1 #ifndef __CS_FUNCTION_H__ 2 #define __CS_FUNCTION_H__ 62 #define CS_FUNCTION_INTENSIVE (1 << 0) 65 #define CS_FUNCTION_EXTENSIVE (1 << 1) 68 #define CS_FUNCTION_TIME_INDEPENDENT (1 << 2) 71 #define CS_FUNCTION_USER (1 << 3) cs_function_t * cs_function_by_name(const char *name)
Return a pointer to a function object based on its name.
Definition: cs_function.c:485
cs_restart_file_t restart_file
Definition: cs_function.h:142
cs_datatype_t
Definition: cs_defs.h:275
time step descriptor
Definition: cs_time_step.h:64
cs_function_t * cs_function_define_by_dof_func(const char *name, int location_id, int dim, bool is_intensive, cs_dof_func_t *data_func, void *data_input)
Define a function whose data values will be computed using the provided "degree of freedom" type eval...
Definition: cs_function.c:388
cs_eval_at_location_t * eval_func
Definition: cs_function.h:147
cs_function_t * cs_function_define_by_analytic_func(const char *name, int location_id, int dim, bool is_intensive, cs_analytic_func_t *data_func, void *data_input)
Definition: cs_function.c:346
void cs_function_evaluate(const cs_function_t *f, const cs_time_step_t *ts, int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *vals)
Evaluate function values.
Definition: cs_function.c:787
char * label
Definition: cs_function.h:118
Definition: cs_defs.h:512
const int location_id
Definition: cs_function.h:127
const cs_datatype_t datatype
Definition: cs_function.h:129
cs_function_t * cs_function_by_id(int id)
Return a pointer to a function object based on its id.
Definition: cs_function.c:461
cs_function_t * cs_function_by_name_try(const char *name)
Return a pointer to a function object based on its name if present.
Definition: cs_function.c:511
int log
Definition: cs_function.h:135
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
cs_dof_func_t * dof_func
Definition: cs_function.h:151
void cs_function_log_defs(void)
Log function definition setup information.
Definition: cs_function.c:545
Definition: cs_function.h:115
int time_stamp
Definition: cs_function.h:139
void * func_input
Definition: cs_function.h:154
int cs_function_n_functions(void)
Return the number of defined functions.
Definition: cs_function.c:443
const char * name
Definition: cs_function.h:117
void cs_function_destroy_all(void)
Destroy all functions management metadata.
Definition: cs_function.c:414
void cs_function_set_label(cs_function_t *f, const char *label)
Assig a label to a function object.
Definition: cs_function.c:531
Definition: cs_defs.h:316
Definition: cs_defs.h:513
void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition: cs_function.h:106
const int id
Definition: cs_function.h:121
int type
Definition: cs_function.h:122
int post_vis
Definition: cs_function.h:131
char * label
Definition: keywords.h:71
const int dim
Definition: cs_function.h:124
cs_function_t * cs_function_define_by_func(const char *name, int location_id, int dim, bool is_intensive, cs_datatype_t datatype, cs_eval_at_location_t *data_func, void *data_input)
Define a function whose data values will be computed using the provided evaluation function...
Definition: cs_function.c:303
cs_restart_file_t
Definition: cs_restart_default.h:54
cs_analytic_func_t * analytic_func
Definition: cs_function.h:149
void cs_function_log_all_settings(void)
Print info relative to all given function object settings to log file.
Definition: cs_function.c:693
