7.3
cs_parameters.h
1 #ifndef __CS_PARAMETERS_H__
2 #define __CS_PARAMETERS_H__
5  * General parameters management.
34 #include <stdarg.h>
37  * Local headers
40 #include "cs_defs.h"
41 #include "cs_equation_param.h"
42 #include "cs_field.h"
43 #include "cs_tree.h"
45 /*----------------------------------------------------------------------------*/
46
48
49 /*=============================================================================
50  * Macro definitions
52
54  * Type definitions
56
58  * Structure of variable calculation options
59  * (now an alias of cs_equation_param_t)
60  *----------------------------------------------------------------------------*/
61
63
64 /*----------------------------------------------------------------------------
65  * Structure of the solving info
66  *----------------------------------------------------------------------------*/
67
68 typedef struct {
69  int n_it;
70  double rhs_norm;
71  double res_norm;
72  double derive;
73  double l2residual;
75
76 /*----------------------------------------------------------------------------
77  * Boundary condition types
78  *----------------------------------------------------------------------------*/
79
80 enum {
81
82  CS_INDEF = 1,
83  CS_INLET = 2,
84  CS_OUTLET = 3,
86
90  CS_ESICF = 7,
92  CS_SSPCF = 8,
93  CS_SOPCF = 9,
94  CS_EPHCF = 10,
96  CS_EQHCF = 11,
98  CS_COUPLED = 12,
106 };
107
108 /*----------------------------------------------------------------------------
109  * flag for computing the drift mass flux:
110  * (for coal classes for instance, only the first
111  * scalar of a class compute the drift flux of the class
112  * and the other scalars use it without recomputing it)
113  *----------------------------------------------------------------------------*/
114
115 enum {
116  CS_DRIFT_SCALAR_ON = (1 << 0),
125 };
126
127 /*----------------------------------------------------------------------------
128  * Space discretisation options descriptor
129  *----------------------------------------------------------------------------*/
130
131 typedef struct {
132
133  int imvisf; /* face viscosity field interpolation
134  - 1: harmonic
135  - 0: arithmetic (default) */
136
137  int imrgra; /* type of gradient reconstruction
138  - 0: iterative process
139  - 1: standard least square method
140  - 2: least square method with extended
141  neighborhood
142  - 3: least square method with reduced extended
143  neighborhood
144  - 4: Green-Gauss using least squares face
145  values interpolation */
146
147  int iflxmw; /* method to compute interior mass flux due to ALE
148  mesh velocity
149  - 1: based on cell center mesh velocity
150  - 0: based on nodes displacement */
151
152  int itbrrb; /* accurate treatment of the wall temperature
153  - 1: true
154  - 0: false (default) */
155
157
158 /*----------------------------------------------------------------------------
159  * Time scheme descriptor
160  *----------------------------------------------------------------------------*/
161
162 typedef struct {
163
164  int time_order; /* Global time order of the time stepping */
165
166  int isto2t; /* time scheme activated for the source
167  terms of turbulent equations */
168
169  double thetst; /* value of \f$theta\f$ for turbulence */
170
171  int iccvfg; /* calculation with a fixed velocity field
172  - 1: true (default)
173  - 0: false */
175
176 /*----------------------------------------------------------------------------
177  * Auxiliary checkpoint/restart file parameters
178  *----------------------------------------------------------------------------*/
179
180 typedef struct {
181
182  int read_auxiliary; /* Activate reading of auxiliary restart file */
183  int write_auxiliary; /* Activate output of auxiliary restart file */
184
186
187 /*============================================================================
188  * Static global variables
189  *============================================================================*/
190
191 /* Pointer to space discretisation options structure */
192
193 extern const cs_space_disc_t *cs_glob_space_disc;
194
195 /* Pointer to time scheme options structure */
196
198
199 /* Pointer to auxiliary checkpoint/restart file parameters */
200
202
203 /*============================================================================
204  * Global variables
205  *============================================================================*/
206
209 extern cs_tree_node_t *cs_glob_tree;
210
211 /*=============================================================================
212  * Public function prototypes
213  *============================================================================*/
214
226 /*----------------------------------------------------------------------------*/
227
228 static inline int
230 {
231  int iscvr = 0, f_id = 0;
232  int kscavr = cs_field_key_id("first_moment_id");
233  int keysca = cs_field_key_id("scalar_id");
234
235  if (kscavr >= 0) {
236  f_id = cs_field_get_key_int(f, kscavr);
