1 #ifndef __CS_CDOFB_MONOLITHIC_SLES_H__
2 #define __CS_CDOFB_MONOLITHIC_SLES_H__
Structures and function pointers useful to build and solve the Navier-Stokes equations with face-base...
struct _cdofb_monolithic_t cs_cdofb_monolithic_t
Definition: cs_cdofb_monolithic_priv.h:76
int cs_cdofb_monolithic_sles_alu(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithi...
Definition: cs_cdofb_monolithic_sles.c:1030
int cs_cdofb_monolithic_sles_gkb_inhouse(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.c:1407
int cs_cdofb_monolithic_sles_uzawa_cg(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.c:1574
int cs_cdofb_monolithic_sles_notay(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.c:1498
void cs_cdofb_monolithic_sles_init_system_helper(const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_cdofb_monolithic_t *sc)
Define the system helper for a CDO-Fb scheme solving the Navier-Stokes equation using a monolithic ap...
Definition: cs_cdofb_monolithic_sles.c:704
void cs_cdofb_monolithic_set_sles(cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to couple the system...
void cs_cdofb_monolithic_sles_init_sharing(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Set pointers to shared structures.
Definition: cs_cdofb_monolithic_sles.c:680
int cs_cdofb_monolithic_sles_block_krylov(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-b...
Definition: cs_cdofb_monolithic_sles.c:1118
int cs_cdofb_monolithic_sles_full_system(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.c:1328
void cs_cdofb_monolithic_sles_init_solver(const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_cdofb_monolithic_t *sc)
Define the saddle solver and its context for a CDO-Fb scheme solving the Navier-Stokes equation using...
Definition: cs_cdofb_monolithic_sles.c:873
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_cdo_quantities.h:137
Definition: cs_navsto_param.h:262
Structure storing all metadata related to the resolution of a saddle-point linear system....
Definition: cs_param_saddle.h:272
Definition: cs_saddle_solver.h:88
