7.2
cs_navsto_param.h
1 #ifndef __CS_NAVSTO_PARAM_H__
2 #define __CS_NAVSTO_PARAM_H__
5  * Functions to handle cs_navsto_param_t structure
29  * Local headers
32 #include "cs_boundary.h"
33 #include "cs_cdo_turbulence.h"
34 #include "cs_equation_param.h"
35 #include "cs_iter_algo.h"
36 #include "cs_math.h"
37 #include "cs_param_sles.h"
38 #include "cs_physical_constants.h"
45  * Macro definitions
48 /* Manage the naming of properties, variables and equations related to the
49  * Navier-Stokes module
50  */
51
52 #define CS_NAVSTO_STREAM_EQNAME "streamfunction_eq"
53
55  * Type definitions
57
60
82 typedef enum {
83
87
89
91
131 typedef enum {
132
133  CS_NAVSTO_MODEL_STEADY = 1<<0, /* = 1 */
137  CS_NAVSTO_MODEL_BOUSSINESQ = 1<<4, /* = 16 */
139
141
188 typedef enum {
189
191  CS_NAVSTO_POST_KINETIC_ENERGY = 1<< 1, /* = 2 */
192  CS_NAVSTO_POST_VORTICITY = 1<< 2, /* = 4 */
194  CS_NAVSTO_POST_STREAM_FUNCTION = 1<< 4, /* = 16 */
195  CS_NAVSTO_POST_HELICITY = 1<< 5, /* = 32 */
196  CS_NAVSTO_POST_ENSTROPHY = 1<< 6, /* = 64 */
197  CS_NAVSTO_POST_MASS_DENSITY = 1<< 7, /* = 128 */
199  CS_NAVSTO_POST_PRESSURE_GRADIENT = 1<< 9, /* = 512 */
200
202
442 typedef enum {
443
459  CS_NAVSTO_SLES_NOTAY_TRANSFORM, /* experimental */
467
469
471
476 typedef struct {
477
483
489
504
511
526
534
541
551
555
570 typedef enum {
571
575
577
579
585 typedef struct {
586
587  cs_real_t beta; /* Dilatation coefficient */
588  cs_real_t var0; /* Reference value of the variable */
589
590  /* Array of values of the variable (for instance the temperature). This is a
591  * shared pointer. The lifecycle of this array is not managed by this
592  * structure.
593  */
594
595  const cs_real_t *var;
596
598
604 typedef struct {
605
618
624
630
643
650
658
664
677
683
691
702
708
726
727  /* Boussinesq approximation:
728  *
729  * Take into account buoyancy terms (variation of mass density w.r.t. the
730  * variation of a field (for instance the temperature but can be also a
731  * concentration as in segregation model in the solidification module)
732  *
733  * \var n_boussinesq_terms
734  * Number of contributions to the buoyancy source term in the Boussinesq
735  * approximation
736  *
737  * \var boussinesq_param
738  * Structure storing elements used to compute the Boussinesq approximation
739  */
740
743
750
756
763
772
783
789
819
837
846  /* \var boundaries
847  * Pointer to a \ref cs_boundary_t structure shared with the domain
848  */
850
869
886
898
902
1019 typedef enum {
1020
1048
1050
1051 } cs_navsto_key_t;
1052
1053 /*============================================================================
1054  * Inline static public function prototypes
1055  *============================================================================*/
1056
1057 /*----------------------------------------------------------------------------*/
1066 /*----------------------------------------------------------------------------*/
1067
1068 static inline bool
1070 {
1071  if (nsp == NULL)
1072  return true;
1073
1075  return true;
1076  else
1077  return false;
1078 }
1079
1080 /*============================================================================
1081  * Public function prototypes
1082  *============================================================================*/
1083
1084 /*----------------------------------------------------------------------------*/
1093 /*----------------------------------------------------------------------------*/
1094
1095 double
1097
1098  /*----------------------------------------------------------------------------*/
1107 /*----------------------------------------------------------------------------*/
1108
1109 void
1110 cs_navsto_param_set_notay_scaling(double scaling_coef);
1111
1112 /*----------------------------------------------------------------------------*/
1125 /*----------------------------------------------------------------------------*/
1126
1128 cs_navsto_param_create(const cs_boundary_t *boundaries,
1130  cs_navsto_param_model_flag_t model_flag,
1131  cs_navsto_param_coupling_t algo_coupling,
1132  cs_navsto_param_post_flag_t post_flag);
1133
1134 /*----------------------------------------------------------------------------*/
1142 /*----------------------------------------------------------------------------*/
1143
1146
1147 /*----------------------------------------------------------------------------*/
1156 /*----------------------------------------------------------------------------*/
1157
1158 void
1160  cs_navsto_key_t key,
1161  const char *keyval);
1162
