1 #ifndef __CS_PROTOTYPES_H__
2 #define __CS_PROTOTYPES_H__
628 int structure_num[]);
1003 const int bc_type[],
1159 const char *syrthes_name,
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:514
Definition: cs_defs.h:319
#define CS_PROCF(x, y)
Definition: cs_defs.h:528
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:334
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ t
@ xlam
Definition: cs_field_pointer.h:182
@ eps
Definition: cs_field_pointer.h:71
@ h
Definition: cs_field_pointer.h:91
@ epa
Definition: cs_field_pointer.h:183
@ dt
struct _cs_probe_set_t cs_probe_set_t
Definition: cs_probe.h:53
void cs_user_postprocess_meshes(void)
Define post-processing meshes.
Definition: cs_user_postprocess.c:86
void cs_user_rad_transfer_absorption(const int bc_type[], cs_real_t ck[])
Absorption coefficient for radiative module.
Definition: cs_user_radiative_transfer.c:103
void cs_coal_bt2h(cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t t[], cs_real_t h[])
Convert temperature to enthalpy at boundary for coal combustion.
void cs_user_mesh_bad_cells_tag(cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Tag bad cells within the mesh based on user-defined geometric criteria.
Definition: cs_user_mesh.c:219
void cs_user_wall_condensation(int nvar, int nscal, int iappel)
Source terms associated at the boundary faces and the neighboring cells with surface condensation.
Definition: cs_user_wall_condensation.c:169
void cs_user_mesh_boundary(cs_mesh_t *mesh)
Insert boundaries into a mesh.
Definition: cs_user_mesh.c:156
void cs_user_zones(void)
Define volume and surface zones.
Definition: cs_user_zones.c:65
void cs_user_model(void)
Select physical model options, including user fields.
Definition: cs_user_parameters.c:84
void cs_add_model_thermal_field_indexes(int f_id)
void cs_physical_model_source_terms(int iscal, cs_real_t st_imp[], cs_real_t st_exp[])
void cs_user_join(void)
Define mesh joinings.
Definition: cs_user_mesh.c:115
void cs_user_extra_operations_finalize(cs_domain_t *domain)
This function is called at the end of the calculation.
Definition: cs_user_extra_operations.c:122
void cs_lagr_status(int *model_flag, int *restart_flag, int *frozen_flag)
void cs_user_internal_coupling(void)
Define internal coupling options.
Definition: cs_user_parameters.c:162
void cs_user_extra_operations(cs_domain_t *domain)
This function is called at the end of each time step.
Definition: cs_user_extra_operations.c:104
void cs_user_syrthes_coupling_volume_h(int coupling_id, const char *syrthes_name, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t h_vol[])
Compute a volume exchange coefficient for SYRTHES couplings.
Definition: cs_user_coupling.c:114
void cs_user_syrthes_coupling(void)
Define couplings with SYRTHES code.
Definition: cs_user_coupling.c:95
void cs_user_parameters(cs_domain_t *domain)
Define or modify general numerical and physical user parameters.
Definition: cs_user_parameters.c:107
void cs_user_boundary_conditions_ale(cs_domain_t *domain, int bc_type[], int ale_bc_type[], int impale[])
User definition of boundary conditions for ALE.
Definition: cs_user_boundary_conditions.c:177
void cs_user_physical_properties_td_pressure(cs_real_t *td_p)
User function to define a custom law for the thermodynamic pressure.
Definition: cs_user_physical_properties.c:179
void cs_user_physical_properties_turb_viscosity(cs_domain_t *domain)
User modification of the turbulence viscosity.
Definition: cs_user_physical_properties.c:157
void cs_user_boundary_conditions_setup(cs_domain_t *domain)
Set boundary conditions to be applied.
Definition: cs_user_boundary_conditions.c:77
void cs_user_turbomachinery_rotor(void)
Define rotor axes, associated cells, and rotor/stator faces.
Definition: cs_user_turbomachinery.c:90
void cs_field_map_and_init_bcs(void)
Initialize all field BC coefficients.
void cs_user_turbomachinery_set_rotation_velocity(void)
Define rotation velocity of rotor.
