1 #ifndef __CS_SOURCE_TERM_H__ 2 #define __CS_SOURCE_TERM_H__ 49 #define CS_N_MAX_SOURCE_TERMS 8 // Max number of source terms in an equation 156 const int n_source_terms,
void cs_source_term_dcsd_q5o3_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it to the given array of values...
Definition: cs_source_term.c:1931
cs_flag_t cs_source_term_get_flag(const cs_xdef_t *st)
Get metadata related to the given source term structure.
Definition: cs_source_term.c:635
void cs_source_term_pcvd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2543
cs_eflag_t cs_source_term_init(cs_param_space_scheme_t space_scheme, const int n_source_terms, cs_xdef_t *const *source_terms, cs_source_term_cellwise_t *compute_source[], cs_flag_t *sys_flag, cs_mask_t *source_mask[])
Initialize data to build the source terms.
Definition: cs_source_term.c:660
void cs_source_term_hhovd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution of a source term for a cell and add it to the given array of values...
Definition: cs_source_term.c:3019
unsigned char cs_mask_t
Definition: cs_flag.h:158
void cs_source_term_dcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1530
void cs_source_term_pvsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:991
void cs_source_term_hhosd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2902
void cs_source_term_dcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1215
void cs_source_term_dcsd_q10o2_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1719
void cs_source_term_pvsp_by_c2v_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1161
void cs_source_term_dcsd_q1o1_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1640
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
void cs_source_term_pcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2149
void cs_source_term_dfsf_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:3132
void cs_source_term_dcsd_by_pv_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1296
Definition: cs_param_types.h:207
void cs_source_term_set_reduction(cs_xdef_t *st, cs_flag_t flag)
Set advanced parameters which are defined by default in a source term structure.
Definition: cs_source_term.c:578
void cs_source_term_dcsd_by_c2v_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution of a source term in a cell and add it to the given array of values...
Definition: cs_source_term.c:1337
void cs_source_term_dcsd_none_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1478
void cs_source_term_pcvd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2236
void cs_source_term_vcsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2088
void cs_source_term_pvsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1047
void cs_source_term_pcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it the given array of values...
Definition: cs_source_term.c:2287
void cs_source_term_pcsd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2187
void cs_source_term_hhosd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2772
Definition: cs_cdo_local.h:60
Definition: cs_xdef.h:154
void cs_source_term_dcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1255
void cs_source_term_pcsd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2375
void cs_source_term_set_default_flag(cs_param_space_scheme_t scheme, cs_flag_t *state_flag, cs_flag_t *meta_flag)
Set the default flag related to a source term according to the numerical scheme chosen for discretizi...
Definition: cs_source_term.c:532
void cs_source_term_pcvd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2593
unsigned short int cs_flag_t
Definition: cs_defs.h:324
void cs_source_term_compute_cellwise(const int n_source_terms, cs_xdef_t *const *source_terms, const cs_cell_mesh_t *cm, const cs_mask_t *source_mask, cs_source_term_cellwise_t *compute_source[], cs_real_t time_eval, void *input, cs_cell_builder_t *cb, cs_real_t *result)
Compute the local contributions of source terms in a cell.
Definition: cs_source_term.c:926
unsigned int cs_eflag_t
Definition: cs_flag.h:187
void cs_source_term_dcsd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1427
void cs_source_term_pvsp_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1102
void cs_source_term_pcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2328
void cs_source_term_pcvd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2727
void cs_source_term_vcsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2032
void cs_source_term_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_source_term.c:513
void() cs_source_term_cellwise_t(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.h:70
void cs_source_term_pcsd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2501
void cs_source_term_dcsd_by_pc_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1386
