7.3
cs_post.h
1 #ifndef __CS_POST_H__
2 #define __CS_POST_H__
5  * Post-processing management
30 #include "cs_defs.h"
37  * Local headers
40 #include "fvm_nodal.h"
41 #include "fvm_writer.h"
43 #include "cs_base.h"
44 #include "cs_function.h"
45 #include "cs_interpolate.h"
46 #include "cs_probe.h"
47 #include "cs_time_step.h"
48 #include "cs_time_control.h"
49
50 /*----------------------------------------------------------------------------*/
51
53
55  * Macro definitions
57
58 /* Output type masks */
59
60 #define CS_POST_ON_LOCATION (1 << 0) /* postprocess variables
61  on their base location
62  (volume for variables) */
63 #define CS_POST_BOUNDARY_NR (1 << 1) /* postprocess boundary
64  without reconstruction */
65
66 #define CS_POST_MONITOR (1 << 2) /* monitor variables */
67
68 /* Default writer ids and filters */
69
70 #define CS_POST_WRITER_ALL_ASSOCIATED 0
72 #define CS_POST_WRITER_DEFAULT -1
73 #define CS_POST_WRITER_ERRORS -2
74 #define CS_POST_WRITER_PARTICLES -3
75 #define CS_POST_WRITER_TRAJECTORIES -4
76 #define CS_POST_WRITER_PROBES -5
77 #define CS_POST_WRITER_PROFILES -6
78 #define CS_POST_WRITER_HISTOGRAMS -7
80 /* Default mesh ids */
81
82 #define CS_POST_MESH_VOLUME -1
83 #define CS_POST_MESH_BOUNDARY -2
84 #define CS_POST_MESH_PARTICLES -3
85 #define CS_POST_MESH_TRAJECTORIES -4
86 #define CS_POST_MESH_PROBES -5
88 /* Additional categories (no associated default mesh) */
89
90 #define CS_POST_MESH_SURFACE -12 /* surface (boundary and/or
91  interior) mesh */
92
93 /*============================================================================
94  * Local type definitions
95  *============================================================================*/
96
97 /* Datatype enumeration (deprecated; cs_datatype_t preferred) */
98
100
101 #define CS_POST_TYPE_int CS_INT_TYPE
102 #define CS_POST_TYPE_cs_real_t CS_REAL_TYPE
103 #define CS_POST_TYPE_float CS_FLOAT
104 #define CS_POST_TYPE_double CS_DOUBLE
105
106 /*----------------------------------------------------------------------------
107  * Function pointer to elements selection definition.
108  *
109  * Each function of this sort may be used to select a given type of element,
110  * usually cells, interior faces, boundary faces, or particles.
111  *
112  * If non-empty and not containing all elements, a list of elements of the
113  * main mesh should be allocated (using BFT_MALLOC) and defined by this
114  * function when called. This list's lifecycle is then managed by the
115  * postprocessing subsystem.
116  *
117  * Note: if the input pointer is non-NULL, it must point to valid data
118  * when the selection function is called, so either:
119  * - that value or structure should not be temporary (i.e. local);
120  * - post-processing output must be ensured using cs_post_write_meshes()
121  * with a fixed-mesh writer before the data pointed to goes out of scope;
122  *
123  * parameters:
124  * input <-> pointer to optional (untyped) value or structure.
125  * n_elts --> number of selected elements.
126  * elt_list --> list of selected elements (0 to n-1 numbering).
127  *----------------------------------------------------------------------------*/
128
129 typedef void
130 (cs_post_elt_select_t) (void *input,
131  cs_lnum_t *n_elts,
132  cs_lnum_t **elt_list);
133
134 /*----------------------------------------------------------------------------
135  * Function pointer associated with a specific post-processing output.
136  *
137  * Such functions are registered using the cs_post_add_time_dep_vars(),
138  * and all registered functions are automatically called by
139  * cs_post_write_vars().
140  *
141  * Note: if the input pointer is non-NULL, it must point to valid data
142  * when the output function is called, so either:
143  * - that value or structure should not be temporary (i.e. local);
144  * - post-processing output must be ensured using cs_post_write_var()
145  * or similar before the data pointed to goes out of scope.
146  *
147  * parameters:
148  * input <-> pointer to optional (untyped) value or structure.
