1 #ifndef __CS_RESTART_H__ 2 #define __CS_RESTART_H__ 52 #define CS_RESTART_INTERVAL_NONE -2 53 #define CS_RESTART_INTERVAL_ONLY_AT_END -1 54 #define CS_RESTART_INTERVAL_DEFAULT 0 58 #define CS_RESTART_SUCCESS 0 59 #define CS_RESTART_ERR_FILE_NUM -1 60 #define CS_RESTART_ERR_LOCATION -2 61 #define CS_RESTART_ERR_VAL_TYPE -3 62 #define CS_RESTART_ERR_N_VALS -4 63 #define CS_RESTART_ERR_MODE -5 64 #define CS_RESTART_ERR_EXISTS -6 65 #define CS_RESTART_ERR_NO_MAP -7 122 const char *sec_name,
152 const char *sec_name,
180 const char *sec_name,
475 const char *location_name,
631 const char *sec_name,
654 const char *sec_name,
675 const char *sec_name,
716 int particles_location_id,
745 bool number_by_coords,
776 const char *sec_name,
801 const char *sec_name,
827 const char *sec_name,
828 const char *old_name,
857 const char *sec_name,
858 const char *old_name_x,
859 const char *old_name_y,
860 const char *old_name_z,
890 const char *sec_name,
891 const char *old_name_xx,
892 const char *old_name_yy,
893 const char *old_name_zz,
894 const char *old_name_xy,
895 const char *old_name_yz,
896 const char *old_name_xz,
926 const char *sec_name,
927 const char *old_name_xx,
928 const char *old_name_yy,
929 const char *old_name_zz,
930 const char *old_name_xy,
931 const char *old_name_yz,
932 const char *old_name_xz,
Definition: cs_restart.h:88
int cs_restart_read_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Read a section from a restart file.
Definition: cs_restart.c:2791
time step descriptor
Definition: cs_time_step.h:64
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
cs_restart_write_section_t * cs_restart_set_write_section_func(cs_restart_write_section_t *func)
Associate a function and its input to all restart section write operations.
Definition: cs_restart.c:2658
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:337
int cs_restart_write_particles(cs_restart_t *restart, const char *name, bool number_by_coords, cs_lnum_t n_particles, const cs_lnum_t *particle_cell_id, const cs_real_t *particle_coords)
Write basic particles information to a restart file.
Definition: cs_restart.c:3178
void cs_restart_dump_index(const cs_restart_t *restart)
Print the index associated with a restart file in read mode.
Definition: cs_restart.c:2719
void cs_restart_checkpoint_done(const cs_time_step_t *ts)
Indicate checkpointing has been done at a given time.
Definition: cs_restart.c:2055
void cs_restart_clear_locations_ref(void)
Clear reference location definitions with a private copy.
Definition: cs_restart.c:2569
void cs_restart_checkpoint_set_defaults(int nt_interval, double t_interval, double wt_interval)
Define default checkpoint interval.
Definition: cs_restart.c:1881
void cs_restart_print_stats(void)
Print statistics associated with restart files.
Definition: cs_restart.c:3975
cs_restart_t * cs_restart_create(const char *name, const char *path, cs_restart_mode_t mode)
Initialize a restart file.
Definition: cs_restart.c:2123
integer, save ntsuit
saving period of the restart files
Definition: entsor.f90:52
cs_real_t cs_real_66_t[6][6]
6x6 matrix of floating-point values
Definition: cs_defs.h:345
Definition: cs_defs.h:512
void cs_restart_write_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, const void *val)
Write a section to a restart file.
Definition: cs_restart.c:2834
cs_restart_check_section_t * cs_restart_set_check_section_func(cs_restart_check_section_t *func)
Associate a function to restart section check operations.
Definition: cs_restart.c:2614
cs_restart_mode_t
Definition: cs_restart.h:75
const char * cs_restart_get_name(const cs_restart_t *restart)
Return name of restart file.
Definition: cs_restart.c:2677
Definition: cs_restart.h:85
void cs_restart_add_location_ref(const char *location_name, cs_gnum_t n_glob_ents, cs_lnum_t n_ents, const cs_gnum_t *ent_global_num)
Add a reference location definition with a private copy.
Definition: cs_restart.c:2527
int cs_restart_read_section_compat(cs_restart_t *restart, const char *sec_name, const char *old_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Read a section from a restart file, when that section may have used a different name in a previous ve...
Definition: cs_restart.c:3519
Definition: cs_defs.h:322
integer, save isuite
Indicator of a calculation restart (=1) or not (=0). This value is set automatically by the code; dep...
Definition: optcal.f90:229
void cs_restart_set_n_max_checkpoints(int n_checkpoints)
Set the number of checkpoint files to keep.
Definition: cs_restart.c:4051
int cs_restart_read_real_3_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_x, const char *old_name_y, const char *old_name_z, int location_id, cs_real_3_t *val)
Read a cs_real_3_t vector section from a restart file, when that section may have used a different na...
Definition: cs_restart.c:3596
void reqsui(int *iisuit)
Definition: cs_restart.c:1797
int cs_restart_read_real_66_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_xx, const char *old_name_yy, const char *old_name_zz, const char *old_name_xy, const char *old_name_yz, const char *old_name_xz, int location_id, cs_real_66_t *val)
Read a cs_real_66_t tensor section from a restart file, when that section may have used a different n...
