Structure storing the parameters related to the resolution of the Navier-Stokes system. More...
#include <cs_navsto_param.h>
Collaboration diagram for cs_navsto_param_t:Data Fields | |
| cs_real_t | delta_thermal_tolerance |
| int | n_max_outer_iter |
Physical modelling | |
Which equations to solve ? Properties and their related fields are allocated according to the choice of model for Navier-Stokes | |
| cs_navsto_param_model_t | model |
| cs_navsto_param_model_flag_t | model_flag |
| cs_turbulence_param_t * | turbulence |
Properties and fields related to the Navier-Stokes module | |
| cs_physical_constants_t * | phys_constants |
| cs_property_t * | mass_density |
| cs_property_t * | tot_viscosity |
| cs_property_t * | lam_viscosity |
Numerical options | |
Set of numerical options to build the linear system and how to solve it | |
| cs_param_dof_reduction_t | dof_reduction_mode |
| cs_navsto_param_coupling_t | coupling |
| cs_param_space_scheme_t | space_scheme |
| int | n_boussinesq_terms |
| cs_navsto_param_boussinesq_t * | boussinesq_param |
Non-linear algorithm | |
Set of parameters to drive the resolution of the non-linearity arising from the Navier–Stokes system | |
| cs_param_nl_algo_t | nl_algo_type |
| cs_param_convergence_t | nl_cvg_param |
| cs_iter_algo_param_aac_t | anderson_param |
Output | |
| int | verbosity |
| cs_navsto_param_post_flag_t | post_flag |
Initial conditions (IC) | |
Set of parameters used to take into account the initial condition on the pressure and/or the velocity. CAUTION: so far, there is no check if the different IC are compatible with the boundary conditions for instance | |
| bool | velocity_ic_is_owner |
| int | n_velocity_ic_defs |
| cs_xdef_t ** | velocity_ic_defs |
| bool | pressure_ic_is_owner |
| int | n_pressure_ic_defs |
| cs_xdef_t ** | pressure_ic_defs |
Boundary conditions (BC) | |
Set of parameters used to take into account the boundary conditions on the pressure and/or the velocity. | |
| const cs_boundary_t * | boundaries |
| bool | velocity_bc_is_owner |
| int | n_velocity_bc_defs |
| cs_xdef_t ** | velocity_bc_defs |
| bool | pressure_bc_is_owner |
| int | n_pressure_bc_defs |
| cs_xdef_t ** | pressure_bc_defs |
Other conditions | |
| cs_real_t | reference_pressure |
| anderson_param |
Set of parameters to drive the Anderson acceleration (useful if the type of non-linear algorithm is set to Anderson acceleration).
| const cs_boundary_t* boundaries |
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t Most of the time this should be false since an equation is associated to to the resolution of the velocity field (the momentum equation).
| cs_navsto_param_boussinesq_t* boussinesq_param |
How are defined the Degrees of freedom
| coupling |
Choice of algorithm for solving the system
Value under which one considers that the thermal equation is converged
Then stop iteration
| lam_viscosity |
Laminar viscosity
| mass_density |
Mass_density of the fluid, pointer to cs_property_t used in several terms in the Navier-Stokes equations
| model |
Modelling related to the Navier-Stokes system of equations
| model_flag |
Flag storing high-level option related to the Navier-Stokes system
| int n_boussinesq_terms |
| n_max_outer_iter |
Stopping criterion related to the maximum number of outer iterations allowed. This outer iteration encompasses the Navier-Stokes system, and (according to the case settings) the turbulence system and/or the thermal system.
Number of boundary conditions associated to the pressure field.
Number of initial conditions associated to the pressure
Number of definitions related to the settings of the boundary conditions for the velocity field.
Number of initial conditions associated to the velocity
| nl_algo_type |
Type of algorithm used to tackle the non-linearity arising from the advection term
| nl_cvg_param |
Structure storing several tolerances and metadata to drive the convergence of the non-linear iterative algorithm used to solve te Navier-Stokes when the advection term is implicit and non linearized.
| phys_constants |
Main physical constants (gravity vector and Coriolis source term). This structure is shared with the legacy part.
| post_flag |
Flag storing which predefined post-processing has to be done
| pressure_bc_defs |
Pointers to the definitions of the boundary conditions associated to the pressure field.
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t if an equation solves the pressure field.
| pressure_ic_defs |
Pointers to the definitions of the initial conditions associated to the pressure. In order to force a zero-mean pressure, the code can compute the average of the resulting pressure and subtract it
Value of the reference pressure p0 (used for rescaling or during update of physical quantities). By default: 0.
| space_scheme |
Discretization scheme for space
| tot_viscosity |
Laminar viscosity + if needed the turbulent viscosity Pointer to cs_property_t associated to the diffusion term for the momentum equation
| turbulence |
Structure storing all information needed to set the turbulence modelling
| velocity_bc_defs |
Array of pointers to the definition of boundary conditions for the velocity field
| velocity_ic_defs |
Pointers to the definitions of the initial conditions associated to the velocity. The code does not check if the resulting initial velocity satisfies the divergence constraint.
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a cs_equation_param_t structure dedicated to the momentum equation.
| verbosity |
Level of display of the information related to the Navier-Stokes system
