8.1
cs_turbulence_bc.h
1 #ifndef __CS_TURBULENCE_BC_H__
2 #define __CS_TURBULENCE_BC_H__
5  * Base turbulence boundary conditions.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
49  * Global variables
51
52 /*=============================================================================
53  * Public function prototypes
55
56 /*----------------------------------------------------------------------------*/
57 /*
58  * Initialize turbulence model boundary condition pointers.
59  */
60 /*----------------------------------------------------------------------------*/
61
62 void
64
65 /*----------------------------------------------------------------------------*/
66 /*
67  * \brief Free memory allocations for turbulence boundary condition pointers.
68  */
69 /*----------------------------------------------------------------------------*/
70
71 void
73
75 /*
76  * \brief Calculation of \f$ u^\star \f$, \f$ k \f$ and \f$\varepsilon \f$
77  * from a diameter \f$ D_H \f$ and the reference velocity \f$ U_{ref} \f$
78  * for a circular duct flow with smooth wall
79  * (use for inlet boundary conditions).
80  *
81  * Both \f$ u^\star \f$ and\f$ (k,\varepsilon )\f$ are returned, so that
82  * the user may compute other values of \f$ k \f$ and \f$ \varepsilon \f$
83  * with \f$ u^\star \f$.
84  *
85  * We use the laws from Idel'Cik, i.e.
86  * the head loss coefficient \f$ \lambda \f$ is defined by:
87  * \f[ |\dfrac{\Delta P}{\Delta x}| =
88  * \dfrac{\lambda}{D_H} \frac{1}{2} \rho U_{ref}^2 \f]
89  *
90  * then the relation reads \f$u^\star = U_{ref} \sqrt{\dfrac{\lambda}{8}}\f$.
91  * \f$\lambda \f$ depends on the hydraulic Reynolds number
92  * \f$ Re = \dfrac{U_{ref} D_H}{ \nu} \f$ and is given by:
93  * - for \f$ Re < 2000 \f$
94  * \f[ \lambda = \dfrac{64}{Re} \f]
95  *
96  * - for \f$ Re > 4000 \f$
97  * \f[ \lambda = \dfrac{1}{( 1.8 \log_{10}(Re)-1.64 )^2} \f]
98  *
99  * - for \f$ 2000 < Re < 4000 \f$, we complete by a straight line
100  * \f[ \lambda = 0.021377 + 5.3115. 10^{-6} Re \f]
101  *
102  * From \f$ u^\star \f$, we can estimate \f$ k \f$ and \f$ \varepsilon\f$
103  * from the well known formulae of developped turbulence
104  *
105  * \f[ k = \dfrac{u^{\star 2}}{\sqrt{C_\mu}} \f]
106  * \f[ \varepsilon = \dfrac{ u^{\star 3}}{(\kappa D_H /10)} \f]
107  *
108  * \param[in] uref2 square of the reference flow velocity
109  * \param[in] dh hydraulic diameter \f$ D_H \f$
110  * \param[in] rho mass density \f$ \rho \f$
111  * \param[in] mu dynamic viscosity \f$ \nu \f$
112  * \param[out] ustar2 square of friction speed
113  * \param[out] k calculated turbulent intensity \f$ k \f$
114  * \param[out] eps calculated turbulent dissipation
115  * \f$ \varepsilon \f$
116  */
117 /*----------------------------------------------------------------------------*/
118
119 void
120 cs_turbulence_bc_ke_hyd_diam(double uref2,
121  double dh,
122  double rho,
123  double mu,
124  double *ustar2,
125  double *k,
126  double *eps);
127
129 /*
130  * \brief Calculation of \f$ k \f$ and \f$\varepsilon\f$
131  * from a diameter \f$ D_H \f$, a turbulent intensity \f$ I \f$
132  * and the reference velocity \f$ U_{ref} \f$
133  * for a circular duct flow with smooth wall
134  * (for inlet boundary conditions).
