| integer | nscamx |
maximum number of scalars solutions of an advection equation, apart from the variables of the turbulence model ) , that is to say the temperature and other scalars (passive or not, user-defined or not) More... | |
| integer | nvarmx |
| maximal number of variables = nscamx + 12 (u,v,w,P,Rij,e,alp) More... | |
| integer | ntypmx |
| Maximal possible boundary condition types. More... | |
| integer | iindef |
| integer | ientre |
| integer | isolib |
| integer | isymet |
| integer | iparoi |
| integer | iparug |
| integer | iesicf |
| if itypfb=iesicf: imposed inlet/outlet for compressible flow (for example, supersonic inlet). More... | |
| integer | isspcf |
| if itypfb=isspcf: supersonic outlet for compressible flow. More... | |
| integer | isopcf |
| if itypfb=isopcf: mixed outlet for compressible flow with a given pressure. More... | |
| integer | iephcf |
| if itypfb=iephcf: mixed inlet for compressible flow with given total pressure and total enthalpy (reservoir boundary conditions). More... | |
| integer | ieqhcf |
| integer | icscpl |
| integer | icscpd |
| integer | ifrent |
| integer | ifresf |
| integer | i_convective_inlet |
| integer | nestmx |
| maximal number of valuators for Navier-Stokes More... | |
| integer | iespre |
Error estimator for Navier-Stokes. iest = iespre: prediction, (default name: EsPre). After the velocity prediction step (yielding ), the estimator , local variable calculated at every cell , is created from , which represents the residual of the equation solved during this step: and :
. More... | |
| integer | iesder |
Error estimator for Navier-Stokes. iest = iesder: drift (default name: EsDer). The estimator is based on the following quantity (intrinsic to the code):
. More... | |
| integer | iescor |
Error estimator for Navier-Stokes. iest = iescor: correction, (default name: EsCor). The estimator comes directly from the mass flow calculated with the updated velocity field:
. More... | |
| integer | iestot |
Error estimator for Navier-Stokes. iest = iestot: total, (default name: EsTot). The estimator , local variable calculated at every cell , is based on the quantity , which represents the residual of the equation using the updated values of and :
. More... | |
| integer | ibfixe |
| integer | igliss |
| integer | ivimpo |
| integer | ibalfs |
| integer | nstrmx |
| maximum number of structures in ALE More... | |
| integer i_convective_inlet |
if itypfb=i_convective_inlet: inlet face where the total mass flux is prescribed.
ivar, except for ivar = ipr. The other values of rcodcl and icodcl are filled automatically. The diffusive flux is CANCELLED (therefore the total mass flux is due to convection only). | integer ientre |
| integer iephcf |
| integer ieqhcf |
| integer iescor |
are taken at the cell centers, the divergence is calculated after projection on the faces.
represents the Kronecker symbol.
.| integer iesder |
| integer iesicf |
| integer iespre |
), the estimator
, is created from
and
which intrinsicly appears with the norm
. The size of the cell therefore appears in its calculation and induces a weighting effect.
is ideally equal to zero when the reconstruction methods are perfect and the associated system is solved exactly. | integer iestot |
and
expressed at the cell centers (and not taken from the updated mass flow at the faces).
. The size of the cell therefore appears in its calculation and induces a weighting effect. | integer ifrent |
if itypfb=ifrent: free entrance based on Bernoulli equation when the flow is incoming, standard outlet when outgoing
| integer ifresf |
if itypfb=ifresf: free surface for mobile mesh boundary condition
| integer iparoi |
if itypfb=iparoi: smooth solid wall face, impermeable and with friction.
| integer iparug |
if itypfb=iparug: rough solid wall face, impermeable and with friction.
| integer isolib |
if itypfb=isolib: free outlet face (or more precisely free inlet/outlet with forced pressure)
. The pressure is set to
at the first isolib face met. The pressure calibration is always done on a single face, even if there are several outlets.| integer isopcf |
| integer isspcf |
| integer isymet |
if itypfb=isymet: symmetry face (or wall without friction).
| integer ivimpo |
boundary condition type for mesh velocity in ALE: imposed velocity.
ivar (iuma, ivma and iwma). The other boxes of rcodcl and icodcl are completed automatically. The tangential mesh velocity is taken like a tape speed under the boundary conditions of wall for the fluid, except if wall fluid velocity was specified by the user in the interface or cs_user_boundary_conditions (in which case it is this speed which is considered). | integer nestmx |
| integer nscamx |
| integer nstrmx |
| integer ntypmx |
| integer nvarmx |
