8.0
cs_vof.c File Reference
#include "cs_blas.h"
#include "cs_boundary_conditions.h"
#include "cs_equation.h"
#include "cs_face_viscosity.h"
#include "cs_divergence.h"
#include "cs_field_default.h"
#include "cs_field_pointer.h"
#include "cs_math.h"
#include "cs_rotation.h"
#include "cs_sles_default.h"
#include "cs_vof.h"
+ Include dependency graph for cs_vof.c:
cs_vof_parameters_tcs_get_glob_vof_parameters (void)
static void _smoothe (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, cs_real_t *restrict coefa, cs_real_t *restrict coefb, cs_real_t *restrict pvar)
 Smoothing a variable after several double-projections cells->faces->cells. More...
void cs_vof_compute_linear_rho_mu (const cs_mesh_t *m)
 Compute the mixture density, mixture dynamic viscosity given fluid volume fractions and the reference density and dynamic viscosity $ \rho_l, \mu_l $ (liquid), $ \rho_v, \mu_v $ (gas). More...
void cs_vof_update_phys_prop (const cs_mesh_t *m)
 Compute the mixture density, mixture dynamic viscosity and mixture mass flux given the volumetric flux, the volume fraction and the reference density and dynamic viscosity $ \rho_l, \mu_l $ (liquid), $ \rho_v, \mu_v $ (gas). More...
void cs_vof_log_mass_budget (const cs_mesh_t *m, const cs_mesh_quantities_t *mq)
 Write in main log the global mixture mass budget: More...
void cs_vof_surface_tension (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, cs_real_3_t stf[])
 Compute the surface tension momentum source term following the CSF model of Brackbill et al. (1992). More...
void cs_vof_deshpande_drift_flux (const cs_mesh_t *m, const cs_mesh_quantities_t *mq)
 Compute a relative velocity $ \vect u _d $ directly at internal faces (drift flux), following the approach described by Suraj S. Deshpande et al 2012 Comput. Sci. Disc. 5 014016. It is activated with the option idrift = 1. More...
void cs_vof_drift_term (int imrgra, int nswrgp, int imligp, int iwarnp, cs_real_t epsrgp, cs_real_t climgp, cs_real_t *restrict pvar, const cs_real_t *restrict pvara, cs_real_t *restrict rhs)
 Add the divergence of the drift velocity term in the volume fraction equation. More...
cs_cavitation_parameters_tcs_get_glob_cavitation_parameters (void)
VOF model data.
◆ _smoothe()
static void _smoothe ( const cs_mesh_t m,
const cs_mesh_quantities_t mq,
static
[in]mpointer to mesh structure
[in]mqpointer to mesh quantities structure
[in]coefaboundary condition array for the variable
[in]coefbboundary condition array for the variable
[in,out]pvardiffused variable
◆ cs_get_glob_cavitation_parameters()
cs_cavitation_parameters_t* cs_get_glob_cavitation_parameters ( void  )
◆ cs_get_glob_vof_parameters()
cs_vof_parameters_t* cs_get_glob_vof_parameters ( void  )
◆ cs_vof_compute_linear_rho_mu()
void cs_vof_compute_linear_rho_mu ( const cs_mesh_t m)
Computation is done as follows on cells:
\[ \rho_\celli = \alpha_\celli \rho_v + (1-\alpha_\celli) \rho_l, \]
\[ \mu_\celli = \alpha_\celli \mu_v + (1-\alpha_\celli) \mu_l, \]
A similar linear formula is followed on boundary using fluid volume fraction value on the boundary.
◆ cs_vof_deshpande_drift_flux()
void cs_vof_deshpande_drift_flux ( const cs_mesh_t m,
Compute the flux of the drift velocity $ \vect u _d $, by using the flux of the standard velocity $ \vect u $ following the approach described by Suraj S Deshpande et al 2012 Comput. Sci. Disc. 5 014016. It is activated with the option idrift = 1.