Definition: cs_restart.c:3852
void cs_restart_checkpoint_set_last_ts(int nt_last)
Define last forced checkpoint time step.
Definition: cs_restart.c:1925
bool cs_restart_checkpoint_required(const cs_time_step_t *ts)
Check if checkpointing is recommended at a given time.
Definition: cs_restart.c:1983
cs_restart_read_section_t * cs_restart_set_read_section_func(cs_restart_read_section_t *func)
Associate a function and its input to all restart section read operations.
Definition: cs_restart.c:2636
int cs_restart_present(void)
Check if we have a restart directory.
Definition: cs_restart.c:2094
Definition: cs_restart.h:87
void() cs_restart_write_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, const void *val)
Function pointer for modifying behavior when writing a section.
Definition: cs_restart.h:179
int cs_restart_check_if_restart_from_ncfd(cs_restart_t *r)
Checks if restart is done from a NCFD checkpoint file.
Definition: cs_restart.c:3998
Definition: cs_restart.h:96
void stusui(void)
Definition: cs_restart.c:1820
void cs_restart_checkpoint_set_next_ts(int nt_next)
Define next forced checkpoint time step.
Definition: cs_restart.c:1939
int cs_restart_read_particles_info(cs_restart_t *restart, const char *name, cs_lnum_t *n_particles)
Read basic particles information from a restart file.
Definition: cs_restart.c:2874
int cs_restart_read_ids(cs_restart_t *restart, const char *sec_name, int location_id, int ref_location_id, cs_lnum_t ref_id_base, cs_lnum_t *ref_id)
Read a referenced location id section from a restart file.
Definition: cs_restart.c:3313
int cs_restart_read_real_6_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_xx, const char *old_name_yy, const char *old_name_zz, const char *old_name_xy, const char *old_name_yz, const char *old_name_xz, int location_id, cs_real_6_t *val)
Read a cs_real_6_t tensor section from a restart file, when that section may have used a different na...
Definition: cs_restart.c:3710
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
int cs_restart_check_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type)
Check the presence of a given section in a restart file.
Definition: cs_restart.c:2758
void cs_restart_clean_multiwriters_history(void)
Remove all previous checkpoints which are not to be retained.
Definition: cs_restart.c:4073
Definition: cs_defs.h:316
Definition: cs_restart.h:78
void indsui(int *isuite)
Definition: cs_restart.c:1856
void cs_restart_checkpoint_set_next_wt(double wt_next)
Define next forced checkpoint wall-clock time value.
Definition: cs_restart.c:1967
Definition: cs_restart.h:84
Definition: cs_defs.h:513
int cs_restart_is_from_ncfd(void)
Returns if restart is done from a NCFD checkpoint file.
Definition: cs_restart.c:4027
void cs_restart_checkpoint_set_next_tv(double t_next)
Define next forced checkpoint time value.
Definition: cs_restart.c:1953
int cs_restart_read_particles(cs_restart_t *restart, int particles_location_id, cs_lnum_t *particle_cell_id, cs_real_t *particle_coords)
Definition: cs_restart.c:3061
void trbsui(void)
Definition: cs_restart.c:1837
#define CS_PROCF(x, y)
Definition: cs_defs.h:526
Definition: cs_restart.h:86
void dflsui(int *ntsuit, cs_real_t *ttsuit, cs_real_t *wtsuit)
Definition: cs_restart.c:1776
void cs_restart_set_context(void *context)
Associate a context to restart section check operations.
Definition: cs_restart.c:2596
cs_lnum_t cs_restart_get_n_location_elts(const cs_restart_t *restart, int location_id)
Return local number of elements associated with a given restart location.
Definition: cs_restart.c:2697
void cs_restart_destroy(cs_restart_t **restart)
Destroy structure associated with a restart file (and close the file).
Definition: cs_restart.c:2318
void cs_restart_check_base_location(const cs_restart_t *restart, bool *match_cell, bool *match_i_face, bool *match_b_face, bool *match_vertex)
Check the locations associated with a restart file.
Definition: cs_restart.c:2374
void cs_restart_multiwriters_destroy_all(void)
Destroy the multiwriter structure at the end of the computation.
Definition: cs_restart.c:4132
void cs_restart_checkpoint_set_mesh_mode(int mode)
Define checkpoint behavior for mesh.
Definition: cs_restart.c:1911
Definition: cs_restart.h:77
int cs_restart_add_location(cs_restart_t *restart, const char *location_name, cs_gnum_t n_glob_ents, cs_lnum_t n_ents, const cs_gnum_t *ent_global_num)
Add a location definition.
Definition: cs_restart.c:2432
int() cs_restart_check_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type)
Function pointer for modifying behavior when checking a section's presence.
Definition: cs_restart.h:121
void cs_restart_write_ids(cs_restart_t *restart, const char *sec_name, int location_id, int ref_location_id, cs_lnum_t ref_id_base, const cs_lnum_t *ref_id)
Write a referenced location id section to a restart file.
Definition: cs_restart.c:3416
int() cs_restart_read_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Function pointer for modifying behavior when reading a section.
Definition: cs_restart.h:151
