7.3
cs_function.h File Reference
#include "cs_mesh_location.h"
#include "cs_param_types.h"
#include "cs_restart_default.h"
+ Include dependency graph for cs_function.h:
Data Structures
struct  cs_function_t
Macros
#define CS_FUNCTION_INTENSIVE   (1 << 0)
#define CS_FUNCTION_EXTENSIVE   (1 << 1)
#define CS_FUNCTION_TIME_INDEPENDENT   (1 << 2)
#define CS_FUNCTION_USER   (1 << 3)
Typedefs
typedef void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
 Function pointer for evaluation of local function values. More...
cs_function_tcs_function_define_by_func (const char *name, int location_id, int dim, bool is_intensive, cs_datatype_t datatype, cs_eval_at_location_t *data_func, void *data_input)
 Define a function whose data values will be computed using the provided evaluation function. More...
cs_function_tcs_function_define_by_analytic_func (const char *name, int location_id, int dim, bool is_intensive, cs_analytic_func_t *data_func, void *data_input)
 Define a function whose data values will be computed using the provided "degree of freedom" type evaluation function. More...
cs_function_tcs_function_define_by_dof_func (const char *name, int location_id, int dim, bool is_intensive, cs_dof_func_t *data_func, void *data_input)
void cs_function_destroy_all (void)
 Destroy all functions management metadata. More...
int cs_function_n_functions (void)
 Return the number of defined functions. More...
cs_function_tcs_function_by_id (int id)
 Return a pointer to a function object based on its id. More...
cs_function_tcs_function_by_name (const char *name)
 Return a pointer to a function object based on its name. More...
cs_function_tcs_function_by_name_try (const char *name)
 Return a pointer to a function object based on its name if present. More...
void cs_function_set_label (cs_function_t *f, const char *label)
 Assig a label to a function object. More...
void cs_function_log_defs (void)
 Log function definition setup information. More...
void cs_function_log_all_settings (void)
 Print info relative to all given function object settings to log file. More...
void cs_function_evaluate (const cs_function_t *f, const cs_time_step_t *ts, int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *vals)
 Evaluate function values. More...
Typedef Documentation
◆ cs_eval_at_location_t
If the matching values are multidimensional, they must be interleaved. The output values are assumed to use a dense storage (i.e. of size n_elts *
for the associated data type, in the same order as elt_ids if present.)
Note: if the input pointer is non-NULL, it must point to valid data when the selection function is called, so either:
  • that value or structure should not be temporary (i.e. local);
  • when a single integer identifier is needed, the input pointer can be set to that value instead of an actual address;
[in]location_idbase associated mesh location id
[in]n_eltsnumber of associated elements
[in]elt_idsids of associated elements, or NULL if no filtering is required
[in,out]inputpointer to optional (untyped) value or structure.
[in,out]valspointer to output values (size: n_elts*dimension)
◆ cs_function_by_id()
cs_function_t* cs_function_by_id ( int  id)
This function requires that a function of the given id is defined.
[in]idfunction id
pointer to the function structure
◆ cs_function_by_name()
cs_function_t* cs_function_by_name ( const char *  name)
This function requires that a function of the given name is defined.
[in]namefunction name
◆ cs_function_by_name_try()
cs_function_t* cs_function_by_name_try ( const char *  name)
If no function of the given name is defined, NULL is returned.
pointer to the function structure, or NULL
◆ cs_function_define_by_analytic_func()
cs_function_t* cs_function_define_by_analytic_func ( const char *  name,
int  location_id,
int  dim,
bool  is_intensive,
cs_analytic_func_t data_func,
void *  data_input
The provided function and optional associated input is of the same form as and may be shared with some boundary condition or property definitions.
[in]namename of associated function
[in]location_idid of associated mesh location
[in]dimdimension associated with element data
[in]is_intensiveis the function intensive?
[in]data_funcfunction used to define data values
[in]data_inputpointer to optional (untyped) value or structure to be used by data_func
pointer to the associated function object in case of success, or NULL in case of error
◆ cs_function_define_by_dof_func()
cs_function_t* cs_function_define_by_dof_func ( const char *  name,
int  location_id,
int  dim,
bool  is_intensive,
cs_dof_func_t data_func,
void *  data_input
◆ cs_function_define_by_func()
cs_function_t* cs_function_define_by_func ( const char *  name,
int  location_id,
int  dim,
bool  is_intensive,
cs_eval_at_location_t data_func,
void *  data_input
If of dimension > 1, the evaluated values are always interleaved.
[in]datatypeassociated data values type
◆ cs_function_destroy_all()
void cs_function_destroy_all ( void  )
◆ cs_function_evaluate()
void cs_function_evaluate ( const cs_function_t f,
const cs_time_step_t ts,
int  location_id,
cs_lnum_t  n_elts,
const cs_lnum_t elt_ids,
void *  vals
[in]fpointer to associated function handle
◆ cs_function_log_all_settings()
void cs_function_log_all_settings ( void  )
◆ cs_function_log_defs()
void cs_function_log_defs ( void  )
◆ cs_function_n_functions()
int cs_function_n_functions ( void  )
◆ cs_function_set_label()
void cs_function_set_label ( cs_function_t f,
const char *  label
[in,out]fpointer to associated function handle
[in]labelassociated label
