Structure storing the parameters related to the resolution of the Navier-Stokes system. More...
#include <cs_navsto_param.h>
Collaboration diagram for cs_navsto_param_t:Structure storing the parameters related to the resolution of the Navier-Stokes system.
| adv_extrapol |
Extrapolation used to estimate the advection field
| adv_form |
Type of formulation for the advection term
| adv_scheme |
Type of scheme for the advection term
| adv_strategy |
Strategy to handle the advection term
| const cs_boundary_t* boundaries |
| cs_navsto_param_boussinesq_t* boussinesq_param |
| coupling |
Choice of algorithm for solving the system
| delta_thermal_tolerance |
Value under which one considers that the thermal equation is converged max_{c Cells} |T_c - T_{ref}|/|T_{ref}| < eps => stop iteration
| dof_reduction_mode |
How are defined the Degrees of freedom
| gd_scale_coef |
Default value to set the scaling of the grad-div term when an artificial compressibility algorithm or an Uzawa-Augmented Lagrangian method is used
| lam_viscosity |
Laminar viscosity
| mass_density |
Mass_density of the fluid, pointer to cs_property_t used in several terms in the Navier-Stokes equations
| model |
Modelling related to the Navier-Stokes system of equations
| model_flag |
Flag storing high-level option related to the Navier-Stokes system
| int n_boussinesq_terms |
| n_max_outer_iter |
Stopping crierion related to the maximum number of outer iterations allowed. This outer iteration encompasses the Navier-Stokes system, and (according to the case settings) the turbulence system and/or the thermal system.
| n_pressure_bc_defs |
Number of boundary conditions associated to the pressure field.
| n_pressure_ic_defs |
Number of initial conditions associated to the pressure
| n_velocity_bc_defs |
Number of definitions related to the settings of the boundary conditions for the velocity field.
| n_velocity_ic_defs |
Number of initial conditions associated to the velocity
| phys_constants |
Main physical constants (gravity vector and Coriolis source term). This structure is shared with the legacy part.
| post_flag |
Flag storing which predefined post-processing has to be done
| pressure_bc_defs |
Pointers to the definitions of the boundary conditions associated to the pressure field.
| pressure_bc_is_owner |
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t if an equation solves the pressure field.
| pressure_ic_defs |
Pointers to the definitions of the initial conditions associated to the pressure. In order to force a zero-mean pressure, the code can compute the average of the resulting pressure and subtract it
| pressure_ic_is_owner |
| qtype |
A cs_quadrature_type_t indicating the type of quadrature to use in all functions involving quadratures
| reference_pressure |
Value of the reference pressure p0 (used for rescaling or during update of physical quantities). By default: 0.
| sles_param |
Set of choices to control the resolution of the Navier–Stokes system
| space_scheme |
Discretization scheme for space
| theta |
Value of the parameter for the time scheme when a theta-scheme is used
| time_scheme |
Discretization scheme for time
| tot_viscosity |
Laminar viscosity + if needed the turbulent viscosity Pointer to cs_property_t associated to the diffusion term for the momentum equation
| turbulence |
Structure storing all information needed to set the turbulence modelling
| velocity_bc_defs |
Array of pointers to the definition of boundary conditions for the velocity field
| velocity_bc_is_owner |
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t Most of the time this should be false since an equation is associated to to the resolution of the velocity field (the momentum equation).
| velocity_ic_defs |
Pointers to the definitions of the initial conditions associated to the velocity. The code does not check if the resulting initial velocity satisfies the divergence constraint.
| velocity_ic_is_owner |
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a cs_equation_param_t structure dedicated to the momentum equation.
| verbosity |
Level of display of the information related to the Navier-Stokes system