1163 /*----------------------------------------------------------------------------*/
1171 /*----------------------------------------------------------------------------*/
1172
1173 void
1175  cs_equation_param_t *eqp);
1176
1177 /*----------------------------------------------------------------------------*/
1183 /*----------------------------------------------------------------------------*/
1184
1185 void
1187
1188 /*----------------------------------------------------------------------------*/
1196 /*----------------------------------------------------------------------------*/
1197
1200  cs_real_t dilatation_coef,
1201  cs_real_t reference_value);
1202
1203 /*----------------------------------------------------------------------------*/
1210 /*----------------------------------------------------------------------------*/
1211
1212 void
1214  const cs_real_t *var);
1215
1216 /*----------------------------------------------------------------------------*/
1225 /*----------------------------------------------------------------------------*/
1226
1229
1230 /*----------------------------------------------------------------------------*/
1239 /*----------------------------------------------------------------------------*/
1240
1243
1244 /*----------------------------------------------------------------------------*/
1252 /*----------------------------------------------------------------------------*/
1253
1254 const char *
1256
1257 /*----------------------------------------------------------------------------*/
1265 /*----------------------------------------------------------------------------*/
1266
1267 const char *
1269
1270 /*----------------------------------------------------------------------------*/
1277 /*----------------------------------------------------------------------------*/
1278
1279 void
1281  cs_real_t pref);
1282
1283 /*----------------------------------------------------------------------------*/
1297 /*----------------------------------------------------------------------------*/
1298
1299 cs_xdef_t *
1301  const char *z_name,
1302  cs_real_t *val);
1303
1304 /*----------------------------------------------------------------------------*/
1319 /*----------------------------------------------------------------------------*/
1320
1321 cs_xdef_t *
1323  const char *z_name,
1324  cs_analytic_func_t *analytic,
1325  void *input);
1326
1327 /*----------------------------------------------------------------------------*/
1341 /*----------------------------------------------------------------------------*/
1342
1343 cs_xdef_t *
1345  const char *z_name,
1346  cs_real_t *val);
1347
1348 /*----------------------------------------------------------------------------*/
1363 /*----------------------------------------------------------------------------*/
1364
1365 cs_xdef_t *
1367  const char *z_name,
1368  cs_analytic_func_t *analytic,
1369  void *input);
1370
1371 /*----------------------------------------------------------------------------*/
1379 /*----------------------------------------------------------------------------*/
1380
1381 void
1383
1384 /*----------------------------------------------------------------------------*/
1392 /*----------------------------------------------------------------------------*/
1393
1394 void
1396
1397 /*----------------------------------------------------------------------------*/
1405 /*----------------------------------------------------------------------------*/
1406
1407 void
1409
1410 /*----------------------------------------------------------------------------*/
1421 /*----------------------------------------------------------------------------*/
1422
1423 cs_xdef_t *
1425  const char *z_name,
1426  cs_real_t *values);
1427
1428 /*----------------------------------------------------------------------------*/
1440 /*----------------------------------------------------------------------------*/
1441
1442 cs_xdef_t *
1444  const char *z_name,
1445  cs_real_t *values);
1446
1447 /*----------------------------------------------------------------------------*/
1459 /*----------------------------------------------------------------------------*/
1460
1461 cs_xdef_t *
1463  const char *z_name,
1464  cs_real_t *values);
1465
1466 /*----------------------------------------------------------------------------*/
1479 /*----------------------------------------------------------------------------*/
1480
1481 cs_xdef_t *
1483  const char *z_name,
1484  cs_analytic_func_t *ana,
1485  void *input);
1486
1487 /*----------------------------------------------------------------------------*/
