Build an algebraic CDO face-based system for the Navier-Stokes equations and solved it with a monolithic approach. More...
#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <float.h>#include <assert.h>#include <string.h>#include <bft_mem.h>#include "cs_blas.h"#include "cs_cdo_bc.h"#include "cs_cdo_blas.h"#include "cs_cdofb_priv.h"#include "cs_cdofb_scaleq.h"#include "cs_cdofb_vecteq.h"#include "cs_cdofb_navsto.h"#include "cs_cdofb_monolithic_sles.h"#include "cs_equation_bc.h"#include "cs_equation_builder.h"#include "cs_equation_priv.h"#include "cs_evaluate.h"#include "cs_log.h"#include "cs_navsto_coupling.h"#include "cs_parall.h"#include "cs_post.h"#include "cs_sdm.h"#include "cs_solid_selection.h"#include "cs_source_term.h"#include "cs_static_condensation.h"#include "cs_timer.h"#include "cs_cdofb_monolithic_priv.h"#include "cs_cdofb_monolithic.h"
Include dependency graph for cs_cdofb_monolithic.c:Macros | |
| #define | CS_CDOFB_MONOLITHIC_DBG 0 |
| void | cs_cdofb_monolithic_init_sharing (const cs_navsto_param_t *nsp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step) |
| Set shared pointers from the main domain members. More... | |
| void | cs_cdofb_monolithic_finalize_common (const cs_navsto_param_t *nsp) |
| Free shared pointers with lifecycle dedicated to this file. More... | |
| void * | cs_cdofb_monolithic_init_scheme_context (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *bf_type, void *cc_context) |
| Initialize a cs_cdofb_monolithic_t structure. More... | |
| void * | cs_cdofb_monolithic_free_scheme_context (void *scheme_context) |
| Destroy a cs_cdofb_monolithic_t structure. More... | |
| void | cs_cdofb_monolithic_steady (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context) |
| Solve the steady Stokes or Oseen system with a CDO face-based scheme using a monolithic approach and GKB algorithm. More... | |
| void | cs_cdofb_monolithic_steady_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context) |
| Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach and Picard iterations to solve the non-linearities arising from the advection term. More... | |
| void | cs_cdofb_monolithic (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context) |
| Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach. According to the settings, this function can handle either an implicit Euler time scheme or more generally a theta time scheme. More... | |
| void | cs_cdofb_monolithic_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context) |
| Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach. According to the settings, this function can handle either an implicit Euler time scheme or more generally a theta time scheme. Rely on Picard iterations to solve the non-linearities arising from the advection term. More... | |
| #define CS_CDOFB_MONOLITHIC_DBG 0 |
| void cs_cdofb_monolithic | ( | const cs_mesh_t * | mesh, |
| [in] | scheme_context | pointer to a structure cast on-the-fly |
| void cs_cdofb_monolithic_finalize_common | ( | const cs_navsto_param_t * | nsp | ) |
| [in] | nsp | pointer to NavSto parameter settings |
| void* cs_cdofb_monolithic_free_scheme_context | ( | void * | scheme_context | ) |
| [in] | scheme_context | pointer to a scheme context structure to free |
| void* cs_cdofb_monolithic_init_scheme_context | ( | const cs_navsto_param_t * | nsp, |
| cs_adv_field_t * | adv_field, | ||
| cs_real_t * | mflux, | ||
| cs_real_t * | mflux_pre, | ||
| cs_boundary_type_t * | bf_type, | ||
| void * | cc_context | ||
| [in] | mflux | current values of the mass flux across primal faces |
| [in] | mflux_pre | current values of the mass flux across primal faces |
| [in] | bf_type | type of boundary for each boundary face |
| [in] | cc_context | pointer to a cs_navsto_monolithic_t structure |
| void cs_cdofb_monolithic_init_sharing | ( | const cs_navsto_param_t * | nsp, |
| void cs_cdofb_monolithic_nl | ( | const cs_mesh_t * | mesh, |
| void cs_cdofb_monolithic_steady | ( | const cs_mesh_t * | mesh, |
Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach.
| void cs_cdofb_monolithic_steady_nl | ( | const cs_mesh_t * | mesh, |
