Functions to handle the cs_navsto_system_t structure which is the high-level structure to manage the Navier-Stokes system of equations. More...
#include "cs_defs.h"#include <assert.h>#include <stdlib.h>#include <string.h>#include <bft_mem.h>#include "cs_array.h"#include "cs_cdofb_ac.h"#include "cs_cdofb_monolithic.h"#include "cs_cdofb_monolithic_sles.h"#include "cs_cdofb_navsto.h"#include "cs_cdofb_predco.h"#include "cs_hho_stokes.h"#include "cs_evaluate.h"#include "cs_flag.h"#include "cs_log.h"#include "cs_navsto_coupling.h"#include "cs_post.h"#include "cs_volume_zone.h"#include "cs_navsto_system.h"
Include dependency graph for cs_navsto_system.c:Macros | |
| #define | CS_NAVSTO_SYSTEM_DBG 0 |
| bool | cs_navsto_system_is_activated (void) |
| Check if the resolution of the Navier-Stokes system has been activated. More... | |
| void | cs_navsto_system_update_model (bool with_thermal) |
| Update the flag associated to the modelling options. More... | |
| cs_navsto_system_t * | cs_navsto_system_activate (const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag) |
| Allocate and initialize the Navier-Stokes (NS) system. More... | |
| void | cs_navsto_system_destroy (void) |
| Free the main structure related to the Navier-Stokes system. More... | |
| cs_navsto_param_t * | cs_navsto_system_get_param (void) |
| Retrieve the structure storing the parameters for the Navier–Stokes system. More... | |
| cs_equation_t * | cs_navsto_system_get_momentum_eq (void) |
| Retrieve a pointer to the equation related to the momentum equation. More... | |
| cs_adv_field_t * | cs_navsto_get_adv_field (void) |
| Retrieve the advection field structure (the mass flux) related to the Navier-Stokes system. More... | |
| cs_real_t * | cs_navsto_get_mass_flux (bool previous) |
| Retrieve the mass flux array related to the Navier-Stokes system. More... | |
| void | cs_navsto_system_init_setup (void) |
| Start setting-up the Navier-Stokes system At this stage, numerical settings should be completely determined but connectivity and geometrical information is not yet available. More... | |
| void | cs_navsto_system_finalize_setup (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Last step of the setup of the Navier-Stokes system. More... | |
| void | cs_navsto_system_define_context (const cs_mesh_t *mesh) |
| Initialize the scheme context structure used to build the algebraic system. This is done after the setup step. More... | |
| void | cs_navsto_system_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Set an initial value for the velocity and pressure fields as well as mass fluxes and tubulent quantities if needed. More... | |
| void | cs_navsto_system_set_solid_cells (cs_lnum_t n_solid_cells, cs_lnum_t solid_cell_ids[]) |
| Set a solid zone related to the Navier-Stokes equations. More... | |
| void | cs_navsto_system_update (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Update variables and related quantities when a new state of the Navier-Stokes system has been computed. More... | |
| void | cs_navsto_system_compute_steady_state (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Build, solve and update the Navier-Stokes system in case of a steady-state approach. More... | |
| void | cs_navsto_system_compute (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Build, solve and update the Navier-Stokes system. More... | |
| void | cs_navsto_system_extra_op (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Predefined extra-operations for the Navier-Stokes system. More... | |
| void | cs_navsto_system_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step) |
| Predefined post-processing output for the Navier-Stokes system. The prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More... | |
| void | cs_navsto_system_log_setup (void) |
| Summary of the main cs_navsto_system_t structure. More... | |
| #define CS_NAVSTO_SYSTEM_DBG 0 |
| cs_adv_field_t* cs_navsto_get_adv_field | ( | void | ) |
| cs_real_t* cs_navsto_get_mass_flux | ( | bool | previous | ) |
| [in] | previous | if true return the previous state otherwise the current state. |
| cs_navsto_system_t* cs_navsto_system_activate | ( | const cs_boundary_t * | boundaries, |
| cs_navsto_param_model_t | model, | ||
| cs_navsto_param_model_flag_t | model_flag, | ||
| cs_navsto_param_coupling_t | algo_coupling, | ||
| cs_navsto_param_post_flag_t | post_flag | ||
| [in] | model | type of model related to the NS system |
| [in] | model_flag | additional high-level model options |
| [in] | algo_coupling | algorithm used for solving the NS system |
| [in] | post_flag | predefined post-processings options |
| void cs_navsto_system_compute | ( | const cs_mesh_t * | mesh, |
| [in] | time_step | structure managing the time stepping |
| void cs_navsto_system_compute_steady_state | ( | const cs_mesh_t * | mesh, |
| void cs_navsto_system_define_context | ( | const cs_mesh_t * | mesh | ) |
| void cs_navsto_system_destroy | ( | void | ) |
| void cs_navsto_system_extra_op | ( | const cs_mesh_t * | mesh, |
| void cs_navsto_system_extra_post | ( | void * | input, |
| int | mesh_id, | ||
| int | cat_id, | ||
| int | ent_flag[5], | ||
| cs_lnum_t | n_cells, | ||
| cs_lnum_t | n_i_faces, | ||
| cs_lnum_t | n_b_faces, | ||
| [in,out] | input | pointer to a optional structure (here a cs_navsto_system_t structure) |
| void cs_navsto_system_finalize_setup | ( | const cs_mesh_t * | mesh, |
| cs_equation_t* cs_navsto_system_get_momentum_eq | ( | void | ) |
| cs_navsto_param_t* cs_navsto_system_get_param | ( | void | ) |
| void cs_navsto_system_init_setup | ( | void | ) |
| void cs_navsto_system_init_values | ( | const cs_mesh_t * | mesh, |
| bool cs_navsto_system_is_activated | ( | void | ) |
| void cs_navsto_system_log_setup | ( | void | ) |
| [in] | n_solid_cells | number of solid cells |
| [in] | solid_cell_ids | list of cell ids (local numbering) |
| void cs_navsto_system_update | ( | const cs_mesh_t * | mesh, |
| void cs_navsto_system_update_model | ( | bool | with_thermal | ) |
| [in] | with_thermal | true or false |