135  *
136  * \f[ k = 1.5 I {U_{ref}}^2 \f]
137  * \f[ \varepsilon = 10 \dfrac{{C_\mu}^{0.75} k^{1.5}}{ \kappa D_H} \f]
138  *
139  * \param[in] uref2 square of the reference flow velocity
140  * \param[in] t_intensity turbulent intensity \f$ I \f$
141  * \param[in] dh hydraulic diameter \f$ D_H \f$
142  * \param[out] k calculated turbulent intensity \f$ k \f$
143  * \param[out] eps calculated turbulent dissipation
144  * \f$ \varepsilon \f$
145  */
147
148 void
150  double t_intensity,
151  double dh,
152  double *k,
153  double *eps);
154
155 /*----------------------------------------------------------------------------*/
156 /*
157  * \brief Set inlet boundary condition values for turbulence variables based
158  * on a diameter \f$ D_H \f$ and the reference velocity \f$ U_{ref} \f$
159  * for a circular duct flow with smooth wall
160  * (use for inlet boundary conditions).
161  *
162  * We use the laws from Idel'Cik, i.e.
163  * the head loss coefficient \f$ \lambda \f$ is defined by:
164  * \f[ |\dfrac{\Delta P}{\Delta x}| =
165  * \dfrac{\lambda}{D_H} \frac{1}{2} \rho U_{ref}^2 \f]
166  *
167  * then the relation reads \f$u^\star = U_{ref} \sqrt{\dfrac{\lambda}{8}}\f$.
168  * \f$\lambda \f$ depends on the hydraulic Reynolds number
169  * \f$ Re = \dfrac{U_{ref} D_H}{ \nu} \f$ and is given by:
170  * - for \f$ Re < 2000 \f$
171  * \f[ \lambda = \dfrac{64}{Re} \f]
172  *
173  * - for \f$ Re > 4000 \f$
174  * \f[ \lambda = \dfrac{1}{( 1.8 \log_{10}(Re)-1.64 )^2} \f]
175  *
176  * - for \f$ 2000 < Re < 4000 \f$, we complete by a straight line
177  * \f[ \lambda = 0.021377 + 5.3115. 10^{-6} Re \f]
178  *
179  * From \f$ u^\star \f$, we can estimate \f$ k \f$ and \f$ \varepsilon\f$
180  * from the well known formulae of developped turbulence
181  *
182  * \param[in] face_id boundary face id
183  * \param[in] uref2 square of the reference flow velocity
184  * \param[in] dh hydraulic diameter \f$ D_H \f$
185  * \param[in] rho mass density \f$ \rho \f$
186  * \param[in] mu dynamic viscosity \f$ \nu \f$
187  */
188 /*----------------------------------------------------------------------------*/
189
190 void
192  double uref2,
193  double dh,
194  double rho,
195  double mu);
196
197 /*----------------------------------------------------------------------------*/
198 /*
199  * \brief Set inlet boundary condition values for turbulence variables based
200  * on a diameter \f$ D_H \f$, a turbulent intensity \f$ I \f$
201  * and the reference velocity \f$ U_{ref} \f$
202  * for a circular duct flow with smooth wall.
203  *
204  * \param[in] face_id boundary face id
205  * \param[in] uref2 square of the reference flow velocity
206  * \param[in] t_intensity turbulent intensity \f$ I \f$
207  * \param[in] dh hydraulic diameter \f$ D_H \f$
208  */
209 /*----------------------------------------------------------------------------*/
210
211 void
213  double uref2,
214  double t_intensity,
215  double dh);
216
217 /*----------------------------------------------------------------------------*/
218 /*
219  * \brief Set inlet boundary condition values for turbulence variables based
220  * on given k and epsilon values.
221  *
222  * \param[in] face_id boundary face id
223  * \param[in] k turbulent kinetic energy
224  * \param[in] eps turbulent dissipation
225  */
226 /*----------------------------------------------------------------------------*/
227
228 void
230  double k,
231  double eps);
232
233 /*----------------------------------------------------------------------------*/
234 /*
235  * \brief Set inlet boundary condition values for turbulence variables based
236  * on a diameter \f$ D_H \f$ and the reference velocity \f$ U_{ref} \f$
237  * for a circular duct flow with smooth wall, only if not already set.
238  *
239  * Apart from assigning values where not already initialized, this function
240  * is similar to \ref cs_turbulence_bc_inlet_hyd_diam.