Definition: cs_user_turbomachinery.c:103
void cs_user_postprocess_activate(int nt_max_abs, int nt_cur_abs, double t_cur_abs)
Definition: cs_user_postprocess.c:177
void cs_secondary_viscosity(cs_real_t secvif[], cs_real_t secvib[])
Computes the secondary viscosity contribution in order to compute:
void cs_user_linear_solvers(void)
Define linear solver options.
Definition: cs_user_parameters.c:130
void cs_user_periodicity(void)
Define periodic faces.
Definition: cs_user_mesh.c:128
void findpt(const cs_lnum_t *ncelet, const cs_lnum_t *ncel, const cs_real_t *xyzcen, const cs_real_t *xx, const cs_real_t *yy, const cs_real_t *zz, cs_lnum_t *node, int *ndrang)
void initi1(void)
Definition: initi1.f90:29
void cs_user_internal_coupling_from_disjoint_meshes(cs_mesh_t *mesh)
Define volumesi from separated meshes as internal coupling zones.
Definition: cs_internal_coupling.c:2969
void cs_user_scaling_elec(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *dt)
Define scaling parameter for electric model.
Definition: cs_user_electric_scaling.c:75
void cs_user_mesh_cartesian_define(void)
Define a cartesian mesh.
Definition: cs_user_mesh.c:253
void cs_fortran_resize_aux_arrays(void)
resize some Fortran auxiliary arrays
void cs_coal_thfieldconv1(int location_id, const cs_real_t eh[], cs_real_t tp[])
Calculation of the gas temperature Function with the gas enthalpy and concentrations.
void cs_user_mesh_modify(cs_mesh_t *mesh)
Modify geometry and mesh.
Definition: cs_user_mesh.c:171
void cs_mass_flux_prediction(cs_real_t dt[])
Update the convective mass flux before the Navier Stokes equations (prediction and correction steps).
void cs_user_fsi_structure_num(cs_domain_t *domain, int structure_num[])
Define structure numbers for faces associated with internal or external (code_aster) structures.
Definition: cs_user_fluid_structure_interaction.c:174
void cs_user_radiative_transfer_bcs(cs_domain_t *domain, const int bc_type[], int isothp[], cs_real_t *tmin, cs_real_t *tmax, cs_real_t *tx, const cs_real_t dt[], const cs_real_t thwall[], const cs_real_t qincid[], cs_real_t hfcnvp[], cs_real_t flcnvp[], cs_real_t xlamp[], cs_real_t epap[], cs_real_t epsp[], cs_real_t textp[])
User definition of radiative transfer boundary conditions.
Definition: cs_user_radiative_transfer_bcs.c:124
void cs_user_postprocess_probes(void)
Define monitoring probes and profiles.
Definition: cs_user_postprocess.c:101
void cs_user_numbering(void)
Define advanced mesh numbering options.
Definition: cs_user_performance_tuning.c:74
void cs_user_1d_wall_thermal(int iappel, int isuit1)
Definition: cs_user_1d_wall_thermal.c:82
void cs_user_physical_properties_h_to_t(cs_domain_t *domain, const cs_zone_t *z, bool z_local, const cs_real_t h[restrict], cs_real_t t[restrict])
User definition of enthalpy to temperature conversion.
void cs_user_fsi_structure_values(int n_structs, const cs_time_step_t *ts, const cs_real_t xstreq[][3], const cs_real_t xstr[][3], const cs_real_t vstr[][3], cs_real_t xmstru[][3][3], cs_real_t xcstru[][3][3], cs_real_t xkstru[][3][3], cs_real_t forstr[][3], cs_real_t dtstr[])
Time-based settings for internal mobile structures.
Definition: cs_user_fluid_structure_interaction.c:134
void cs_user_time_moments(void)
Define time moments.
Definition: cs_user_parameters.c:147
void cs_atmo_chem_source_terms(int iscal, cs_real_t st_exp[], cs_real_t st_imp[])
void cs_user_radiative_transfer_parameters(void)
User function for input of radiative transfer module options.
Definition: cs_user_radiative_transfer.c:77
int cs_user_solver_set(void)
Set user solver.
Definition: cs_user_solver.c:75
void cs_at_source_term_for_inlet(cs_real_3_t st_exp[])
Additional right-hand side source terms for momentum equation in case of free inlet.
void cs_user_mesh_input(void)
Define mesh files to read and optional associated transformations.
