Collaboration diagram for Mixture properties:Data Types | |
| struct | cs_vof_parameters_t |
| VOF model parameters. Void fraction variable tracks fluid 2. More... | |
| real(c_double), pointer, save | rho1 |
| reference density of fluid 1 (kg/m3). By convention, liquid phase for cavitation model. More... | |
| real(c_double), pointer, save | rho2 |
| reference density of fluid 2 (kg/m3). By convention, gas phase for cavitation model. More... | |
| real(c_double), pointer, save | mu1 |
| reference molecular viscosity of fluid 1 (kg/(m s)) More... | |
| real(c_double), pointer, save | mu2 |
| reference molecular viscosity of fluid 2 (kg/(m s)) More... | |
| real(c_double), pointer, save | sigmas |
| surface tension (N/m) More... | |
| real(c_double), pointer, save | cdrift |
| Drift flux factor. More... | |
| real(c_double), pointer, save | kdrift |
| volume fraction gradient factor in drift velocity More... | |
| unsigned | vof_model |
| double | rho1 |
| double | rho2 |
| double | mu1 |
| double | mu2 |
| double | sigmaS |
| int | idrift |
| double | cdrift |
| double | kdrift |
| cdrift |
Flux factor parameter. In case of drift flux, factor of the local flux compared to the global max flux.
| real(c_double), pointer, save cdrift |
Drift flux factor.
| idrift |
drift velocity model
| kdrift |
Turbulent like diffusion effect (m2/s). In case of drift velocity, factor of a volume fraction gradient
| real(c_double), pointer, save kdrift |
| mu1 |
| real(c_double), pointer, save mu1 |
| mu2 |
| real(c_double), pointer, save mu2 |
| rho1 |
| real(c_double), pointer, save rho1 |
| rho2 |
| real(c_double), pointer, save rho2 |
| sigmaS |
reference surface tension (N/m)
| real(c_double), pointer, save sigmas |
| vof_model |
Volume of Fluid model - sum of masks defining VoF model and submodels. See defined masks in Masks used to specify Volume of Fluid models.