149  * ts <-- time step status structure, or NULL
150  *----------------------------------------------------------------------------*/
151
152 typedef void
154  const cs_time_step_t *ts);
155
156 /*----------------------------------------------------------------------------
157  * Function pointer associated with a specific post-processing output
158  * on multiple meshes.
159  *
160  * Such functions are registered using the cs_post_add_time_mesh_dep_vars(),
161  * and all registered functions are automatically called by
162  * cs_post_write_vars().
163  *
164  * Note: if the input pointer is non-NULL, it must point to valid data
165  * when the output function is called, so either:
166  * - that value or structure should not be temporary (i.e. local);
167  * - post-processing output must be ensured using cs_post_write_var()
168  * or similar before the data pointed to goes out of scope.
169  *
170  * parameters:
171  * input <-> pointer to optional (untyped) value or structure.
172  * mesh_id <-- id of the output mesh for the current call
173  * cat_id <-- category id of the output mesh for the current call
174  * ent_flag <-- indicate global presence of cells (ent_flag[0]), interior
175  * faces (ent_flag[1]), boundary faces (ent_flag[2]),
176  * particles (ent_flag[3]) or probes (ent_flag[4])
177  * n_cells <-- local number of cells of post_mesh
178  * n_i_faces <-- local number of interior faces of post_mesh
179  * n_b_faces <-- local number of boundary faces of post_mesh
180  * cell_ids <-- list of cells (0 to n-1) of post-processing mesh
181  * i_face_ids <-- list of interior faces (0 to n-1) of post-processing mesh
182  * b_face_ids <-- list of boundary faces (0 to n-1) of post-processing mesh
183  * ts <-- time step status structure, or NULL
184  *----------------------------------------------------------------------------*/
185
186 typedef void
188  int mesh_id,
189  int cat_id,
190  int ent_flag[5],
191  cs_lnum_t n_cells,
192  cs_lnum_t n_i_faces,
193  cs_lnum_t n_b_faces,
194  const cs_lnum_t cell_ids[],
195  const cs_lnum_t i_face_ids[],
196  const cs_lnum_t b_face_ids[],
197  const cs_time_step_t *ts);
198
199 /*=============================================================================
200  * Global variables
201  *============================================================================*/
202
203 /*============================================================================
204  * Public function prototypes
205  *============================================================================*/
206
207 /*----------------------------------------------------------------------------*/
292 /*----------------------------------------------------------------------------*/
293
294 void
295 cs_post_define_writer(int writer_id,
296  const char *case_name,
297  const char *dir_name,
298  const char *fmt_name,
299  const char *fmt_opts,
300  fvm_writer_time_dep_t time_dep,
301  bool output_at_start,
302  bool output_at_end,
303  int interval_n,
304  double interval_t);
305
306 /*----------------------------------------------------------------------------*/
319 /*----------------------------------------------------------------------------*/
320
321 void
322 cs_post_define_volume_mesh(int mesh_id,
323  const char *mesh_name,
324  const char *cell_criteria,
325  bool add_groups,
326  bool auto_variables,
327  int n_writers,
328  const int writer_ids[]);
329
330 /*----------------------------------------------------------------------------*/
357 /*----------------------------------------------------------------------------*/
358
359 void
361  const char *mesh_name,
362  cs_post_elt_select_t *cell_select_func,
363  void *cell_select_input,
364  bool time_varying,
365  bool add_groups,
366  bool auto_variables,
367  int n_writers,
368  const int writer_ids[]);
369
370 /*----------------------------------------------------------------------------*/
384 /*----------------------------------------------------------------------------*/
385
386 void
387 cs_post_define_surface_mesh(int mesh_id,
388  const char *mesh_name,
389  const char *i_face_criteria,
390  const char *b_face_criteria,
391  bool add_groups,
392  bool auto_variables,
393  int n_writers,
394  const int writer_ids[]);
395
396 /*----------------------------------------------------------------------------*/
427 /*----------------------------------------------------------------------------*/
428
429 void
431  const char *mesh_name,
432  cs_post_elt_select_t *i_face_select_func,
433  cs_post_elt_select_t *b_face_select_func,
434  void *i_face_select_input,
435  void *b_face_select_input,
436  bool time_varying,
437  bool add_groups,
438  bool auto_variables,
439  int n_writers,
440  const int writer_ids[]);
441
442 /*----------------------------------------------------------------------------*/
456 /*----------------------------------------------------------------------------*/
457
458 void
460  const char *mesh_name,
461  int location_id,
462  bool add_groups,
463  bool auto_variables,
