Collaboration diagram for Stokes options:Variables | |
| integer(c_int), pointer, save | ivisse |
Indicates whether the source terms in transposed gradient and velocity divergence should be taken into account in the momentum equation. In the compressible module, these terms also account for the volume viscosity (cf. viscv0 and iviscv) : More... | |
| integer(c_int), pointer, save | irevmc |
| Reconstruction of the velocity field with the updated pressure option. More... | |
| integer(c_int), pointer, save | iprco |
| Compute the pressure step thanks to the continuity equation. More... | |
| real(c_double), pointer, save | arak |
| Arakawa multiplicator for the Rhie and Chow filter (1 by default) More... | |
| integer(c_int), pointer, save | rcfact |
| Factor of the Rhie and Chow filter: More... | |
| integer(c_int), pointer, save | staggered |
| 1D staggered scheme option: More... | |
| integer(c_int), pointer, save | ipucou |
| indicates the algorithm for velocity-pressure coupling: More... | |
| integer(c_int), pointer, save | iccvfg |
| integer(c_int), pointer, save | idilat |
| Algorithm to take into account the density variation in time. More... | |
| integer, save | ipredfl |
| Option to switch on massflux prediction befor momentum solving to be fully conservative in momentum over time for variable density flows. This option is to be removed. More... | |
| real(c_double), pointer, save | epsdp |
| parameter of diagonal pressure strengthening More... | |
| integer, dimension(ntypmx), save | idebty |
| integer, dimension(ntypmx), save | ifinty |
| integer(c_int), pointer, save | itbrrb |
| accurate treatment of the wall temperature More... | |
| integer(c_int), pointer, save | iphydr |
| improve static pressure algorithm More... | |
| integer(c_int), pointer, save | igprij |
| integer(c_int), pointer, save | igpust |
| integer(c_int), pointer, save | iifren |
| indicates the presence of a Bernoulli boundary face (automatically computed) More... | |
| integer, save | ifrslb |
| number of the closest free standard outlet (or free inlet) face to xyzp0 More... | |
| integer, save | itbslb |
| max of ifrslb on all ranks, standard outlet face presence indicator More... | |
| integer(c_int), pointer, save | icalhy |
| compute the hydrostatic pressure in order to compute the Dirichlet conditions on the pressure at outlets More... | |
| integer(c_int), pointer, save | irecmf |
| use interpolated face diffusion coefficient instead of cell diffusion coefficient for the mass flux reconstruction for the non-orthogonalities More... | |
| logical(c_bool), pointer, save | fluid_solid |
| Has a solid zone where dynamics must be killed? More... | |
| integer, save | itagms |
| choice the way to compute the wall temperature at the solid/fluid interface coupled with condensation to the metal mass structures wall More... | |
| integer, dimension(nestmx), save | iescal |
| iescal indicates the calculation mode for the error estimator iespre, iesder, iescor or iestot for the Navier-Stokes equation: More... | |
| integer(c_int), pointer, save | n_buoyant_scal |
| n_buoyant_scal is the number of buoyant scalar It will be zero if there is no buoyant scalar More... | |
| integer(c_int), pointer, save | iprcdo |
| Dicretization method for pressure. More... | |
| real(c_double), pointer, save arak |
| real(c_double), pointer, save epsdp |
| logical(c_bool), pointer, save fluid_solid |
| integer(c_int), pointer, save icalhy |
| integer(c_int), pointer, save iccvfg |
indicates whether the dynamic field should be frozen or not:
, turbulent viscosity) are kept constant over time and only the equations for the scalars are solved.
0 and the calculation is a restart. | integer, dimension(ntypmx), save idebty |
| integer(c_int), pointer, save idilat |
| integer, dimension(nestmx), save iescal |
is calculated, without contribution of the volume,
is calculated, with contribution of the volume (norm
), except for iescor, for which
is calculated. The names of the estimators appearing in the log and the post-processing are made up of the default name (given before), followed by the value of iescal}. For instance, EsPre2 is the estimator iespre calculated with iescal = 2. | integer, dimension(ntypmx), save ifinty |
| integer, save ifrslb |
| integer(c_int), pointer, save igprij |
| integer(c_int), pointer, save igpust |
| integer(c_int), pointer, save iifren |
| integer(c_int), pointer, save iphydr |
| integer(c_int), pointer, save iprcdo |
| integer(c_int), pointer, save iprco |
| integer, save ipredfl |
| integer(c_int), pointer, save ipucou |
| integer(c_int), pointer, save irecmf |
| integer(c_int), pointer, save irevmc |
| integer, save itagms |
| integer(c_int), pointer, save itbrrb |
| integer, save itbslb |
| integer(c_int), pointer, save ivisse |
| integer(c_int), pointer, save n_buoyant_scal |
| integer(c_int), pointer, save rcfact |
| integer(c_int), pointer, save staggered |