Definition: cs_user_mesh.c:102
void cs_user_time_table(void)
Define time tables using C API. This function is called at the begin of the simulation only.
Definition: cs_user_time_table.c:77
int cs_add_model_field_indexes(int f_id)
void cs_wall_condensation_volume_exchange_surf_at_cells(cs_real_t *surf)
Return condensing volume structures surface at each cell.
Definition: cs_wall_condensation.c:1072
void cs_hydrostatic_pressure_prediction(cs_real_t grdphd[][3], int iterns)
Computes a hydrostatic pressure solving an a priori simplified momentum equation:
void cs_user_mesh_restart_mode(void)
Force preprocessing behavior in case of restart.
Definition: cs_user_mesh.c:89
void cs_user_mesh_save(cs_mesh_t *mesh)
Enable or disable mesh saving.
Definition: cs_user_mesh.c:203
void cs_user_porosity(cs_domain_t *domain)
Compute the porosity (volume factor when the porosity model is activated. (cs_glob_porous_model > 0)...
Definition: cs_user_porosity.c:80
void cs_user_source_terms(cs_domain_t *domain, int f_id, cs_real_t *st_exp, cs_real_t *st_imp)
Additional user-defined source terms for variable equations (momentum, scalars, turbulence....
Definition: cs_user_source_terms.c:155
void cs_compressible_convective_mass_flux(int iterns, cs_real_t dt[], cs_real_t vela[][3])
Solves the continuity equation in pressure formulation and then updates the density and the mass flux...
void cs_user_postprocess_values(const char *mesh_name, int mesh_id, int cat_id, cs_probe_set_t *probes, cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, cs_lnum_t n_vertices, const cs_lnum_t cell_list[], const cs_lnum_t i_face_list[], const cs_lnum_t b_face_list[], const cs_lnum_t vertex_list[], const cs_time_step_t *ts)
User function for output of values on a post-processing mesh.
Definition: cs_user_postprocess.c:134
void cs_prediction_mass_flux(cs_lnum_t ncesmp, cs_lnum_t icetsm[], cs_real_t dt[])
void cs_user_matrix_tuning(void)
Define sparse matrix tuning options.
Definition: cs_user_performance_tuning.c:113
void cs_user_paramedmem_define_fields(void)
Define fields to couple with ParaMEDMEM.
Definition: cs_user_paramedmem_coupling.c:108
void cs_user_internal_coupling_add_volumes(cs_mesh_t *mesh)
Define volumes as internal coupling zones.
Definition: cs_internal_coupling.c:2950
void cs_user_mesh_modify_partial(cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Apply partial modifications to the mesh after the preprocessing and initial postprocessing mesh build...
Definition: cs_user_mesh.c:238
void cs_user_physical_properties(cs_domain_t *domain)
This function is called each time step to define physical properties.
Definition: cs_user_physical_properties.c:75
void cs_cavitation_compute_source_term(const cs_real_t pressure[], const cs_real_t voidf[])
Compute the vaporization source term using the Merkle model:
cs_real_t * cs_get_cavitation_gam(void)
Return pointer to cavitation "gamcav" array.
void cs_user_head_losses(const cs_zone_t *zone, cs_real_t cku[][6])
Compute GUI-defined head losses for a given volume zone.
Definition: cs_user_head_losses.c:86
void cs_user_fsi_structure_define(int is_restart, int n_structs, int *plot, cs_time_control_t *plot_time_control, cs_real_t *aexxst, cs_real_t *bexxst, cs_real_t *cfopre, cs_real_t xstr0[][3], cs_real_t vstr0[][3], cs_real_t xstreq[][3])
Definition of internal mobile structures and corresponding initial conditions (initial displacement a...
Definition: cs_user_fluid_structure_interaction.c:92
void cs_user_solver(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
Main call to user solver.
Definition: cs_user_solver.c:92
cs_real_t * cs_get_cavitation_dgdp_st(void)
Return pointer to cavitation "dgdpca" array.
void cs_user_postprocess_writers(void)
Define post-processing writers.
Definition: cs_user_postprocess.c:69
void cs_user_boundary_conditions(cs_domain_t *domain, int bc_type[])
User definition of boundary conditions.
Definition: cs_user_boundary_conditions.c:123
void cs_user_mesh_smoothe(cs_mesh_t *mesh)
Mesh smoothing.