464  int n_writers,
465  const int writer_ids[]);
466
467 /*----------------------------------------------------------------------------*/
492 /*----------------------------------------------------------------------------*/
493
494 void
496  const char *mesh_name,
497  const char *cell_criteria,
498  double density,
499  bool trajectory,
500  bool auto_variables,
501  int n_writers,
502  const int writer_ids[]);
503
504 /*----------------------------------------------------------------------------*/
534 /*----------------------------------------------------------------------------*/
535
536 void
538  const char *mesh_name,
539  cs_post_elt_select_t *p_select_func,
540  void *p_select_input,
541  bool trajectory,
542  bool auto_variables,
543  int n_writers,
544  const int writer_ids[]);
545
546 /*----------------------------------------------------------------------------*/
576 /*----------------------------------------------------------------------------*/
577
578 void
579 cs_post_define_existing_mesh(int mesh_id,
580  fvm_nodal_t *exp_mesh,
581  int dim_shift,
582  bool transfer,
583  bool auto_variables,
584  int n_writers,
585  const int writer_ids[]);
586
587 /*----------------------------------------------------------------------------*/
604 /*----------------------------------------------------------------------------*/
605
606 void
607 cs_post_define_edges_mesh(int mesh_id,
608  int base_mesh_id,
609  int n_writers,
610  const int writer_ids[]);
611
612 /*----------------------------------------------------------------------------*/
627 /*----------------------------------------------------------------------------*/
628
629 void
630 cs_post_mesh_attach_writer(int mesh_id,
631  int writer_id);
632
633 /*----------------------------------------------------------------------------*/
648 /*----------------------------------------------------------------------------*/
649
650 void
651 cs_post_mesh_detach_writer(int mesh_id,
652  int writer_id);
653
654 /*----------------------------------------------------------------------------*/
670 /*----------------------------------------------------------------------------*/
671
672 void
673 cs_post_mesh_attach_field(int mesh_id,
674  int writer_id,
675  int field_id,
676  int comp_id);
677
678 /*----------------------------------------------------------------------------*/
694 /*----------------------------------------------------------------------------*/
695
696 const int *
697 cs_post_mesh_get_ent_flag(int mesh_id);
698
699 /*----------------------------------------------------------------------------*/
707 /*----------------------------------------------------------------------------*/
708
709 cs_lnum_t
710 cs_post_mesh_get_n_cells(int mesh_id);
711
712 /*----------------------------------------------------------------------------*/
723 /*----------------------------------------------------------------------------*/
724
725 void
726 cs_post_mesh_get_cell_ids(int mesh_id,
727  cs_lnum_t *cell_ids);
728
729 /*----------------------------------------------------------------------------*/
737 /*----------------------------------------------------------------------------*/
738
739 cs_lnum_t
740 cs_post_mesh_get_n_i_faces(int mesh_id);
741
742 /*----------------------------------------------------------------------------*/
753 /*----------------------------------------------------------------------------*/
754
755 void
756 cs_post_mesh_get_i_face_ids(int mesh_id,
757  cs_lnum_t i_face_ids[]);
758
759 /*----------------------------------------------------------------------------*/
767 /*----------------------------------------------------------------------------*/
768
769 cs_lnum_t
770 cs_post_mesh_get_n_b_faces(int mesh_id);
771
772 /*----------------------------------------------------------------------------*/
783 /*----------------------------------------------------------------------------*/
784
785 void
786 cs_post_mesh_get_b_face_ids(int mesh_id,
787  cs_lnum_t b_face_ids[]);
788
789 /*----------------------------------------------------------------------------*/
797 /*----------------------------------------------------------------------------*/
798
799 cs_lnum_t
800 cs_post_mesh_get_n_vertices(int mesh_id);
801
802 /*----------------------------------------------------------------------------*/
813 /*----------------------------------------------------------------------------*/
814
815 void
816 cs_post_mesh_get_vertex_ids(int mesh_id,
817  cs_lnum_t *vertex_ids);
818
819 /*----------------------------------------------------------------------------*/
827 /*----------------------------------------------------------------------------*/
828
829 void
830 cs_post_mesh_set_post_domain(int mesh_id,
831  bool post_domain);
832
833 /*----------------------------------------------------------------------------*/
845 /*----------------------------------------------------------------------------*/
846
847 void
848 cs_post_free_mesh(int mesh_id);
849
850 /*----------------------------------------------------------------------------*/
