8.1
cs_turbulence_rij.c File Reference
#include "cs_array.h"
#include "cs_blas.h"
#include "cs_boundary_conditions.h"
#include "cs_domain.h"
#include "cs_equation_iterative_solve.h"
#include "cs_face_viscosity.h"
#include "cs_field_default.h"
#include "cs_field_pointer.h"
#include "cs_gradient.h"
#include "cs_lagr.h"
#include "cs_log_iteration.h"
#include "cs_mass_source_terms.h"
#include "cs_math.h"
#include "cs_porous_model.h"
#include "cs_prototypes.h"
#include "cs_rotation.h"
#include "cs_solid_zone.h"
#include "cs_thermal_model.h"
#include "cs_time_step.h"
#include "cs_turbulence_bc.h"
#include "cs_velocity_pressure.h"
#include "cs_wall_functions.h"
#include "cs_turbulence_rij.h"
+ Include dependency graph for cs_turbulence_rij.c:
void cs_turbulence_rij (int phase_id, cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], cs_real_t smacel[])
 Solve the $ R_{ij} - \epsilon $ for incompressible flows or slightly compressible flows for one time step. More...
void cs_turbulence_rij_solve_alpha (int f_id, int phase_id, cs_real_t c_durbin_l)
 Solve the equation on alpha in the framework of the Rij-EBRSM model. More...
void cs_turbulence_rij_init_by_ref_quantities (cs_real_t uref, cs_real_t almax)
 Initialize Rij-epsilon variables based on reference quantities. More...
void cs_turbulence_rij_clip (int phase_id, cs_lnum_t n_cells)
 Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version). More...
void cs_turbulence_rij_mu_t (int phase_id)
 Compute the turbulent viscosity for the Reynolds Stress model. More...
void cs_turbulence_rij_compute_rusanov (void)
 Compute Rusanov equivalent diffusivity of the model. ! More...
◆ cs_turbulence_rij()
void cs_turbulence_rij ( int  phase_id,
cs_lnum_t  ncesmp,
cs_lnum_t  icetsm[],
int  itypsm[],
cs_real_t  smacel[]
Please refer to the $ R_{ij} - \epsilon $ model section of the theory guide for more informations, as well as the turrij section.
[in]phase_idturbulent phase id (-1 for single phase flow)
[in]ncesmpnumber of cells with mass source term
[in]icetsmindex of cells with mass source term
[in]itypsmmass source type for the variables
[in]smacelvalues of the variables associated to the mass source (for ivar=ipr, smacel is the mass flux) !
◆ cs_turbulence_rij_clip()
void cs_turbulence_rij_clip ( int  phase_id,
cs_lnum_t  n_cells
[in]n_cellsnumber of cells
◆ cs_turbulence_rij_compute_rusanov()
void cs_turbulence_rij_compute_rusanov ( void  )
◆ cs_turbulence_rij_init_by_ref_quantities()
void cs_turbulence_rij_init_by_ref_quantities ( cs_real_t  uref,
cs_real_t  almax
If uref is not provided (0 or negative), values are set at a large negative value (-cs_math_big_r) to allow for later checks.
[in]urefcharacteristic flow velocity
[in]almaxcharacteristic macroscopic length of the domain
◆ cs_turbulence_rij_mu_t()
void cs_turbulence_rij_mu_t ( int  phase_id)
◆ cs_turbulence_rij_solve_alpha()
void cs_turbulence_rij_solve_alpha ( int  f_id,
int  phase_id,
Also called for alpha of scalars for EB-DFM.
[in]f_idfield id of alpha variable
[in]c_durbin_lconstant for the Durbin length !
