#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdarg.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_at_opt_interp.h"#include "cs_convection_diffusion.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_gradient.h"#include "cs_log.h"#include "cs_map.h"#include "cs_mesh_location.h"#include "cs_post.h"#include "cs_parall.h"#include "cs_physical_model.h"#include "cs_restart.h"#include "cs_restart_default.h"#include "cs_time_moment.h"#include "cs_tree.h"#include "cs_parameters.h"
Include dependency graph for cs_parameters.c:Functions | |
| cs_space_disc_t * | cs_get_glob_space_disc (void) |
| Provide access to cs_glob_space_disc. More... | |
| cs_time_scheme_t * | cs_get_glob_time_scheme (void) |
| Provide access to cs_glob_time_scheme. More... | |
| void | cs_parameters_define_field_keys (void) |
| Define general field keys. More... | |
| void | cs_parameters_read_restart_info (void) |
| Read general restart info. More... | |
| void | cs_parameters_add_variable (const char *name, int dim) |
| Define a user variable. More... | |
| void | cs_parameters_add_variable_variance (const char *name, const char *variable_name) |
| Define a user variable which is a variance of another variable. More... | |
| void | cs_parameters_add_property (const char *name, int dim, int location_id) |
| Define a user property. More... | |
| int | cs_parameters_n_added_variables (void) |
| Return the number of defined user variables not added yet. More... | |
| int | cs_parameters_n_added_properties (void) |
| Return the number of defined user properties not added yet. More... | |
| void | cs_parameters_create_added_variables (void) |
| Create previously added user variables. More... | |
| void | cs_parameters_create_added_properties (void) |
| Create previously added user properties. More... | |
| cs_field_t * | cs_parameters_add_boundary_values (cs_field_t *f) |
| Define a boundary values field for a variable field. More... | |
| cs_field_t * | cs_parameters_add_boundary_temperature (void) |
| Define a boundary values field for temperature, if applicable. More... | |
| bool | cs_parameters_need_extended_neighborhood (void) |
| Check if extended neighborhood is needed. More... | |
| void | cs_parameters_eqp_complete (void) |
| Complete general equation parameter definitions. More... | |
| void | cs_parameters_output_complete (void) |
| Complete general output option definitions. More... | |
| cs_var_cal_opt_t | cs_parameters_var_cal_opt_default (void) |
| Return a local variable calculation options structure, with default options. More... | |
| void | cs_time_scheme_log_setup (void) |
| Print the time scheme structure to setup.log. More... | |
| void | cs_space_disc_log_setup (void) |
| Print the space discretization structure to setup.log. More... | |
General parameters and options management.
| cs_space_disc_t* cs_get_glob_space_disc | ( | void | ) |
| cs_time_scheme_t* cs_get_glob_time_scheme | ( | void | ) |
| cs_field_t* cs_parameters_add_boundary_temperature | ( | void | ) |
| cs_field_t* cs_parameters_add_boundary_values | ( | cs_field_t * | f | ) |
| void cs_parameters_add_property | ( | const char * | name, |
| int | dim, | ||
| int | location_id | ||
| [in] | name | name of property and associated field |
| void cs_parameters_add_variable | ( | const char * | name, |
| int | dim | ||
| [in] | name | name of variable and associated field |
| [in] | dim | variable dimension |
| void cs_parameters_add_variable_variance | ( | const char * | name, |
| const char * | variable_name | ||
| [in] | name | name of variance and associated field |
| [in] | variable_name | name of associated variable |
| void cs_parameters_create_added_properties | ( | void | ) |
| void cs_parameters_create_added_variables | ( | void | ) |
| void cs_parameters_define_field_keys | ( | void | ) |
| void cs_parameters_eqp_complete | ( | void | ) |
| int cs_parameters_n_added_properties | ( | void | ) |
| int cs_parameters_n_added_variables | ( | void | ) |
| bool cs_parameters_need_extended_neighborhood | ( | void | ) |
| void cs_parameters_output_complete | ( | void | ) |
Complete general output options definitions.
| void cs_parameters_read_restart_info | ( | void | ) |
This updates the previous time step info.
| cs_var_cal_opt_t cs_parameters_var_cal_opt_default | ( | void | ) |
| void cs_space_disc_log_setup | ( | void | ) |
| void cs_time_scheme_log_setup | ( | void | ) |
