_set_options ( bool  apply_mesh_deformation,
[in]apply_mesh_deformationapply mesh deformation from upstream computation (if present) so as to map to final, and not initial mesh shape.
[in]tolerance_baseassociated base tolerance (used for bounding box check only, not for location test)
[in]tolerance_fractionassociated fraction of element bounding boxes added to tolerance
