47 #define CS_IO_NAME_LEN 32
49 #define CS_IO_ECHO_NONE -2
50 #define CS_IO_ECHO_OPEN_CLOSE -1
51 #define CS_IO_ECHO_HEADERS 0
68 typedef struct _cs_io_t
cs_io_t;
125 #if defined(HAVE_MPI)
129 const char *magic_string,
141 const char *magic_string,
169 #if defined(HAVE_MPI)
173 const char *magic_string,
183 const char *magic_string,
469 size_t n_location_vals,
514 size_t n_location_vals,
561 size_t n_location_vals,
cs_datatype_t
Definition: cs_defs.h:284
Definition: cs_defs.h:528
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:310
#define MPI_Info
Definition: cs_defs.h:90
Definition: cs_defs.h:529
long long cs_file_off_t
Definition: cs_file.h:107
cs_file_access_t
Definition: cs_file.h:84
cs_io_t * cs_io_initialize(const char *file_name, const char *magic_string, cs_io_mode_t mode, cs_file_access_t method, long echo, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm)
Definition: cs_io.c:1819
void cs_io_log_finalize(void)
Definition: cs_io.c:3154
cs_io_mode_t
Definition: cs_io.h:59
@ CS_IO_MODE_READ
Definition: cs_io.h:61
@ CS_IO_MODE_WRITE
Definition: cs_io.h:62
size_t cs_io_get_echo(const cs_io_t *pp_io)
Definition: cs_io.c:2101
void cs_io_set_int(cs_io_sec_header_t *header, const cs_io_t *cs_io)
Definition: cs_io.c:2398
const char * cs_io_get_indexed_sec_name(const cs_io_t *inp, size_t id)
Definition: cs_io.c:2031
void * cs_io_read_index_block(cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, cs_gnum_t *elts, cs_io_t *pp_io)
Definition: cs_io.c:2624
size_t cs_io_get_index_size(const cs_io_t *inp)
Definition: cs_io.c:2009
void cs_io_write_global(const char *sec_name, cs_gnum_t n_vals, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp)
Definition: cs_io.c:2784
void cs_io_log_initialize(void)
Definition: cs_io.c:3137
void cs_io_finalize(cs_io_t **pp_io)
Definition: cs_io.c:1953
void * cs_io_read_block(const cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, void *elts, cs_io_t *pp_io)
Definition: cs_io.c:2575
int cs_io_read_header(cs_io_t *inp, cs_io_sec_header_t *header)
Definition: cs_io.c:2123
void cs_io_write_block(const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp)
Definition: cs_io.c:2875
void cs_io_assert_cs_real(const cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.c:2506
void cs_io_set_cs_lnum(cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.c:2435
cs_io_sec_header_t cs_io_get_indexed_sec_header(const cs_io_t *inp, size_t id)
Definition: cs_io.c:2058
void cs_io_write_block_buffer(const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, void *elts, cs_io_t *outp)
Definition: cs_io.c:2976
void cs_io_set_cs_gnum(cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.c:2472
void * cs_io_read_global(const cs_io_sec_header_t *header, void *elts, cs_io_t *pp_io)
Definition: cs_io.c:2541
const char * cs_io_get_name(const cs_io_t *pp_io)
Definition: cs_io.c:1991
int cs_io_set_indexed_position(cs_io_t *inp, cs_io_sec_header_t *header, size_t id)
Definition: cs_io.c:2334
cs_file_off_t cs_io_get_offset(cs_io_t *inp)
Definition: cs_io.c:3104
cs_io_t * cs_io_initialize_with_index(const char *file_name, const char *magic_string, cs_file_access_t method, long echo, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm)
Definition: cs_io.c:1882
void cs_io_set_offset(cs_io_t *inp, cs_file_off_t offset)
Definition: cs_io.c:3121
void cs_io_dump(const cs_io_t *cs_io)
Definition: cs_io.c:3260
struct _cs_io_t cs_io_t
Definition: cs_io.h:68
void cs_io_skip(const cs_io_sec_header_t *header, cs_io_t *pp_io)
Definition: cs_io.c:3050
integer(c_int), dimension(:), pointer, save inp
Definition: cpincl.f90:130