Using the notation:
\[ \begin{cases} \left ( \vect u ^{n+1} . \vect S \right ) _{\face} = \Dot{m}_{\face}\\ \left ( \vect u _d^{n+1} . \vect S \right ) _{\face} = \Dot{m^d}_{\face} \end{cases} \]
The drift flux is computed as:
\[ \Dot{m^d}_{\face} = min \left ( C_{\gamma} \dfrac{\Dot{m}_{\face}} {\vect S_{\face}}, \underset{\face'}{max} \left [ \dfrac{\Dot{m}_{\face'}} {\vect S_{\face'}} \right ] \right ) \left ( \vect n \cdot \vect S \right ) _{\face} \]
Where $ C_{\gamma} $ is the drift flux factor defined with the variable cdrift, $ \vect n _{\face} $ the normal vector to the interface. The gradient is computed using a centered scheme:
\[ \vect {n} _{\face} = \dfrac{\left ( \grad \alpha \right ) _{\face}} {\norm {\left ( \grad \alpha \right ) _{\face} + \delta}}, \text{ with: } \left ( \grad \alpha \right ) _{\face _{\celli \cellj}} = \dfrac{\left ( \grad \alpha \right ) _\celli + \left ( \grad \alpha \right ) _\cellj}{2}, \text{ and: } \delta = 10^{-8} / \overline{\vol \celli} ^{1/3} \]
◆ cs_vof_drift_term()
void cs_vof_drift_term ( int  imrgra,
int  nswrgp,
int  imligp,
int  iwarnp,
cs_real_t  epsrgp,
cs_real_t  climgp,
Add the explicit part of the convection/diffusion terms of a standard transport equation of a scalar field $ \varia $.
More precisely, the right hand side $ Rhs $ is updated as follows:
\[ Rhs = Rhs - \sum_{\fij \in \Facei{\celli}} \left( \alpha_\celli^{n+1} \left( 1 - \alpha_\cellj^{n+1} \right) \left( \dot{m}_\fij^{d} \right)^{+} + \alpha_\cellj^{n+1} \left( 1 - \alpha_\celli^{n+1} \right) \left( \dot{m}_\fij^{d} \right)^{-} \right) \]
[in]imrgraindicator
  • 0 iterative gradient
  • 1 least squares gradient
[in]nswrgpnumber of reconstruction sweeps for the gradients
[in]imligpclipping gradient method
  • < 0 no clipping
  • = 0 by neighboring gradients
  • = 1 by the mean gradient
[in]iwarnpverbosity
[in]epsrgprelative precision for the gradient reconstruction
[in]climgpclipping coefficient for the computation of the gradient
[in]pvarsolved variable (current time step)
[in]pvarasolved variable (previous time step)
[in,out]rhsright hand side $ \vect{Rhs} $
◆ cs_vof_log_mass_budget()
void cs_vof_log_mass_budget ( const cs_mesh_t m,
\[ \sum_\celli\left( |\Omega_\celli|\dfrac{\rho_\celli^n - \rho_\celli^{n-1}}{\Delta t} + \sum_{\cellj\in\Face{\celli}}\left(\rho\vect{u}\vect{S}\right)_{\ij}^n \right). \]
◆ cs_vof_surface_tension()
void cs_vof_surface_tension ( const cs_mesh_t m,
cs_real_3_t  stf[]
[out]stfsurface tension momentum source term
◆ cs_vof_update_phys_prop()
void cs_vof_update_phys_prop ( const cs_mesh_t m)
For the computation of mixture density, mixture dynamic viscosity, see cs_vof_compute_linear_rho_mu.
Computation of mass flux is as follows:
\[ \left( \rho\vect{u}\cdot\vect{S} \right)_\ij = \\ \left\lbrace \begin{array}{ll} \rho_\celli (\vect{u}\cdot\vect{S})_\ij &\text{ if } (\vect{u}\cdot\vect{S})_\ij>0, \\ \rho_\cellj (\vect{u}\cdot\vect{S})_\ij &\text{ otherwise }, \end{array} \right. \]
\[ \left( \rho\vect{u}\cdot\vect{S} \right)_\ib = \\ \left\lbrace \begin{array}{ll} \rho_\celli (\vect{u}\cdot\vect{S})_\ib &\text{ if } (\vect{u}\cdot\vect{S})_\ib>0, \\ \rho_b (\vect{u}\cdot\vect{S})_\ib &\text{ otherwise }. \end{array} \right. \]