237  if (f_id >= 0)
238  iscvr = cs_field_get_key_int(cs_field_by_id(f_id), keysca);
239  }
240
241  return iscvr;
242 }
243
244 /*----------------------------------------------------------------------------*/
253
256
257 /*----------------------------------------------------------------------------*/
265 /*----------------------------------------------------------------------------*/
266
269
270 /*----------------------------------------------------------------------------*/
277 /*----------------------------------------------------------------------------*/
278
279 void
281
282 /*----------------------------------------------------------------------------*/
288 /*----------------------------------------------------------------------------*/
289
290 void
292
293 /*----------------------------------------------------------------------------*/
302 /*----------------------------------------------------------------------------*/
303
304 void
305 cs_parameters_add_variable(const char *name,
306  int dim);
307
308 /*----------------------------------------------------------------------------*/
317 /*----------------------------------------------------------------------------*/
318
319 void
320 cs_parameters_add_variable_variance(const char *name,
321  const char *variable_name);
322
323 /*----------------------------------------------------------------------------*/
331 /*----------------------------------------------------------------------------*/
332
333 void
334 cs_parameters_add_property(const char *name,
335  int dim,
336  int location_id);
337
338 /*----------------------------------------------------------------------------*/
347 /*----------------------------------------------------------------------------*/
348
349 int
351
352 /*----------------------------------------------------------------------------*/
361 /*----------------------------------------------------------------------------*/
362
363 int
365
366 /*----------------------------------------------------------------------------*/
370 /*----------------------------------------------------------------------------*/
371
372 void
374
375 /*----------------------------------------------------------------------------*/
379 /*----------------------------------------------------------------------------*/
380
381 void
383
384 /*----------------------------------------------------------------------------*/
392 /*----------------------------------------------------------------------------*/
393
394 cs_field_t *
396
397 /*----------------------------------------------------------------------------*/
408 /*----------------------------------------------------------------------------*/
409
410 cs_field_t *
412
413 /*----------------------------------------------------------------------------*/
419 /*----------------------------------------------------------------------------*/
420
421 bool
423
424 /*----------------------------------------------------------------------------*/
428 /*----------------------------------------------------------------------------*/
429
430 void
432
433 /*----------------------------------------------------------------------------*/
437 /*----------------------------------------------------------------------------*/
438
439 void
441
442 /*----------------------------------------------------------------------------*/
449 /*----------------------------------------------------------------------------*/
450
453
454 /*----------------------------------------------------------------------------*/
458 /*----------------------------------------------------------------------------*/
459
460 void
462
463 /*----------------------------------------------------------------------------*/
467 /*----------------------------------------------------------------------------*/
468
469 void
471
472 /*----------------------------------------------------------------------------*/
473
475
476 #endif /* __CS_PARAMETERS_H__ */
Definition: cs_parameters.h:116
void cs_parameters_eqp_complete(void)
Complete general equation parameter definitions.
Definition: cs_parameters.c:1563
Definition: cs_parameters.h:90
cs_field_t * cs_parameters_add_boundary_values(cs_field_t *f)
Define a boundary values field for a variable field.
Definition: cs_parameters.c:1321
Definition: cs_parameters.h:123
Definition: cs_parameters.h:68
Definition: cs_parameters.h:117
int read_auxiliary
Definition: cs_parameters.h:182
double thetst
Definition: cs_parameters.h:169
int imrgra
Definition: cs_parameters.h:137
const cs_space_disc_t * cs_glob_space_disc
Definition: cs_parameters.h:121
Definition: cs_parameters.h:85
void cs_parameters_create_added_variables(void)
Create previously added user variables.
Definition: cs_parameters.c:1196
Definition: cs_parameters.h:124
int iflxmw
Definition: cs_parameters.h:147
Definition: cs_field.h:130
Definition: cs_parameters.h:103
Definition: cs_field.c:2310
cs_time_scheme_t * cs_get_glob_time_scheme(void)
Provide access to cs_glob_time_scheme.
