1 #ifndef __CS_GRADIENT_H__
2 #define __CS_GRADIENT_H__
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:514
Definition: cs_defs.h:319
cs_real_t cs_real_66_t[6][6]
6x6 matrix of floating-point values
Definition: cs_defs.h:344
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:334
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:336
Definition: cs_defs.h:515
Definition: cs_defs.h:313
cs_real_t cs_real_63_t[6][3]
Definition: cs_defs.h:351
void cs_gradient_vector_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], const cs_real_t var[restrict][3], const cs_real_t c_weight[restrict], const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3][3])
Compute cell gradient of vector field.
Definition: cs_gradient.cxx:10370
void cs_gradient_type_by_imrgra(int imrgra, cs_gradient_type_t *gradient_type, cs_halo_type_t *halo_type)
Definition: cs_gradient.cxx:10881
void cs_gradient_tensor(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_6_t bc_coeff_a[], const cs_real_66_t bc_coeff_b[], cs_real_6_t *restrict var, cs_real_63_t *restrict grad)
Compute cell gradient of tensor.
Definition: cs_gradient.cxx:10162
void cs_gradient_tensor_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][6], const cs_real_t bc_coeff_b[][6][6], const cs_real_t var[restrict][6], cs_real_63_t *restrict grad)
Definition: cs_gradient.cxx:10455
cs_gradient_type_t
Definition: cs_gradient.h:56
@ CS_GRADIENT_LSQ
Definition: cs_gradient.h:59
@ CS_GRADIENT_GREEN_LSQ
Definition: cs_gradient.h:60
@ CS_GRADIENT_GREEN_R
Definition: cs_gradient.h:64
@ CS_GRADIENT_GREEN_ITER
Definition: cs_gradient.h:58
@ CS_GRADIENT_GREEN_VTX
Definition: cs_gradient.h:62
const char * cs_gradient_type_name[]
cs_gradient_limit_t
Definition: cs_gradient.h:72
@ CS_GRADIENT_LIMIT_CELL
Definition: cs_gradient.h:75
@ CS_GRADIENT_LIMIT_NONE
Definition: cs_gradient.h:74
@ CS_GRADIENT_LIMIT_FACE
Definition: cs_gradient.h:78
void cs_gradient_porosity_balance(int inc)
compute the steady balance due to porous modelling for the pressure gradient.
Definition: cs_gradient.cxx:10930
void cs_gradient_scalar_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_t f_ext[][3], const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], const cs_real_t var[restrict], const cs_real_t c_weight[restrict], const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3])
Compute cell gradient of scalar field or component of vector or tensor field.
Definition: cs_gradient.cxx:10265
void cs_gradient_vector_cell(const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], const cs_real_t var[restrict][3], const cs_real_t c_weight[], cs_real_t grad[3][3])
Compute the gradient of a vector field at a given cell using least-squares reconstruction.
Definition: cs_gradient.cxx:10803
void cs_gradient_finalize(void)
Finalize gradient computation API.
Definition: cs_gradient.cxx:9874
void cs_gradient_tensor_cell(const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[][6], const cs_real_t bc_coeff_b[][6][6], const cs_real_t var[restrict][6], const cs_real_t c_weight[], cs_real_t grad[6][3])
Compute the gradient of a tensor field at a given cell using least-squares reconstruction.
Definition: cs_gradient.cxx:10850
void cs_gradient_initialize(void)
Initialize gradient computation API.
Definition: cs_gradient.cxx:9845
void cs_gradient_free_quantities(void)
Free saved gradient quantities.
Definition: cs_gradient.cxx:9909
void cs_gradient_scalar_cell(const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], const cs_real_t var[], const cs_real_t c_weight[], cs_real_t grad[3])
Compute the gradient of a scalar field at a given cell using least-squares reconstruction.
Definition: cs_gradient.cxx:10539
void cs_gradient_vector(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], cs_real_t var[restrict][3], cs_real_t *restrict c_weight, const cs_internal_coupling_t *cpl, cs_real_t gradv[restrict][3][3])
Definition: cs_gradient.cxx:10064
void cs_gradient_scalar(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_3_t f_ext[], const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], cs_real_t var[restrict], cs_real_t *restrict c_weight, const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3])
Definition: cs_gradient.cxx:9953
cs_halo_type_t
Definition: cs_halo.h:56
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:137
Definition: cs_internal_coupling.h:63