1504 /*----------------------------------------------------------------------------*/
1505
1506 cs_xdef_t *
1508  const char *z_name,
1509  cs_flag_t loc,
1510  cs_real_t *array,
1511  bool is_owner,
1512  const cs_lnum_t *index,
1513  const cs_lnum_t *ids);
1514
1515 /*----------------------------------------------------------------------------*/
1527 /*----------------------------------------------------------------------------*/
1528
1529 cs_xdef_t *
1531  const char *z_name,
1532  cs_dof_func_t *func,
1533  void *func_input);
1534
1535 /*----------------------------------------------------------------------------*/
1547 /*----------------------------------------------------------------------------*/
1548
1549 cs_xdef_t *
1551  const char *z_name,
1552  cs_analytic_func_t *ana,
1553  void *input);
1554
1555 /*----------------------------------------------------------------------------*/
1566 /*----------------------------------------------------------------------------*/
1567
1568 cs_xdef_t *
1570  const char *z_name,
1571  cs_real_t *val);
1572
1573 /*----------------------------------------------------------------------------*/
1589 /*----------------------------------------------------------------------------*/
1590
1591 cs_xdef_t *
1593  const char *z_name,
1594  cs_flag_t loc,
1595  cs_real_t *array,
1596  bool is_owner,
1597  const cs_lnum_t *index,
1598  const cs_lnum_t *ids);
1599
1600 /*----------------------------------------------------------------------------*/
1607 /*----------------------------------------------------------------------------*/
1608
1609 void
1611  cs_adv_field_t *adv_fld);
1612
1613 /*----------------------------------------------------------------------------*/
1614
1616
1617 #endif /* __CS_NAVSTO_PARAM_H__ */
void cs_navsto_param_transfer(const cs_navsto_param_t *nsp, cs_equation_param_t *eqp)
Apply the numerical settings defined for the Navier-Stokes system to an equation related to this syst...
Definition: cs_navsto_param.c:1332
Definition: cs_navsto_param.h:1047
Definition: cs_navsto_param.h:197
Definition: cs_navsto_param.h:455
void cs_navsto_param_log(const cs_navsto_param_t *nsp)
Summary of the main cs_navsto_param_t structure.
Definition: cs_navsto_param.c:1397
Definition: cs_navsto_param.h:1044
Definition: cs_navsto_param.h:1049
void cs_navsto_set_outlets(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to outlets into the set of parameters for the manag...
Definition: cs_navsto_param.c:2120
Definition: cs_navsto_param.h:1026
Definition: cs_navsto_param.h:1027
cs_navsto_param_sles_t * sles_param
Definition: cs_navsto_param.h:755
Definition: cs_navsto_param.h:1029
Structure storing the parameters related to the Boussinesq source term in the momentum equation...
Definition: cs_navsto_param.h:585
int n_velocity_ic_defs
Definition: cs_navsto_param.h:817
Definition: cs_navsto_param.h:454
Definition: cs_advection_field.h:150
cs_navsto_param_boussinesq_t * boussinesq_param
Definition: cs_navsto_param.h:742
Definition: cs_navsto_param.h:1039
Definition: cs_navsto_param.h:460
void cs_navsto_add_oseen_field(cs_navsto_param_t *nsp, cs_adv_field_t *adv_fld)
Add a advection field for the Oseen problem.
Definition: cs_navsto_param.c:2703
cs_navsto_param_t * cs_navsto_param_create(const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
Create a new structure to store all numerical parameters related to the resolution of the Navier-Stok...
Definition: cs_navsto_param.c:628
Definition: cs_navsto_param.h:136
cs_real_t reference_pressure
Definition: cs_navsto_param.h:897
Definition: cs_navsto_param.h:1036
void cs_navsto_param_set_notay_scaling(double scaling_coef)
Set the scaling coefficient used in the Notay&#39;s transformation devised in "Algebraic multigrid for St...
Definition: cs_navsto_param.c:607
Definition: cs_navsto_param.h:570
Definition: cs_navsto_param.h:463
Definition: cs_navsto_param.h:133
bool velocity_ic_is_owner
Definition: cs_navsto_param.h:816
Definition: cs_navsto_param.h:576
Definition: cs_navsto_param.h:468
Structure storing the parameters for solving the Navier-Stokes system.
Definition: cs_navsto_param.h:476
Definition: cs_navsto_param.h:458
Definition: cs_navsto_param.h:86
cs_xdef_t ** pressure_ic_defs
Definition: cs_navsto_param.h:836
int n_boussinesq_terms
Definition: cs_navsto_param.h:741
cs_xdef_t * cs_navsto_add_velocity_ic_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define the initial condition for the velocity unknowns. This definition can be done on a specified me...