858 /*----------------------------------------------------------------------------*/
859
860 bool
861 cs_post_writer_exists(int writer_id);
862
863 /*----------------------------------------------------------------------------*/
871 /*----------------------------------------------------------------------------*/
872
873 bool
874 cs_post_mesh_exists(int mesh_id);
875
876 /*----------------------------------------------------------------------------*/
882 /*----------------------------------------------------------------------------*/
883
884 const char *
886
887 /*----------------------------------------------------------------------------*/
893 /*----------------------------------------------------------------------------*/
894
895 const char *
897
898 /*----------------------------------------------------------------------------*/
904 /*----------------------------------------------------------------------------*/
905
906 int
908
909 /*----------------------------------------------------------------------------*/
915 /*----------------------------------------------------------------------------*/
916
917 int
919
920 /*----------------------------------------------------------------------------*/
930 /*----------------------------------------------------------------------------*/
931
932 void
934
935 /*----------------------------------------------------------------------------*/
943 /*----------------------------------------------------------------------------*/
944
945 bool
946 cs_post_writer_is_active(int writer_id);
947
948 /*----------------------------------------------------------------------------*/
956 /*----------------------------------------------------------------------------*/
957
958 void
959 cs_post_activate_writer(int writer_id,
960  bool activate);
961
962 /*----------------------------------------------------------------------------*/
977 /*----------------------------------------------------------------------------*/
978
979 void
980 cs_post_disable_writer(int writer_id);
981
982 /*----------------------------------------------------------------------------*/
996 /*----------------------------------------------------------------------------*/
997
998 void
999 cs_post_enable_writer(int writer_id);
1000
1001 /*----------------------------------------------------------------------------*/
1009 /*----------------------------------------------------------------------------*/
1010
1011 fvm_writer_t *
1012 cs_post_get_writer(int writer_id);
1013
1014 /*----------------------------------------------------------------------------*/
1022 /*----------------------------------------------------------------------------*/
1023
1025 cs_post_get_time_control(int writer_id);
1026
1027 /*----------------------------------------------------------------------------*/
1035 /*----------------------------------------------------------------------------*/
1036
1038 cs_post_get_writer_time_dep(int writer_id);
1039
1040 /*----------------------------------------------------------------------------*/
1050 /*----------------------------------------------------------------------------*/
1051
1052 void
1053 cs_post_add_writer_t_step(int writer_id,
1054  int nt);
1055
1056 /*----------------------------------------------------------------------------*/
1066 /*----------------------------------------------------------------------------*/
1067
1068 void
1069 cs_post_add_writer_t_value(int writer_id,
1070  double t);
1071
1072 /*----------------------------------------------------------------------------*/
1081 /*----------------------------------------------------------------------------*/
1082
1083 void
1085
1086 /*----------------------------------------------------------------------------*/
1107 /*----------------------------------------------------------------------------*/
1108
1109 void
1110 cs_post_write_var(int mesh_id,
1111  int writer_id,
1112  const char *var_name,
1113  int var_dim,
1114  bool interlace,
1115  bool use_parent,
1116  cs_datatype_t datatype,
1117  const void *cel_vals,
1118  const void *i_face_vals,
1119  const void *b_face_vals,
1120  const cs_time_step_t *ts);
1121
1122 /*----------------------------------------------------------------------------*/
1141 /*----------------------------------------------------------------------------*/
1142
1143 void
1144 cs_post_write_function(int mesh_id,
1145  int writer_id,
1146  const cs_function_t *cel_f,
1147  const cs_function_t *i_face_f,
1148  const cs_function_t *b_face_f,
1149  const cs_time_step_t *ts);
1150
1151 /*----------------------------------------------------------------------------*/
1170 /*----------------------------------------------------------------------------*/
1171
1172 void
1173 cs_post_write_vertex_var(int mesh_id,
1174  int writer_id,
1175  const char *var_name,
1176  int var_dim,
1177  bool interlace,
1178  bool use_parent,
1179  cs_datatype_t datatype,
1180  const void *vtx_vals,
1181  const cs_time_step_t *ts);
1182
