Time scheme descriptor. More...
#include <cs_parameters.h>
Collaboration diagram for cs_time_scheme_t:Data Fields | |
| int | time_order |
| int | isto2t |
| double | thetst |
| int | iccvfg |
Members of the time scheme structure are publicly accessible, to allow for concise syntax, as they are expected to be used in many places.
| iccvfg |
indicates whether the dynamic field should be frozen or not:
, turbulent viscosity) are kept constant over time and only the equations for the scalars are solved.
0 and the calculation is a restart. | isto2t |
Specifies the time scheme activated for the source terms of the turbulence equations i.e. related to
), apart from convection and diffusion.
which are linear functions of the solved variable
are expressed as second-order terms by interpolation (according to the formula
being given by the value of thetav associated with the variable
); the other terms
are expressed as second-order terms by extrapolation (according to the formula
being given by the value of thetst = 0.5)
are treated in the same isto2t = 1; the other terms
are way as when extrapolated according to the same formula as when isto2t = 1, but with
= thetst = 1.
models (iturb = 30 or 31); hence, it is always initialised to 0. | thetst |
-scheme for the extrapolation of the nonlinear explicit source terms $S_e$ of the turbulence equations when the source term extrapolation has been activated (see isto2t), following the formula
The value of
is deduced from the value chosen for isto2t. Generally, only the value 0.5 is used.
| time_order |
Global time order of time stepping