Definition: cs_navsto_param.c:1844
Definition: cs_navsto_param.h:1046
cs_real_t beta
Definition: cs_navsto_param.h:587
Structure storing all the parameters to drive the algorithm called Anderson acceleration.
Definition: cs_iter_algo.h:177
Definition: cs_navsto_param.h:464
Definition: cs_navsto_param.h:444
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:546
cs_xdef_t * cs_navsto_add_source_term_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
Define a new source term structure defined by an analytical function.
Definition: cs_navsto_param.c:2609
Definition: cs_navsto_param.h:135
cs_xdef_t * cs_navsto_set_velocity_inlet_by_dof_func(cs_navsto_param_t *nsp, const char *z_name, cs_dof_func_t *func, void *func_input)
Define the velocity field for an inlet boundary using a DoF function.
Definition: cs_navsto_param.c:2537
Definition: cs_navsto_param.h:190
Definition: cs_navsto_param.h:449
Definition: cs_navsto_param.h:1022
Definition: cs_navsto_param.h:134
cs_quadrature_type_t qtype
Definition: cs_navsto_param.h:749
Definition: cs_navsto_param.h:1040
Definition: cs_navsto_param.h:1033
cs_real_t gd_scale_coef
Definition: cs_navsto_param.h:690
Definition: cs_navsto_param.h:465
Definition: cs_navsto_param.h:1042
void cs_navsto_set_fixed_walls(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to a fixed wall into the set of parameters for the ...
Definition: cs_navsto_param.c:2020
cs_property_t * mass_density
Definition: cs_navsto_param.h:649
int n_pressure_ic_defs
Definition: cs_navsto_param.h:835
Definition: cs_navsto_param.h:1031
cs_property_t * tot_viscosity
Definition: cs_navsto_param.h:657
static bool cs_navsto_param_is_steady(const cs_navsto_param_t *nsp)
Ask cs_navsto_param_t structure if the settings correspond to a steady computation.
Definition: cs_navsto_param.h:1069
cs_flag_t cs_navsto_param_post_flag_t
Definition: cs_navsto_param.h:59
cs_xdef_t * cs_navsto_add_source_term_by_val(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Define a new source term structure defined by a constant value.
Definition: cs_navsto_param.c:2644
void cs_navsto_param_set(cs_navsto_param_t *nsp, cs_navsto_key_t key, const char *keyval)
Set a parameter attached to a keyname in a cs_navsto_param_t structure.
Definition: cs_navsto_param.c:896
cs_xdef_t * cs_navsto_add_velocity_ic_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Definition: cs_navsto_param.c:1780
Definition: cs_navsto_param.h:573
cs_equation_param_t * cs_navsto_param_get_velocity_param(const cs_navsto_param_t *nsp)
Retrieve the cs_equation_param_t structure related to the velocity equation (momentum equation in mos...
Definition: cs_navsto_param.c:1664
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:155
Definition: cs_navsto_param.h:1024
Definition: cs_navsto_param.h:446
Definition: cs_navsto_param.h:1032
cs_param_advection_strategy_t
Choice of how to handle the advection term in an equation.
Definition: cs_param_types.h:379
cs_turbulence_param_t * turbulence
Definition: cs_navsto_param.h:629
Definition: cs_navsto_param.h:604
Structure and routines handling the SLES settings stored inside a cs_param_sles_t structure...
cs_xdef_t * cs_navsto_set_velocity_wall_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Define the velocity field for a sliding wall boundary using a uniform value.
Definition: cs_navsto_param.c:2264
cs_xdef_t ** velocity_bc_defs
Definition: cs_navsto_param.h:868
Definition: cs_defs.h:322
Definition: cs_navsto_param.h:457
Definition: cs_navsto_param.h:1034
const cs_real_t * var
Definition: cs_navsto_param.h:595
cs_real_t delta_thermal_tolerance
Definition: cs_navsto_param.h:762
Definition: cs_navsto_param.h:451
Definition: cs_navsto_param.h:1021
cs_param_nl_algo_t nl_algo_type
Definition: cs_navsto_param.h:525
cs_param_advection_extrapol_t
Choice of how to extrapolate the advection field in the advection term.
Definition: cs_param_types.h:413
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
Definition: cs_navsto_param.h:85
cs_real_t var0
Definition: cs_navsto_param.h:588
Definition: cs_navsto_param.h:195
cs_param_space_scheme_t
Definition: cs_param_types.h:207
Definition: cs_navsto_param.h:623
cs_param_schur_approx_t
Strategy to build the Schur complement approximation. This appears in block preconditioning or uzawa ...