1183 /*----------------------------------------------------------------------------*/
1196 /*----------------------------------------------------------------------------*/
1197
1198 void
1199 cs_post_write_vertex_function(int mesh_id,
1200  int writer_id,
1201  const cs_function_t *f,
1202  const cs_time_step_t *ts);
1203
1204 /*----------------------------------------------------------------------------*/
1219 /*----------------------------------------------------------------------------*/
1220
1221 void
1222 cs_post_write_particle_values(int mesh_id,
1223  int writer_id,
1224  int attr_id,
1225  const char *var_name,
1226  int component_id,
1227  const cs_time_step_t *ts);
1228
1229 /*----------------------------------------------------------------------------*/
1250 /*----------------------------------------------------------------------------*/
1251
1252 void
1253 cs_post_write_probe_values(int mesh_id,
1254  int writer_id,
1255  const char *var_name,
1256  int var_dim,
1257  cs_datatype_t datatype,
1258  int parent_location_id,
1259  cs_interpolate_from_location_t *interpolate_func,
1260  void *interpolate_input,
1261  const void *vals,
1262  const cs_time_step_t *ts);
1263
1264 /*----------------------------------------------------------------------------*/
1299 /*----------------------------------------------------------------------------*/
1300
1301 void
1302 cs_post_write_probe_function(int mesh_id,
1303  int writer_id,
1304  const cs_function_t *f,
1305  int parent_location_id,
1306  cs_interpolate_from_location_t *interpolate_func,
1307  void *interpolate_input,
1308  const cs_time_step_t *ts);
1309
1310 /*----------------------------------------------------------------------------*/
1322 /*----------------------------------------------------------------------------*/
1323
1324 void
1325 cs_post_renum_cells(const cs_lnum_t init_cell_num[]);
1326
1327 /*----------------------------------------------------------------------------*/
1340 /*----------------------------------------------------------------------------*/
1341
1342 void
1343 cs_post_renum_faces(const cs_lnum_t init_i_face_num[],
1344  const cs_lnum_t init_b_face_num[]);
1345
1346 /*----------------------------------------------------------------------------*/
1357 /*----------------------------------------------------------------------------*/
1358
1359 void
1361
1362 /*----------------------------------------------------------------------------*/
1366 /*----------------------------------------------------------------------------*/
1367
1368 void
1369 cs_post_init_writers(void);
1370
1371 /*----------------------------------------------------------------------------*/
1389 /*----------------------------------------------------------------------------*/
1390
1391 void
1392 cs_post_init_meshes(int check_mask);
1393
1394 /*----------------------------------------------------------------------------*/
1401 /*----------------------------------------------------------------------------*/
1402
1403 void
1405
1406 /*----------------------------------------------------------------------------*/
1416 /*----------------------------------------------------------------------------*/
1417
1418 void
1420
1421 /*----------------------------------------------------------------------------*/
1426 /*----------------------------------------------------------------------------*/
1427
1428 void
1429 cs_post_time_step_end(void);
1430
1431 /*----------------------------------------------------------------------------*/
1441 /*----------------------------------------------------------------------------*/
1442
1443 void
1445
1446 /*----------------------------------------------------------------------------*/
1450 /*----------------------------------------------------------------------------*/
1451
1452 void
1453 cs_post_finalize(void);
1454
1455 /*----------------------------------------------------------------------------*/
1459 /*----------------------------------------------------------------------------*/
1460
1461 void
1463
1464 /*----------------------------------------------------------------------------*/
1470 /*----------------------------------------------------------------------------*/
1471
1472 void
1474
1475 /*----------------------------------------------------------------------------*/
1486 /*----------------------------------------------------------------------------*/
1487
1488 int
1490
1491 /*----------------------------------------------------------------------------*/
1505 /*----------------------------------------------------------------------------*/
1506
1507 void
1509  void *input);
1510
1511 /*----------------------------------------------------------------------------*/
1525 /*----------------------------------------------------------------------------*/
1526
1527 void
1529  void *input);
1530
1531 /*----------------------------------------------------------------------------*/
1532
1534
1535 #endif /* __CS_POST_H__ */
void cs_post_write_vars(const cs_time_step_t *ts)
Loop on post-processing meshes to output variables.