241  *
242  * \param[in] face_id boundary face id
243  * \param[in] vel_dir velocity direction (not normalized, or NULL)
244  * \param[in] shear_dir shear direction (or NULL), it also contains the
245  * level of anisotropy (Rnt = a_nt k)
246  * \param[in] uref2 square of the reference flow velocity
247  * \param[in] dh hydraulic diameter \f$ D_H \f$
248  * \param[in] rho mass density \f$ \rho \f$
249  * \param[in] mu dynamic viscosity \f$ \nu \f$
250  */
251 /*----------------------------------------------------------------------------*/
252
253 void
255  double vel_dir[],
256  double shear_dir[],
257  double uref2,
258  double dh,
259  double rho,
260  double mu);
261
262 /*----------------------------------------------------------------------------*/
263 /*
264  * \brief Set inlet boundary condition values for turbulence variables based
265  * on a diameter \f$ D_H \f$, a turbulent intensity \f$ I \f$
266  * and the reference velocity \f$ U_{ref} \f$
267  * for a circular duct flow with smooth wall, only if not already set.
268  *
269  * Apart from assigning values where not already initialized, this function
270  * is similar to \ref cs_turbulence_bc_inlet_turb_intensity.
271  *
272  * \param[in] face_id boundary face id
273  * \param[in] uref2 square of the reference flow velocity
274  * \param[in] t_intensity turbulent intensity \f$ I \f$
275  * \param[in] dh hydraulic diameter \f$ D_H \f$
276  */
277 /*----------------------------------------------------------------------------*/
278
279 void
281  double uref2,
282  double t_intensity,
283  double dh);
284
285 /*----------------------------------------------------------------------------*/
286 /*
287  * \brief Set inlet boundary condition values for turbulence variables based
288  * on given k and epsilon values only if not already initialized.
289  *
290  * \param[in] face_id boundary face id
291  * \param[in] k turbulent kinetic energy
292  * \param[in] eps turbulent dissipation
293  * \param[in] vel_dir velocity direction
294  * \param[in] shear_dir shear direction
295  */
296 /*----------------------------------------------------------------------------*/
297
298 void
300  double k,
301  double eps,
302  double vel_dir[],
303  double shear_dir[]);
304
305 /*----------------------------------------------------------------------------*/
306 /*
307  * \brief Assign homogeneous Neumann turbulent boundary conditions to
308  * a given face.
309  *
310  * This is useful for outgoing flow.
311  */
312 /*----------------------------------------------------------------------------*/
313
314 void
316
317 /*----------------------------------------------------------------------------*/
318 /*
319  * \brief Compute matrix \f$\tens{\alpha}\f$ used in the computation of the
320  * Reynolds stress tensor boundary conditions.
321  *
322  * We note \f$\tens{R}_g\f$ the Reynolds Stress tensor in the global reference
323  * frame (mesh reference frame) and \f$\tens{R}_l\f$ the Reynolds stress
324  * tensor in the local reference frame (reference frame associated to the
325  * boundary face).
326  *
327  * \f$\tens{P}_{lg}\f$ is the change of basis orthogonal matrix from local
328  * to global reference frame.
329
330  * \f$\tens{\alpha}\f$ is a 6 by 6 matrix such that:
331  * \f[
332  * \vect{R}_{g,\fib} = \tens{\alpha} \vect{R}_{g,\centip} + \vect{R}_{g}^*
333  * \f]
334  * where symetric tensors \f$\tens{R}_g\f$ have been unfolded as follows:
335  * \f[
336  * \vect{R}_g = \transpose{\left(R_{g,11},R_{g,22},R_{g,33},
337  * R_{g,12},R_{g,13},R_{g,23}\right)}
338  * \f].