Definition: cs_param_types.h:657
Definition: cs_quadrature.h:52
Definition: cs_navsto_param.h:1035
cs_xdef_t * cs_navsto_set_velocity_inlet_by_array(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, const cs_lnum_t *index, const cs_lnum_t *ids)
Define the velocity field for an inlet boundary using an array of values.
Definition: cs_navsto_param.c:2465
cs_navsto_key_t
List of available keys for setting the parameters of the Navier-Stokes system.
Definition: cs_navsto_param.h:1019
Definition: cs_navsto_param.h:1023
void cs_navsto_set_reference_pressure(cs_navsto_param_t *nsp, cs_real_t pref)
Set the value to consider for the reference pressure.
Definition: cs_navsto_param.c:1754
Definition: cs_navsto_param.h:194
bool velocity_bc_is_owner
Definition: cs_navsto_param.h:866
cs_param_time_scheme_t time_scheme
Definition: cs_navsto_param.h:700
Definition: cs_navsto_param.h:1030
Definition: cs_navsto_param.h:456
const cs_boundary_t * boundaries
Definition: cs_navsto_param.h:849
Definition: cs_navsto_param.h:88
cs_xdef_t * cs_navsto_set_velocity_inlet_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Define the velocity field for an inlet boundary using a uniform value.
Definition: cs_navsto_param.c:2325
cs_navsto_param_post_bit_t
Bit values for additional generic postprocessing related to the Navier-Stokes module. In what follows, w denotes the vorticity vector, u the velocity vector and k the kinetic energy defined by .
Definition: cs_navsto_param.h:188
cs_property_t * lam_viscosity
Definition: cs_navsto_param.h:663
Definition: cs_navsto_param.h:198
cs_xdef_t * cs_navsto_add_source_term_by_array(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, const cs_lnum_t *index, const cs_lnum_t *ids)
Define a new source term structure defined by an array.
Definition: cs_navsto_param.c:2675
cs_param_schur_approx_t schur_approximation
Definition: cs_navsto_param.h:488
Definition: cs_navsto_param.h:617
Definition: cs_navsto_param.h:788
Definition: cs_navsto_param.h:466
cs_param_advection_extrapol_t adv_extrapol
Definition: cs_navsto_param.h:725
Structure storing the parameters related to the resolution of the turbulence modelling. Several members are structures defined in cs_turbulence_model.h as a global variable. The purpose of this structure is to store all parameters in one place.
Definition: cs_cdo_turbulence.h:64
cs_xdef_t ** velocity_ic_defs
Definition: cs_navsto_param.h:818
cs_param_advection_form_t adv_form
Definition: cs_navsto_param.h:722
Definition: cs_navsto_param.h:447
cs_xdef_t * cs_navsto_add_pressure_ic_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Define the initial condition for the pressure unknowns. This definition can be done on a specified me...
Definition: cs_navsto_param.c:1917
Definition: cs_navsto_param.h:1038
bool pressure_ic_is_owner
Definition: cs_navsto_param.h:834
Definition: cs_navsto_param.h:1045
Definition: cs_navsto_param.h:137
void cs_navsto_set_symmetries(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to a symmetry into the set of parameters for the ma...
Definition: cs_navsto_param.c:2069
Definition: cs_xdef.h:154
Definition: cs_navsto_param.h:459
Definition: cs_navsto_param.h:448
cs_real_t theta
Definition: cs_navsto_param.h:701
Definition: cs_navsto_param.h:1037
int il_algo_restart
Definition: cs_navsto_param.h:510
cs_param_advection_strategy_t adv_strategy
Definition: cs_navsto_param.h:724
cs_xdef_t * cs_navsto_set_velocity_inlet_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
Define the velocity field for an inlet boundary using an analytical function.
Definition: cs_navsto_param.c:2388
cs_iter_algo_param_t il_algo_param
Definition: cs_navsto_param.h:503
const char * cs_navsto_param_get_coupling_name(cs_navsto_param_coupling_t coupling)
Retrieve the name of the coupling algorithm.
Definition: cs_navsto_param.c:1727
cs_xdef_t * cs_navsto_add_pressure_ic_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Definition: cs_navsto_param.c:1967
cs_navsto_sles_t
High-level information about the way of settings the SLES for solving the Navier-Stokes system...