Definition: cs_post.c:7838
cs_datatype_t
Definition: cs_defs.h:275
const char * cs_post_get_default_format(void)
Return the default writer format name.
Definition: cs_post.c:5441
time step descriptor
Definition: cs_time_step.h:64
void cs_post_mesh_get_i_face_ids(int mesh_id, cs_lnum_t i_face_ids[])
Get a postprocessing mesh&#39;s list of boundary faces.
Definition: cs_post.c:5125
void cs_post_init_error_writer(void)
Initialize post-processing writer with same format and associated options as default writer...
Definition: cs_post.c:8165
void cs_post_enable_writer(int writer_id)
Enable a specific writer or all writers currently disabled by previous calls to cs_post_disable_write...
Definition: cs_post.c:5648
void cs_post_time_step_end(void)
Flush writers and free time-varying and Lagragian mesh if needed of meshes if there is a time-depende...
Definition: cs_post.c:7794
Definition: cs_time_control.h:96
void cs_post_define_surface_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *i_face_select_func, cs_post_elt_select_t *b_face_select_func, void *i_face_select_input, void *b_face_select_input, bool time_varying, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a surface post-processing mesh using selection functions.
Definition: cs_post.c:4406
cs_lnum_t cs_post_mesh_get_n_vertices(int mesh_id)
Get a postprocessing mesh&#39;s number of vertices.
Definition: cs_post.c:5240
void cs_post_free_mesh(int mesh_id)
Remove a post-processing mesh.
Definition: cs_post.c:5322
void cs_post_init_writers(void)
Initialize post-processing writers.
Definition: cs_post.c:7211
void cs_post_activate_by_time_step(const cs_time_step_t *ts)
Update "active" or "inactive" flag of writers based on the time step.
Definition: cs_post.c:5501
void cs_post_mesh_attach_writer(int mesh_id, int writer_id)
Associate a writer to a postprocessing mesh.
Definition: cs_post.c:4844
Definition: cs_defs.h:512
void cs_post_write_function(int mesh_id, int writer_id, const cs_function_t *cel_f, const cs_function_t *i_face_f, const cs_function_t *b_face_f, const cs_time_step_t *ts)
Output a function evaluation at cells or faces of a post-processing mesh using associated writers...
Definition: cs_post.c:6111
const int * cs_post_mesh_get_ent_flag(int mesh_id)
Get a postprocessing meshes entity presence flag.
Definition: cs_post.c:5018
void cs_post_define_particles_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *p_select_func, void *p_select_input, bool trajectory, bool auto_variables, int n_writers, const int writer_ids[])
Define a particles post-processing mesh using a selection function.
Definition: cs_post.c:4613
cs_time_control_t * cs_post_get_time_control(int writer_id)
Return a pointer to the time control associated to a writer_id.
Definition: cs_post.c:5704
int cs_post_get_free_writer_id(void)
Return the next "reservable" (i.e. non-user) writer id available.
Definition: cs_post.c:5469
int cs_post_init_error_writer_cells(void)
Definition: cs_post.c:8215
void cs_post_define_existing_mesh(int mesh_id, fvm_nodal_t *exp_mesh, int dim_shift, bool transfer, bool auto_variables, int n_writers, const int writer_ids[])
Create a post-processing mesh associated with an existing exportable mesh representation.
Definition: cs_post.c:4679
void cs_post_disable_writer(int writer_id)
Disable specific writer or all writers not currently active until cs_post_enable_writer or cs_post_ac...
Definition: cs_post.c:5611
void cs_post_define_mesh_by_location(int mesh_id, const char *mesh_name, int location_id, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a volume or surface post-processing mesh by associated mesh location id.
Definition: cs_post.c:4466
void cs_post_mesh_set_post_domain(int mesh_id, bool post_domain)
Set whether postprocessing mesh&#39;s parallel domain should be output.