339  *
340  * \f$\tens{\alpha}\f$ is defined so that \f$ \tens{R}_{g,\fib} \f$ is computed
341  * as a function of \f$\tens{R}_{g,\centip}\f$ as follows:
342  * \f[
343  * \tens{R}_{g,\fib}=\tens{P}_{lg}\tens{R}_{l,\fib}\transpose{\tens{P}_{lg}}
344  * \f]
345  *
346  * with
347  * \f[
348  * \tens{R}_{l,\fib} =
349  * \begin{bmatrix}
350  * R_{l,11,\centip} & u^* u_k & c R_{l,13,\centip}\\
351  * u^* u_k & R_{l,22,\centip} & 0 \\
352  * c R_{l,13,\centip} & 0 & R_{l,33,\centip}
353  * \end{bmatrix} +
354  * \underbrace{\begin{bmatrix}
355  * 0 & u^* u_k & 0 \\
356  * u^* u_k & 0 & 0 \\
357  * 0 & 0 & 0
358  * \end{bmatrix}}_{\tens{R}_l^*}
359  * \f]
360  *
361  * and
362  * \f$\tens{R}_{l,\centip}=\transpose{\tens{P}_{lg}}\tens{R}_{g,\centip}
363  * \tens{P}_{lg}\f$.
364  *
365  * Constant c is chosen depending on the type of the boundary face:
366  * \f$c = 0\f$ at a wall face, \f$c = 1\f$ at a symmetry face.
367  *
368  * \param[in] is_sym Constant c in description above
369  * (1 at a symmetry face, 0 at a wall face)
370  * \param[in] p_lg change of basis matrix (local to global)
371  * \param[out] alpha transformation matrix
372  */
373 /*----------------------------------------------------------------------------*/
374
375 void
377  cs_real_t p_lg[3][3],
378  cs_real_t alpha[6][6]);
379
380 /*----------------------------------------------------------------------------*/
381
383
384 #endif /* __CS_TURBULENCE_BC_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ k
@ mu
Definition: cs_field_pointer.h:103
@ eps
Definition: cs_field_pointer.h:71
@ rho
void cs_turbulence_bc_ke_turb_intensity(double uref2, double t_intensity, double dh, double *k, double *eps)
Calculation of and from a diameter , a turbulent intensity and the reference velocity for a circu...
Definition: cs_turbulence_bc.c:827
Definition: cs_turbulence_bc.c:871
void cs_turbulence_bc_set_uninit_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh)
Set inlet boundary condition values for turbulence variables based on a diameter ,...
Definition: cs_turbulence_bc.c:1084
void cs_turbulence_bc_rij_transform(int is_sym, cs_real_t p_lg[3][3], cs_real_t alpha[6][6])
Compute matrix used in the computation of the Reynolds stress tensor boundary conditions.
Definition: cs_turbulence_bc.c:1181
void cs_turbulence_bc_inlet_k_eps(cs_lnum_t face_id, double k, double eps)
Definition: cs_turbulence_bc.c:923
void cs_turbulence_bc_free_pointers(void)
Definition: cs_turbulence_bc.c:741
void cs_turbulence_bc_set_uninit_inlet_k_eps(cs_lnum_t face_id, double k, double eps, double vel_dir[], double shear_dir[])
Set inlet boundary condition values for turbulence variables based on given k and epsilon values only...
Definition: cs_turbulence_bc.c:1111
void cs_turbulence_bc_ke_hyd_diam(double uref2, double dh, double rho, double mu, double *ustar2, double *k, double *eps)
Calculation of , and from a diameter and the reference velocity for a circular duct flow with smo...
Definition: cs_turbulence_bc.c:795
void cs_turbulence_bc_init_pointers(void)
Definition: cs_turbulence_bc.c:650
void cs_turbulence_bc_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh)
Definition: cs_turbulence_bc.c:899
void cs_turbulence_bc_set_hmg_neumann(cs_lnum_t face_id)
Assign homogeneous Neumann turbulent boundary conditions to a given face.
Definition: cs_turbulence_bc.c:940
void cs_turbulence_bc_set_uninit_inlet_hyd_diam(cs_lnum_t face_id, double vel_dir[], double shear_dir[], double uref2, double dh, double rho, double mu)
Definition: cs_turbulence_bc.c:1051
real(c_double), dimension(:), pointer, save dh
hydraulic diameter
Definition: ppincl.f90:713
double precision, dimension(ncharm), save alpha
Definition: cpincl.f90:96
