#include "cs_defs.h"#include "cs_mesh.h"#include "fvm_defs.h"#include "fvm_group.h"#include "fvm_io_num.h"
Include dependency graph for fvm_nodal.h:Go to the source code of this file.
| fvm_nodal_t * | fvm_nodal_create (const char *name, int dim) |
| fvm_nodal_t * | fvm_nodal_destroy (fvm_nodal_t *this_nodal) |
| fvm_nodal_t * | fvm_nodal_copy (const fvm_nodal_t *this_nodal) |
| void | fvm_nodal_reduce (fvm_nodal_t *this_nodal, int del_vertex_num) |
| void | fvm_nodal_change_parent_id (fvm_nodal_t *this_nodal, const cs_lnum_t new_parent_id[], int entity_dim) |
| void | fvm_nodal_remove_parent_id (fvm_nodal_t *this_nodal, int entity_dim) |
| void | fvm_nodal_init_io_num (fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_numbers[], int entity_dim) |
| void | fvm_nodal_transfer_vertex_io_num (fvm_nodal_t *this_nodal, fvm_io_num_t **io_num) |
| void | fvm_nodal_set_tag (fvm_nodal_t *this_nodal, const int tag[], int entity_dim) |
| void | fvm_nodal_remove_tag (fvm_nodal_t *this_nodal, int entity_dim) |
| void | fvm_nodal_define_vertex_list (fvm_nodal_t *this_nodal, cs_lnum_t n_vertices, cs_lnum_t parent_vertex_id[]) |
| void | fvm_nodal_set_shared_vertices (fvm_nodal_t *this_nodal, const cs_coord_t vertex_coords[]) |
| cs_coord_t * | fvm_nodal_transfer_vertices (fvm_nodal_t *this_nodal, cs_coord_t vertex_coords[]) |
| void | fvm_nodal_make_vertices_private (fvm_nodal_t *this_nodal) |
| void | fvm_nodal_set_group_class_set (fvm_nodal_t *this_nodal, const fvm_group_class_set_t *gc_set) |
| void | fvm_nodal_transfer_global_vertex_labels (fvm_nodal_t *this_nodal, char *g_labels[]) |
| const char * | fvm_nodal_get_name (const fvm_nodal_t *this_nodal) |
| int | fvm_nodal_get_dim (const fvm_nodal_t *this_nodal) |
| int | fvm_nodal_get_max_entity_dim (const fvm_nodal_t *this_nodal) |
| cs_lnum_t | fvm_nodal_get_n_entities (const fvm_nodal_t *this_nodal, int entity_dim) |
| cs_gnum_t | fvm_nodal_get_n_g_vertices (const fvm_nodal_t *this_nodal) |
| cs_gnum_t | fvm_nodal_get_n_g_elements (const fvm_nodal_t *this_nodal, fvm_element_t element_type) |
| cs_lnum_t | fvm_nodal_get_n_elements (const fvm_nodal_t *this_nodal, fvm_element_t element_type) |
| void | fvm_nodal_get_parent_num (const fvm_nodal_t *this_nodal, int entity_dim, cs_lnum_t parent_num[]) |
| void | fvm_nodal_get_parent_id (const fvm_nodal_t *this_nodal, int entity_dim, cs_lnum_t parent_id[]) |
| const char ** | fvm_nodal_get_global_vertex_labels (const fvm_nodal_t *this_nodal) |
| const cs_mesh_t * | fvm_nodal_get_parent (const fvm_nodal_t *this_nodal) |
| void | fvm_nodal_set_parent (fvm_nodal_t *this_nodal, const cs_mesh_t *parent) |
| void | fvm_nodal_tesselate (fvm_nodal_t *this_nodal, fvm_element_t type, cs_lnum_t *error_count) |
| fvm_nodal_t * | fvm_nodal_copy_edges (const char *name, const fvm_nodal_t *this_nodal) |
| void | fvm_nodal_dump (const fvm_nodal_t *this_nodal) |
| const int | fvm_nodal_n_vertices_element [] |
