Collaboration diagram for Module for turbulence constants:Variables | |
| double precision, save | xkappa = 0.42d0 |
| real(c_double), pointer, save | ypluli |
| limit value of | |
| real(c_double), pointer, save | cmu |
| constant | |
| real(c_double), pointer, save | csrij |
| Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment. More... | |
| double precision, save | xcl = 0.122d0 |
| constant of the Rij-epsilon EBRSM More... | |
| double precision, save | xa1 = 0.1d0 |
| constant in the expression of Ce1' for the Rij-epsilon EBRSM More... | |
| double precision, save | xct = 6.d0 |
| real(c_double), pointer, save | almax |
| is a characteristic macroscopic length of the domain, used for the initialization of the turbulence and the potential clipping (with iclkep=1) More... | |
| real(c_double), pointer, save | uref |
| the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not initialized. More... | |
| real(c_double), pointer, save | xlesfl |
| constant used in the definition of LES filtering diameter: Useful if and only if iturb = 40 or 41 More... | |
| real(c_double), pointer, save | ales |
| constant used to define, for each cell | |
| real(c_double), pointer, save | bles |
| real(c_double), pointer, save | csmago |
| Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by | |
| real(c_double), pointer, save | xlesfd |
| ratio between explicit and explicit filter width for a dynamic model constant used to define, for each cell | |
| real(c_double), pointer, save | cdries |
| van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant: More... | |
| double precision, save | volmin |
| minimal control volume More... | |
| double precision, save | volmax |
| maximal control volume More... | |
| double precision, save | voltot |
| total domain volume More... | |
| real(c_double), pointer, save | xclt |
| constant of EB-AFM and EB-DFM More... | |
| real(c_double), pointer, save ales |
, the width of the (implicit) filter:
Useful if and only if iturb = 40 or 41.
| real(c_double), pointer, save almax |
Useful if and only if iturb = 20, 21, 30, 31, 50 or 60 (RANS models)
| real(c_double), pointer, save bles |
| real(c_double), pointer, save cdries |
| real(c_double), pointer, save cmu |
constant
for all the RANS turbulence models Warning, different values for the v2f model Useful if and only if iturb = 20, 21, 30, 31, 50, 51 or 60 (
or
| real(c_double), pointer, save csmago |
where
is the width of the filter and
the filtered strain rate.
| real(c_double), pointer, save csrij |
constant
for the
models.
| real(c_double), pointer, save uref |
Useful if and only if iturb = 20, 21, 30, 31, 50 or 60 (RANS model) and the turbulence is not initialized somewhere else (restart file or subroutine cs_user_initialization)
| double precision, save volmax |
| double precision, save volmin |
| double precision, save voltot |
total domain volume
| double precision, save xa1 = 0.1d0 |
| double precision, save xcl = 0.122d0 |
| real(c_double), pointer, save xclt |
| double precision, save xct = 6.d0 |
| double precision, save xkappa = 0.42d0 |
Karman constant. (= 0.42) Useful if and only if iturb >= 10. (mixing length,
, LES, v2f or
| real(c_double), pointer, save xlesfd |
, the width of the explicit filter used in the framework of the LES dynamic model:
Useful if and only if iturb = 41
| real(c_double), pointer, save xlesfl |
