7.2
cs_timer.h
1 #ifndef __CS_TIMER_H__
2 #define __CS_TIMER_H__
5  * Program timing information
31  * Local headers
34 #include "cs_defs.h"
41  * Public types
44 /* Information structure for precise timings */
45
46 typedef struct {
48  long long sec; /* seconds */
49  long long nsec; /* nanoseconds */
50
51 } cs_timer_t;
52
53 /* Information structure for timing counters */
54
55 typedef struct {
56
57  long long nsec; /* wall-time nanoseconds */
58
60
61 /*============================================================================
62  * Public macros
63  *============================================================================*/
64
65 /*----------------------------------------------------------------------------
66  * Initialize timer counter.
67  *
68  * parameters:
69  * _t --> resulting counter.
70  *----------------------------------------------------------------------------*/
71
72 #define CS_TIMER_COUNTER_INIT(_t) \
73  (_t.nsec = 0)
74
75 /*----------------------------------------------------------------------------
76  * Add timer counter.
77  *
78  * The result may be identical to one of the 2 counters to add.
79  *
80  * parameters:
81  * _res --> resulting counter.
82  * _c0 <-- counter to add.
83  * _c1 <-- counter to add.
84  *----------------------------------------------------------------------------*/
85
86 #define CS_TIMER_COUNTER_ADD(_res, _c0, _c1) \
87  (_res.nsec = _c0.nsec + _c1.nsec)
88
89 /*============================================================================
90  * Public function prototypes
91  *============================================================================*/
92
93 /*----------------------------------------------------------------------------
94  * Return Wall clock time
95  *
96  * returns:
97  * elapsed time from first call of a function of the cs_timer_...()
98  * series, or -1 if unable to compute.
99  *----------------------------------------------------------------------------*/
100
101 double
102 cs_timer_wtime(void);
103
104 /*----------------------------------------------------------------------------
105  * Return CPU time.
106  *
107  * Note that in the rare case that only the minimal C library clock()
108  * method is available (see cs_timer_cpu_time_method()), at least one of
109  * the cs_timer_...() functions (possibly this one) must be called
110  * upon program start for this function to be used. In addition,
111  * in this case, time may "loop" back to 0 every multiple of
112  * 2^size_t / CLOCKS_PER_SEC seconds.
113  *
114  * returns:
115  * current CPU time usage, or -1 if unable to compute.
116  *----------------------------------------------------------------------------*/
117
118 double
119 cs_timer_cpu_time(void);
120
121 /*----------------------------------------------------------------------------
122  * Return separate user and system CPU times.
123  *
124  * parameters:
125  * user_time --> current user CPU usage.
126  * system_time --> current system CPU usage.
127  *----------------------------------------------------------------------------*/
128
129 void
130 cs_timer_cpu_times(double *user_time,
131  double *system_time);
132
133 /*----------------------------------------------------------------------------
134  * Return a timer's value
135  *
136  * returns:
137  * timer structure.
138  *----------------------------------------------------------------------------*/
139
141 cs_timer_time(void);
142
143 /*----------------------------------------------------------------------------
144  * Compute the difference between 2 timers.
145  *
146  * parameters:
147  * t0 <-- oldest timer value
148  * t1 <-- most recent timer value
149  *
150  * returns:
151  * last - first timer value.
152  *----------------------------------------------------------------------------*/
153
156  const cs_timer_t *t1);
157
158 /*----------------------------------------------------------------------------
159  * Add the the difference between 2 timers to a counter.
160  *
161  * parameters:
162  * tc <-> pointer to timer counter
163  * t0 <-- oldest timer value
164  * t1 <-- most recent timer value
165  *
166  * returns:
167  * last - first timer value.
168  *----------------------------------------------------------------------------*/
169
170 static inline void
172  const cs_timer_t *t0,
173  const cs_timer_t *t1)
174 {
175  tc->nsec += (t1->sec - t0->sec) * (long long)1000000000
176  + t1->nsec - t0->nsec;
177 }
178
179 /*----------------------------------------------------------------------------
180  * Return method used to return wall clock time.
181  *
182  * Note that in the rare case that only the minimal C library clock()
183  * method is available, this function will return -1 values.
184  *
185  * returns:
186  * short description of method used to return wall clock time.
187  *----------------------------------------------------------------------------*/
188
189 const char *
191
192 /*----------------------------------------------------------------------------
193  * Return method used to return CPU time.
194  *
195  * returns:
196  * short description of method used to return CPU time.
197  *----------------------------------------------------------------------------*/
198
199 const char *
201
202 /*----------------------------------------------------------------------------*/
203
205
206 #endif /* __CS_TIMER_H__ */
static void cs_timer_counter_add_diff(cs_timer_counter_t *tc, const cs_timer_t *t0, const cs_timer_t *t1)
Definition: cs_timer.h:171
Definition: cs_timer.h:46
double cs_timer_cpu_time(void)
Return CPU time.
Definition: cs_timer.c:527
const char * cs_timer_cpu_time_method(void)
Definition: cs_timer.c:685
void cs_timer_cpu_times(double *user_time, double *system_time)
Definition: cs_timer.c:560
long long nsec
Definition: cs_timer.h:49
cs_timer_counter_t cs_timer_diff(const cs_timer_t *t0, const cs_timer_t *t1)
Definition: cs_timer.c:637
long long nsec
Definition: cs_timer.h:57
real(c_double), pointer, save t0
reference temperature.
Definition: cstphy.f90:215
const char * cs_timer_wtime_method(void)
Definition: cs_timer.c:657
cs_timer_t cs_timer_time(void)
Return a timer&#39;s value.
Definition: cs_timer.c:609
double cs_timer_wtime(void)
Return Wall clock time.
Definition: cs_timer.c:491
long long sec
Definition: cs_timer.h:48
Definition: cs_timer.h:55