Definition: cs_post.c:5299
Definition: fvm_writer.h:57
fvm_writer_t * cs_post_get_writer(int writer_id)
Return a pointer to the FVM writer associated to a writer_id.
Definition: cs_post.c:5679
void cs_post_renum_faces(const cs_lnum_t init_i_face_num[], const cs_lnum_t init_b_face_num[])
Update references to parent mesh of post-processing meshes in case of computational mesh interior and...
Definition: cs_post.c:7104
void cs_post_init_meshes(int check_mask)
Initialize main post-processing meshes.
Definition: cs_post.c:7325
void cs_post_mesh_get_b_face_ids(int mesh_id, cs_lnum_t b_face_ids[])
Definition: cs_post.c:5198
cs_lnum_t cs_post_mesh_get_n_b_faces(int mesh_id)
Get a postprocessing mesh&#39;s number of boundary faces.
Definition: cs_post.c:5168
cs_lnum_t cs_post_mesh_get_n_i_faces(int mesh_id)
Get a postprocessing mesh&#39;s number of interior faces.
Definition: cs_post.c:5095
const char * cs_post_get_default_format_options(void)
Return the default writer format options.
Definition: cs_post.c:5455
void cs_post_define_particles_mesh(int mesh_id, const char *mesh_name, const char *cell_criteria, double density, bool trajectory, bool auto_variables, int n_writers, const int writer_ids[])
Define a particles post-processing mesh.
Definition: cs_post.c:4545
void cs_post_add_time_mesh_dep_output(cs_post_time_mesh_dep_output_t *function, void *input)
Register a processing of time-dependent variables than can be output on different meshes to the call ...
Definition: cs_post.c:8298
void cs_post_write_probe_values(int mesh_id, int writer_id, const char *var_name, int var_dim, cs_datatype_t datatype, int parent_location_id, cs_interpolate_from_location_t *interpolate_func, void *interpolate_input, const void *vals, const cs_time_step_t *ts)
Output a variable defined at cells or faces of a post-processing mesh using associated writers...
Definition: cs_post.c:6727
void cs_post_write_meshes(const cs_time_step_t *ts)
Output post-processing meshes using associated writers.
Definition: cs_post.c:5809
fvm_writer_time_dep_t cs_post_get_writer_time_dep(int writer_id)
Return time dependency associated to a writer_id.
Definition: cs_post.c:5723
void() cs_post_elt_select_t(void *input, cs_lnum_t *n_elts, cs_lnum_t **elt_list)
Definition: cs_post.h:130
void cs_post_define_volume_mesh(int mesh_id, const char *mesh_name, const char *cell_criteria, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a volume post-processing mesh.
Definition: cs_post.c:4215
void() cs_interpolate_from_location_t(void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals)
Function pointer for interpolatation of values defined on a mesh location at a given set of points...
Definition: cs_interpolate.h:71
void() cs_post_time_dep_output_t(void *input, const cs_time_step_t *ts)
Definition: cs_post.h:153
void cs_post_finalize(void)
Destroy all structures associated with post-processing.
Definition: cs_post.c:7860
void cs_post_write_vertex_function(int mesh_id, int writer_id, const cs_function_t *f, const cs_time_step_t *ts)
Definition: cs_post.c:6443
Definition: cs_function.h:115
void cs_post_define_surface_mesh(int mesh_id, const char *mesh_name, const char *i_face_criteria, const char *b_face_criteria, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a surface post-processing mesh.
Definition: cs_post.c:4328
void cs_post_mesh_detach_writer(int mesh_id, int writer_id)
De-associate a writer from a postprocessing mesh.
Definition: cs_post.c:4896
void cs_post_set_changing_connectivity(void)
Configure the post-processing output so that mesh connectivity may be automatically updated...
Definition: cs_post.c:7199
double precision, dimension(:,:,:), allocatable density
Definition: atimbr.f90:124
void() cs_post_time_mesh_dep_output_t(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *ts)
Definition: cs_post.h:187
void cs_post_time_step_output(const cs_time_step_t *ts)
Definition: cs_post.c:7520
int cs_post_get_free_mesh_id(void)
Return the next "reservable" (i.e. non-user) mesh id available.