Definition: cs_user_mesh.c:186
void cs_user_initialization(cs_domain_t *domain)
This function is called one time step to initialize problem.
Definition: cs_user_initialization.c:88
void cs_user_extra_operations_initialize(cs_domain_t *domain)
Initialize variables.
Definition: cs_user_extra_operations.c:86
void cs_user_cathare_coupling(void)
Definition: cs_user_coupling.c:138
void caltri(void)
Definition: caltri.f90:36
void csinit(const int *irgpar, const int *nrgpar)
void cs_user_paramedmem_define_couplings(void)
Define ParaMEDMEM coupling(s)
Definition: cs_user_paramedmem_coupling.c:82
void cs_user_hgn_thermo_relax_time(const cs_mesh_t *mesh, const cs_real_t *alpha_eq, const cs_real_t *y_eq, const cs_real_t *z_eq, const cs_real_t *ei, const cs_real_t *v, cs_real_t *relax_tau)
Computation of the relaxation time-scale.
Definition: cs_user_hgn.c:82
void cs_user_mesh_warping(void)
Set options for cutting of warped faces.
Definition: cs_user_mesh.c:141
void cs_sat_coupling_exchange_at_cells(int f_id, cs_real_t st_exp[], cs_real_t st_imp[])
void cs_user_partition(void)
Define advanced partitioning options.
Definition: cs_user_performance_tuning.c:87
void cs_user_physical_properties_t_to_h(cs_domain_t *domain, const cs_zone_t *z, bool z_local, const cs_real_t t[restrict], cs_real_t h[restrict])
User definition of temperature to enthalpy conversion.
void cs_user_parallel_io(void)
Define parallel IO settings.
Definition: cs_user_performance_tuning.c:100
void cs_turbomachinery_update(void)
Sync turbomachinery module components to global c turbomachinery structure.
void cs_user_paramedmem_define_meshes(void)
Define coupled meshes.
Definition: cs_user_paramedmem_coupling.c:95
void cs_user_finalize_setup(cs_domain_t *domain)
Define or modify output user parameters. For CDO schemes, specify the elements such as properties,...
Definition: cs_user_parameters.c:180
void cs_user_rad_transfer_net_flux(const int itypfb[], const cs_real_t coefap[], const cs_real_t coefbp[], const cs_real_t cofafp[], const cs_real_t cofbfp[], const cs_real_t twall[], const cs_real_t qincid[], const cs_real_t xlam[], const cs_real_t epa[], const cs_real_t eps[], const cs_real_t ck[], cs_real_t net_flux[])
Compute the net radiation flux.
Definition: cs_user_radiative_transfer.c:141
void cs_user_saturne_coupling(void)
Define couplings with other instances of code_saturne.
Definition: cs_user_coupling.c:79
void cs_user_turbomachinery(void)
Define rotor/stator model.
Definition: cs_user_turbomachinery.c:77
void cpthp1(const int *mode, cs_real_t *eh, cs_real_t *xesp, cs_real_t *f1mc, cs_real_t *f2mc, cs_real_t *tp)
void cs_drift_convective_flux(int f_id, const cs_real_t dt[], cs_real_t imasfl[], cs_real_t bmasf[], cs_real_t divflu[])
Compute the modified convective flux for scalars with a drift.
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:114
double precision, dimension(:,:,:), allocatable pressure
Definition: atimbr.f90:122
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
integer, dimension(:), pointer, save itypfb
boundary condition type at the boundary face ifac (see cs_user_boundary_conditions)
Definition: pointe.f90:89
integer, save nscal
number of solved user scalars effective number of scalars solutions of an advection equation,...
Definition: dimens.f90:55
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition: dimens.f90:42
integer, save ncelet
number of extended (real + ghost of the 'halo') cells. See Note 1: ghost cells - (halos)
Definition: mesh.f90:48
double precision, dimension(:,:), pointer xyzcen
coordinate of the cell centers
Definition: mesh.f90:70
integer, save ncel
number of real cells in the mesh
Definition: mesh.f90:52
integer, save isuit1
For the 1D wall thermal module, activation (1) or not(0) of the reading of the mesh and of the wall t...
Definition: optcal.f90:174
Definition: cs_domain.h:138
Definition: cs_time_control.h:96
time step descriptor
Definition: cs_time_step.h:64
