8.1
cs_turbulence_rij.h
1 #ifndef __CS_TURBULENCE_RIJ_H__
2 #define __CS_TURBULENCE_RIJ_H__
5  * Rij-epsilon turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
61 /*-----------------------------------------------------------------------------*/
62
63 void
64 cs_turbulence_rij(int phase_id,
65  cs_lnum_t ncesmp,
66  cs_lnum_t icetsm[],
67  int itypsm[],
68  cs_real_t smacel[]);
69
70 /*----------------------------------------------------------------------------*/
79 /*----------------------------------------------------------------------------*/
80
81 void
83  int phase_id,
84  cs_real_t c_durbin_l);
85
86 /*----------------------------------------------------------------------------*/
96 /*----------------------------------------------------------------------------*/
97
98 void
100  cs_real_t almax);
101
110 /*----------------------------------------------------------------------------*/
111
112 void
113 cs_turbulence_rij_clip(int phase_id,
114  cs_lnum_t n_cells);
115
116 /*----------------------------------------------------------------------------*/
123
124 void
125 cs_turbulence_rij_mu_t(int phase_id);
126
130 /*----------------------------------------------------------------------------*/
131
132 void
134
135 /*----------------------------------------------------------------------------*/
136
138
139 #endif /* __CS_TURBULENCE_RIJ_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
void cs_turbulence_rij_clip(int phase_id, cs_lnum_t n_cells)
Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version).
Definition: cs_turbulence_rij.c:3680
void cs_turbulence_rij(int phase_id, cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], cs_real_t smacel[])
Solve the for incompressible flows or slightly compressible flows for one time step.
Definition: cs_turbulence_rij.c:2605
void cs_turbulence_rij_mu_t(int phase_id)
Compute the turbulent viscosity for the Reynolds Stress model.
Definition: cs_turbulence_rij.c:3921
void cs_turbulence_rij_init_by_ref_quantities(cs_real_t uref, cs_real_t almax)
Initialize Rij-epsilon variables based on reference quantities.
Definition: cs_turbulence_rij.c:3617
void cs_turbulence_rij_compute_rusanov(void)
Compute Rusanov equivalent diffusivity of the model.
Definition: cs_turbulence_rij.c:4026
void cs_turbulence_rij_solve_alpha(int f_id, int phase_id, cs_real_t c_durbin_l)
Solve the equation on alpha in the framework of the Rij-EBRSM model.
Definition: cs_turbulence_rij.c:3356
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:191
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:185
real(c_double), pointer, save almax
is a characteristic macroscopic length of the domain, used for the initialization of the turbulence a...
Definition: cstphy.f90:344
real(c_double), pointer, save uref
the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not ...
Definition: cstphy.f90:353