Definition: cs_post.c:5483
void cs_post_write_particle_values(int mesh_id, int writer_id, int attr_id, const char *var_name, int component_id, const cs_time_step_t *ts)
Output an existing lagrangian particle attribute at particle positions or trajectory endpoints of a p...
Definition: cs_post.c:6559
void cs_post_mesh_get_vertex_ids(int mesh_id, cs_lnum_t *vertex_ids)
Get a postprocessing mesh&#39;s list of vertices.
Definition: cs_post.c:5270
Definition: cs_defs.h:316
cs_lnum_t cs_post_mesh_get_n_cells(int mesh_id)
Get a postprocessing mesh&#39;s number of cells.
Definition: cs_post.c:5036
void cs_post_mesh_get_cell_ids(int mesh_id, cs_lnum_t *cell_ids)
Get a postprocessing mesh&#39;s list of cells.
Definition: cs_post.c:5066
void cs_post_write_probe_function(int mesh_id, int writer_id, const cs_function_t *f, int parent_location_id, cs_interpolate_from_location_t *interpolate_func, void *interpolate_input, const cs_time_step_t *ts)
Output function-evaluated values at cells or faces of a post-processing probe set using associated wr...
Definition: cs_post.c:6870
void cs_post_activate_writer(int writer_id, bool activate)
Force the "active" or "inactive" flag for a specific writer or for all writers for the current time s...
Definition: cs_post.c:5574
void cs_post_add_free_faces(void)
Postprocess free (isolated) faces of the current global mesh.
Definition: cs_post.c:7954
Definition: cs_defs.h:513
void cs_post_add_writer_t_value(int writer_id, double t)
Add an activation time value for a specific writer or for all writers.
Definition: cs_post.c:5782
void cs_post_write_var(int mesh_id, int writer_id, const char *var_name, int var_dim, bool interlace, bool use_parent, cs_datatype_t datatype, const void *cel_vals, const void *i_face_vals, const void *b_face_vals, const cs_time_step_t *ts)
Definition: cs_post.c:5866
void cs_post_add_time_dep_output(cs_post_time_dep_output_t *function, void *input)
Register a processing of time-dependent variables to the call to cs_post_write_vars().
Definition: cs_post.c:8257
void cs_post_mesh_attach_field(int mesh_id, int writer_id, int field_id, int comp_id)
Associate a field to a writer and postprocessing mesh combination.
Definition: cs_post.c:4954
void cs_post_define_edges_mesh(int mesh_id, int base_mesh_id, int n_writers, const int writer_ids[])
Create a mesh based upon the extraction of edges from an existing mesh.
Definition: cs_post.c:4803
void cs_post_write_vertex_var(int mesh_id, int writer_id, const char *var_name, int var_dim, bool interlace, bool use_parent, cs_datatype_t datatype, const void *vtx_vals, const cs_time_step_t *ts)
Output a variable defined at vertices of a post-processing mesh using associated writers.
Definition: cs_post.c:6326
cs_datatype_t cs_post_type_t
Definition: cs_post.h:99
bool cs_post_mesh_exists(int mesh_id)
Check for the existence of a post-processing mesh of the given id.
Definition: cs_post.c:5416
void cs_post_add_writer_t_step(int writer_id, int nt)
Add an activation time step for a specific writer or for all writers.
Definition: cs_post.c:5754
void cs_post_define_writer(int writer_id, const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int interval_n, double interval_t)
Define a writer; this objects manages a case&#39;s name, directory, and format, as well as associated mes...
Definition: cs_post.c:4060
bool cs_post_writer_exists(int writer_id)
Check for the existence of a writer of the given id.
Definition: cs_post.c:5387
void cs_post_define_volume_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *cell_select_func, void *cell_select_input, bool time_varying, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a volume post-processing mesh using a selection function.
Definition: cs_post.c:4278
void cs_post_renum_cells(const cs_lnum_t init_cell_num[])
Update references to parent mesh of post-processing meshes in case of computational mesh cell renumbe...
Definition: cs_post.c:7028
bool cs_post_writer_is_active(int writer_id)
Query if a given writer is currently active.
Definition: cs_post.c:5555
void cs_post_time_step_begin(const cs_time_step_t *ts)
Check if post-processing is activated and then update post-processing of meshes if there is a need to...
Definition: cs_post.c:7487