| void fvm_nodal_change_parent_id | ( | fvm_nodal_t * | this_nodal, |
| const cs_lnum_t | new_parent_id[], | ||
| int | entity_dim | ||
| fvm_nodal_t* fvm_nodal_copy | ( | const fvm_nodal_t * | this_nodal | ) |
| fvm_nodal_t* fvm_nodal_copy_edges | ( | const char * | name, |
| const fvm_nodal_t * | this_nodal | ||
| fvm_nodal_t* fvm_nodal_create | ( | const char * | name, |
| int | dim | ||
| void fvm_nodal_define_vertex_list | ( | fvm_nodal_t * | this_nodal, |
| cs_lnum_t | n_vertices, | ||
| cs_lnum_t | parent_vertex_id[] | ||
| fvm_nodal_t* fvm_nodal_destroy | ( | fvm_nodal_t * | this_nodal | ) |
| void fvm_nodal_dump | ( | const fvm_nodal_t * | this_nodal | ) |
| int fvm_nodal_get_dim | ( | const fvm_nodal_t * | this_nodal | ) |
| const char** fvm_nodal_get_global_vertex_labels | ( | const fvm_nodal_t * | this_nodal | ) |
| int fvm_nodal_get_max_entity_dim | ( | const fvm_nodal_t * | this_nodal | ) |
| cs_lnum_t fvm_nodal_get_n_elements | ( | const fvm_nodal_t * | this_nodal, |
| fvm_element_t | element_type | ||
| cs_lnum_t fvm_nodal_get_n_entities | ( | const fvm_nodal_t * | this_nodal, |
| cs_gnum_t fvm_nodal_get_n_g_elements | ( | const fvm_nodal_t * | this_nodal, |
| cs_gnum_t fvm_nodal_get_n_g_vertices | ( | const fvm_nodal_t * | this_nodal | ) |
| const char* fvm_nodal_get_name | ( | const fvm_nodal_t * | this_nodal | ) |
| const cs_mesh_t* fvm_nodal_get_parent | ( | const fvm_nodal_t * | this_nodal | ) |
| void fvm_nodal_get_parent_id | ( | const fvm_nodal_t * | this_nodal, |
| int | entity_dim, | ||
| cs_lnum_t | parent_id[] | ||
| void fvm_nodal_get_parent_num | ( | const fvm_nodal_t * | this_nodal, |
| cs_lnum_t | parent_num[] | ||
| void fvm_nodal_init_io_num | ( | fvm_nodal_t * | this_nodal, |
| const cs_gnum_t | parent_global_numbers[], | ||
| void fvm_nodal_make_vertices_private | ( | fvm_nodal_t * | this_nodal | ) |
| void fvm_nodal_reduce | ( | fvm_nodal_t * | this_nodal, |
| int | del_vertex_num | ||
| void fvm_nodal_remove_parent_id | ( | fvm_nodal_t * | this_nodal, |
| void fvm_nodal_remove_tag | ( | fvm_nodal_t * | this_nodal, |
| void fvm_nodal_set_group_class_set | ( | fvm_nodal_t * | this_nodal, |
| const fvm_group_class_set_t * | gc_set | ||
| void fvm_nodal_set_parent | ( | fvm_nodal_t * | this_nodal, |
| const cs_mesh_t * | parent | ||
| void fvm_nodal_set_shared_vertices | ( | fvm_nodal_t * | this_nodal, |
| const cs_coord_t | vertex_coords[] | ||
| void fvm_nodal_set_tag | ( | fvm_nodal_t * | this_nodal, |
| const int | tag[], | ||
| void fvm_nodal_tesselate | ( | fvm_nodal_t * | this_nodal, |
| fvm_element_t | type, | ||
| cs_lnum_t * | error_count | ||
| void fvm_nodal_transfer_global_vertex_labels | ( | fvm_nodal_t * | this_nodal, |
| char * | g_labels[] | ||
| void fvm_nodal_transfer_vertex_io_num | ( | fvm_nodal_t * | this_nodal, |
| fvm_io_num_t ** | io_num | ||
| cs_coord_t* fvm_nodal_transfer_vertices | ( | fvm_nodal_t * | this_nodal, |
| const int fvm_nodal_n_vertices_element[] |
