1 #ifndef __FVM_NODAL_H__ 2 #define __FVM_NODAL_H__ 581 const fvm_nodal_t *this_nodal);
void fvm_nodal_get_parent_id(const fvm_nodal_t *this_nodal, int entity_dim, cs_lnum_t parent_id[])
Definition: fvm_nodal.c:2158
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
void fvm_nodal_reduce(fvm_nodal_t *this_nodal, int del_vertex_num)
Definition: fvm_nodal.c:1327
fvm_nodal_t * fvm_nodal_copy(const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:1250
cs_gnum_t fvm_nodal_get_n_g_elements(const fvm_nodal_t *this_nodal, fvm_element_t element_type)
Definition: fvm_nodal.c:2032
void fvm_nodal_remove_tag(fvm_nodal_t *this_nodal, int entity_dim)
Definition: fvm_nodal.c:1576
void fvm_nodal_change_parent_id(fvm_nodal_t *this_nodal, const cs_lnum_t new_parent_id[], int entity_dim)
Definition: fvm_nodal.c:1383
void fvm_nodal_transfer_vertex_io_num(fvm_nodal_t *this_nodal, fvm_io_num_t **io_num)
Definition: fvm_nodal.c:1529
Definition: fvm_nodal_priv.h:159
Definition: cs_defs.h:512
cs_coord_t * fvm_nodal_transfer_vertices(fvm_nodal_t *this_nodal, cs_coord_t vertex_coords[])
Definition: fvm_nodal.c:1688
void fvm_nodal_set_group_class_set(fvm_nodal_t *this_nodal, const fvm_group_class_set_t *gc_set)
Definition: fvm_nodal.c:1799
const cs_coord_t * vertex_coords
Definition: fvm_nodal_priv.h:183
char * name
Definition: fvm_nodal_priv.h:164
cs_lnum_t fvm_nodal_get_n_elements(const fvm_nodal_t *this_nodal, fvm_element_t element_type)
Definition: fvm_nodal.c:2061
double cs_coord_t
Definition: cs_defs.h:320
void fvm_nodal_get_parent_num(const fvm_nodal_t *this_nodal, int entity_dim, cs_lnum_t parent_num[])
Definition: fvm_nodal.c:2097
void fvm_nodal_dump(const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:2622
fvm_nodal_t * fvm_nodal_destroy(fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:1194
fvm_element_t
Definition: fvm_defs.h:48
cs_lnum_t fvm_nodal_get_n_entities(const fvm_nodal_t *this_nodal, int entity_dim)
Definition: fvm_nodal.c:1977
const cs_lnum_t * parent_vertex_id
Definition: fvm_nodal_priv.h:189
void fvm_nodal_set_shared_vertices(fvm_nodal_t *this_nodal, const cs_coord_t vertex_coords[])
Definition: fvm_nodal.c:1642
void fvm_nodal_transfer_global_vertex_labels(fvm_nodal_t *this_nodal, char *g_labels[])
Definition: fvm_nodal.c:1894
void fvm_nodal_make_vertices_private(fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:1744
cs_lnum_t n_vertices
Definition: fvm_nodal_priv.h:178
int fvm_nodal_get_max_entity_dim(const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:1949
void fvm_nodal_remove_parent_id(fvm_nodal_t *this_nodal, int entity_dim)
Definition: fvm_nodal.c:1438
fvm_group_class_set_t * gc_set
Definition: fvm_nodal_priv.h:219
const cs_mesh_t * fvm_nodal_get_parent(const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:2240
Definition: cs_defs.h:316
int fvm_nodal_get_dim(const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:1933
const int fvm_nodal_n_vertices_element[]
Definition: fvm_nodal.c:141
struct _fvm_io_num_t fvm_io_num_t
Definition: fvm_io_num.h:72
fvm_nodal_t * fvm_nodal_create(const char *name, int dim)
Definition: fvm_nodal.c:1134
void fvm_nodal_define_vertex_list(fvm_nodal_t *this_nodal, cs_lnum_t n_vertices, cs_lnum_t parent_vertex_id[])
Definition: fvm_nodal.c:1608
Definition: cs_defs.h:513
const char * fvm_nodal_get_name(const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:1915
void fvm_nodal_tesselate(fvm_nodal_t *this_nodal, fvm_element_t type, cs_lnum_t *error_count)
Definition: fvm_nodal.c:2278
Definition: fvm_group.h:60
void fvm_nodal_set_tag(fvm_nodal_t *this_nodal, const int tag[], int entity_dim)
Definition: fvm_nodal.c:1551
cs_gnum_t fvm_nodal_get_n_g_vertices(const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:2015
fvm_nodal_t * fvm_nodal_copy_edges(const char *name, const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:2327
const cs_mesh_t * parent
Definition: fvm_nodal_priv.h:231
void fvm_nodal_set_parent(fvm_nodal_t *this_nodal, const cs_mesh_t *parent)
Definition: fvm_nodal.c:2254
int dim
Definition: fvm_nodal_priv.h:166
const char ** fvm_nodal_get_global_vertex_labels(const fvm_nodal_t *this_nodal)
Definition: fvm_nodal.c:2222
void fvm_nodal_init_io_num(fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_numbers[], int entity_dim)
Definition: fvm_nodal.c:1481