Definition: cs_navsto_param.h:442
cs_navsto_param_sles_t * cs_navsto_param_get_sles_param(const cs_navsto_param_t *nsp)
Definition: cs_navsto_param.c:1644
Definition: cs_navsto_param.h:445
bool pressure_bc_is_owner
Definition: cs_navsto_param.h:883
Definition: cs_navsto_param.h:452
Definition: cs_defs.h:316
double cs_navsto_param_get_notay_scaling(void)
Retrieve the scaling coefficient used in the Notay&#39;s transformation devised in "Algebraic multigrid f...
Definition: cs_navsto_param.c:590
cs_xdef_t ** pressure_bc_defs
Definition: cs_navsto_param.h:885
int n_pressure_bc_defs
Definition: cs_navsto_param.h:884
cs_navsto_param_model_bit_t
Bit values for additional physical modelling related to the Navier-Stokes system of equations...
Definition: cs_navsto_param.h:131
Definition: cs_navsto_param.h:196
unsigned short int cs_flag_t
Definition: cs_defs.h:324
cs_navsto_param_t * cs_navsto_param_free(cs_navsto_param_t *param)
Free a cs_navsto_param_t structure.
Definition: cs_navsto_param.c:812
cs_param_dof_reduction_t
Definition: cs_param_types.h:234
cs_iter_algo_param_t nl_algo_param
Definition: cs_navsto_param.h:533
Physical constants descriptor.
Definition: cs_physical_constants.h:51
int verbosity
Definition: cs_navsto_param.h:782
Definition: cs_iter_algo.h:53
Definition: cs_navsto_param.h:462
cs_param_sles_t * schur_sles_param
Definition: cs_navsto_param.h:550
const char * cs_navsto_param_get_model_name(cs_navsto_param_model_t model)
Retrieve the name of the model system of equations.
Definition: cs_navsto_param.c:1699
cs_navsto_param_boussinesq_t * cs_navsto_param_add_boussinesq_term(cs_navsto_param_t *nsp, cs_real_t dilatation_coef, cs_real_t reference_value)
Add a new Boussinesq term (source term for the momemtum equation)
Definition: cs_navsto_param.c:1587
int n_velocity_bc_defs
Definition: cs_navsto_param.h:867
Definition: cs_navsto_param.h:574
Definition: cs_navsto_param.h:572
Definition: cs_navsto_param.h:453
Definition: cs_navsto_param.h:138
cs_param_advection_scheme_t
Definition: cs_param_types.h:346
Definition: cs_navsto_param.h:193
cs_iter_algo_param_aa_t anderson_param
Definition: cs_navsto_param.h:540
Definition: cs_navsto_param.h:1043
Definition: cs_navsto_param.h:191
Definition: cs_navsto_param.h:1041
cs_param_dof_reduction_t dof_reduction_mode
Definition: cs_navsto_param.h:676
Definition: cs_navsto_param.h:1028
Describe the system of equations related to the Navier-Stokes to be solved.
Definition: cs_navsto_param.h:82
int n_max_outer_iter
Definition: cs_navsto_param.h:771
Definition: cs_param_types.h:269
Definition: cs_navsto_param.h:199
cs_navsto_sles_t strategy
Definition: cs_navsto_param.h:482
Definition: cs_param_types.h:302
Definition: cs_navsto_param.h:1025
cs_flag_t cs_navsto_param_model_flag_t
cs_xdef_t * cs_navsto_set_pressure_bc_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Set the pressure field on a boundary using a uniform value.
Definition: cs_navsto_param.c:2175
cs_physical_constants_t * phys_constants
Definition: cs_navsto_param.h:642
Structure storing all metadata related to the resolution of a linear system with an iterative solver...
Definition: cs_param_sles.h:62
void cs_navsto_param_set_boussinesq_array(cs_navsto_param_boussinesq_t *bp, const cs_real_t *var)
Set the array of values to consider in the Boussinesq term.
Definition: cs_navsto_param.c:1622
Definition: cs_navsto_param.h:461
cs_param_advection_scheme_t adv_scheme
Definition: cs_navsto_param.h:723
Definition: cs_navsto_param.h:682
cs_param_space_scheme_t space_scheme
Definition: cs_navsto_param.h:707
Definition: cs_navsto_param.h:192
Definition: cs_navsto_param.h:450
