| int | cs_variable_cdo_field_create (const char *name, const char *label, int location_id, int dim, int has_previous) |
| | Add a field shared between CDO and legacy schemes. This field is related to a general solved variable, with default options. More...
| int | cs_variable_field_create (const char *name, const char *label, int location_id, int dim) |
| | Add field defining a general solved variable, with default options. More...
| cs_equation_param_t * | cs_field_get_equation_param (cs_field_t *f) |
| | Access a field's equation parameters. More...
| const cs_equation_param_t * | cs_field_get_equation_param_const (const cs_field_t *f) |
| | Access a field's equation parameters for read only. More...
| cs_field_t * | cs_field_get_variance (const cs_field_t *f) |
| | For a given field, returns field defined as its variance, if present. More...
| void | cs_field_build_bc_codes_all (void) |
| | Allocate and map boundary condition coefficients for all variable fields. More...
| void | cs_field_free_bc_codes_all (void) |
| | Deallocate and unmap boundary condition coefficients for all variable fields. More...
| void | cs_field_map_and_init_bcs (void) |
| | Initialize all field BC coefficients. More...
If the equation parameters were never initialized, they will be initialized based on the current defaults.
If the field does not have associated equation paremeters (i.e. is not a variable field or is a CDO field (which is referenced by but does not directly reference equations), NULL is returned.
- Parameters
| [in,out] | f | pointer to associated field |
- Returns
- pointer to field's equation parameters, or NULL
If the equation parameters were never initialized, the current default parameters will be returned instead.
If the field does not have associated equation parameters (i.e. is not a variable field or is a CDO field (which is referenced by but does not directly reference equations), NULL is returned.
- Parameters
| [in] | f | pointer to associated field |
- Returns
- const-qualified pointer to field's equation parameters, or NULL