Definition: cs_parameters.c:866
void cs_parameters_add_variable(const char *name, int dim)
Definition: cs_parameters.c:1057
void cs_parameters_read_restart_info(void)
Read general restart info.
Definition: cs_parameters.c:1035
Definition: cs_defs.h:512
void cs_space_disc_log_setup(void)
Print the space discretization structure to setup.log.
Definition: cs_parameters.c:1678
cs_tree_node_t * cs_glob_tree
Definition: cs_parameters.h:120
void cs_parameters_add_variable_variance(const char *name, const char *variable_name)
Define a user variable which is a variance of another variable.
Definition: cs_parameters.c:1098
bool cs_parameters_need_extended_neighborhood(void)
Check if extended neighborhood is needed.
Definition: cs_parameters.c:1511
cs_restart_auxiliary_t * cs_glob_restart_auxiliary
Definition: cs_parameters.h:88
void cs_parameters_add_property(const char *name, int dim, int location_id)
Define a user property.
Definition: cs_parameters.c:1135
Additional checkpoint/restart files.
Definition: cs_parameters.h:180
Definition: cs_parameters.h:102
int time_order
Definition: cs_parameters.h:164
cs_space_disc_t * cs_get_glob_space_disc(void)
Provide access to cs_glob_space_disc.
Definition: cs_parameters.c:850
Definition: cs_parameters.h:119
void cs_parameters_create_added_properties(void)
Create previously added user properties.
Definition: cs_parameters.c:1271
Definition: cs_field.c:3058
Definition: cs_parameters.h:82
Definition: cs_field.c:2564
Definition: cs_parameters.h:83
int iccvfg
Definition: cs_parameters.h:171
int itbrrb
Definition: cs_parameters.h:152
Definition: cs_parameters.h:100
Definition: cs_parameters.h:122
int cs_parameters_n_added_variables(void)
Return the number of defined user variables not added yet.
Definition: cs_parameters.c:1170
Time scheme descriptor.
Definition: cs_parameters.h:162
Definition: cs_parameters.h:87
int n_it
Definition: cs_parameters.h:69
cs_equation_param_t cs_var_cal_opt_t
Definition: cs_parameters.h:62
const cs_time_scheme_t * cs_glob_time_scheme
double l2residual
Definition: cs_parameters.h:73
Definition: cs_parameters.h:118
void cs_time_scheme_log_setup(void)
Print the time scheme structure to setup.log.
Definition: cs_parameters.c:1652
static int cs_parameters_iscavr(cs_field_t *f)
For a given field, returns the scalar number of the fluctuating field if given field is a variance...
Definition: cs_parameters.h:229
Definition: cs_parameters.h:92
Definition: cs_defs.h:513
Space discretisation options descriptor.
Definition: cs_parameters.h:131
Definition: cs_parameters.h:99
int cs_parameters_n_added_properties(void)
Return the number of defined user properties not added yet.
Definition: cs_parameters.c:1184
int isto2t
Definition: cs_parameters.h:166
Definition: cs_parameters.h:93
Definition: cs_parameters.h:94
double rhs_norm
Definition: cs_parameters.h:70
void cs_parameters_define_field_keys(void)
Define general field keys.
Definition: cs_parameters.c:881
Definition: cs_parameters.h:96
int write_auxiliary
Definition: cs_parameters.h:183
Definition: cs_parameters.h:98
Definition: cs_parameters.h:84
int imvisf
Definition: cs_parameters.h:133
double derive
Definition: cs_parameters.h:72
cs_var_cal_opt_t cs_parameters_var_cal_opt_default(void)
Return a local variable calculation options structure, with default options.
Definition: cs_parameters.c:1640
void cs_parameters_output_complete(void)
Complete general output options definitions.
Definition: cs_parameters.c:1590
cs_field_t * cs_parameters_add_boundary_temperature(void)
Define a boundary values field for temperature, if applicable.
Definition: cs_parameters.c:1426
double res_norm
Definition: cs_parameters.h:71
