59 #define CS_VOF_ENABLED (1 << 0)
62 #define CS_VOF_FREE_SURFACE (1 << 1)
65 #define CS_VOF_MERKLE_MASS_TRANSFER (1 << 2)
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
cs_cavitation_parameters_t * cs_get_glob_cavitation_parameters(void)
Definition: cs_vof.c:1436
cs_vof_parameters_t * cs_get_glob_vof_parameters(void)
Definition: cs_vof.c:424
void cs_vof_deshpande_drift_flux(const cs_mesh_t *m, const cs_mesh_quantities_t *mq)
Compute the flux of the drift velocity , by using the flux of the standard velocity following the ap...
Definition: cs_vof.c:1140
void cs_vof_surface_tension(const cs_mesh_t *m, const cs_mesh_quantities_t *mq, cs_real_3_t stf[])
Compute the surface tension momentum source term following the CSF model of Brackbill et al....
Definition: cs_vof.c:938
void cs_vof_compute_linear_rho_mu(const cs_mesh_t *m)
Compute the mixture density, mixture dynamic viscosity given fluid volume fractions and the reference...
Definition: cs_vof.c:651
void cs_vof_drift_term(int imrgra, int nswrgp, int imligp, int iwarnp, cs_real_t epsrgp, cs_real_t climgp, cs_real_t *restrict pvar, const cs_real_t *restrict pvara, cs_real_t *restrict rhs)
Add the explicit part of the convection/diffusion terms of a standard transport equation of a scalar ...
Definition: cs_vof.c:1247
const cs_vof_parameters_t * cs_glob_vof_parameters
void cs_vof_log_mass_budget(const cs_mesh_t *m, const cs_mesh_quantities_t *mq)
Write in main log the global mixture mass budget:
Definition: cs_vof.c:788
void cs_vof_update_phys_prop(const cs_mesh_t *m)
Compute the mixture density, mixture dynamic viscosity and mixture mass flux given the volumetric flu...
Definition: cs_vof.c:730
int itscvi
Definition: cs_vof.h:114
cs_real_t cprod
Definition: cs_vof.h:111
cs_real_t presat
Definition: cs_vof.h:107
cs_real_t uinf
Definition: cs_vof.h:108
cs_real_t cdest
Definition: cs_vof.h:110
cs_real_t linf
Definition: cs_vof.h:109
cs_real_t mcav
Definition: cs_vof.h:113
int icvevm
Definition: cs_vof.h:112
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:137
double cdrift
Definition: cs_vof.h:96
double sigmaS
Definition: cs_vof.h:92
double rho2
Definition: cs_vof.h:86
unsigned vof_model
Definition: cs_vof.h:81
double mu2
Definition: cs_vof.h:90
double mu1
Definition: cs_vof.h:88
int idrift
Definition: cs_vof.h:94
double kdrift
Definition: cs_vof.h:98
double rho1
Definition: cs_vof.h:84
Cavitation model parameters.
Definition: cs_vof.h:105
VOF model parameters. Void fraction variable tracks fluid 2.
Definition: cs_vof.h:79
