| struct | cs_turbulence_param_t |
| | Structure storing the parameters related to the resolution of the turbulence modelling. Several members are structures defined in cs_turbulence_model.h as a global variable. The purpose of this structure is to store all parameters in one place. More...
| struct | cs_turbulence_t |
| cs_turbulence_param_t * | cs_turbulence_param_create (void) |
| | Allocate the structure storing the set of parameters for the turbulence modelling. More...
| cs_turbulence_t * | cs_turbulence_create (cs_turbulence_param_t *tbp) |
| | Allocate the structure managing the turbulence modelling. More...
| void | cs_turbulence_free (cs_turbulence_t **p_turb_struct) |
| | Free the structure managing the turbulence modelling. More...
| void | cs_turbulence_init_setup (cs_turbulence_t *tbs, cs_equation_t *mom_eq) |
| | Initialize the structure managing the turbulence modelling. More...
| void | cs_turbulence_finalize_setup (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
| | Finalize the setup of the turbulence modelling and especially the equations/properties and other related quantities. More...
| void | cs_turbulence_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
| | Initialize the values of quantities related to a turbulence model. More...
| void * | cs_turb_init_k_eps_context (const cs_turb_model_t *tbm) |
| | Allocate and initialize the context structure related to the k-epsilon turbulence model. More...
| void * | cs_turb_free_k_eps_context (void *tbc) |
| | Free the context structure related to the k-epsilon turbulence model. More...
| void | cs_turb_compute_k_eps (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
| | Compute for the current time step the new state for the turbulence model. This means that all related equations are built and then solved. More...
| void | cs_turb_update_k_eps (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs) |
| | Update for the current time step the new state for the turbulence model. This is used to update the turbulent viscosity. More...
◆ CS_NAVSTO_LAM_VISCOSITY
| #define CS_NAVSTO_LAM_VISCOSITY "laminar_viscosity" |
◆ CS_NAVSTO_TOTAL_VISCOSITY
| #define CS_NAVSTO_TOTAL_VISCOSITY "total_viscosity" |
◆ CS_NAVSTO_TURB_VISCOSITY
| #define CS_NAVSTO_TURB_VISCOSITY "turbulent_viscosity" |
◆ cs_turb_compute_t
- Parameters
| [in] | time_step | structure managing the time stepping |
| [in,out] | tbs | pointer to turbulence structure |
◆ cs_turb_free_context_t
| typedef void*() cs_turb_free_context_t(void *turb_context) |
Free the context structure related to a given turbulence modelling.
- Parameters
| [in,out] | tbc | pointer to a structure cast on-the-fly to free |
- Returns
- a NULL pointer
◆ cs_turb_init_context_t
Allocate and initialize the context structure related to a given turbulence modelling.
- Parameters
- Returns
- a pointer to a new allocated turbulence context structure
◆ cs_turb_update_t
Update properties, arrays related to the turbulent variables.
- Parameters
◆ cs_turb_compute_k_eps()
- Parameters
◆ cs_turb_free_k_eps_context()
| void* cs_turb_free_k_eps_context |
void * |
tbc | ) |
- Parameters
| [in,out] | tbc | pointer to a structure context cast on-the-fly |
- Returns
- a NULL pointer
◆ cs_turb_init_k_eps_context()
- Parameters
| [in] | tbm | structure which defines the turbulence model |
- Returns
- a pointer to a new allocated context structure
◆ cs_turb_update_k_eps()
- Parameters
◆ cs_turbulence_create()
- Parameters
- Returns
- a pointer to a new allocated cs_turbulence_t structure
◆ cs_turbulence_finalize_setup()
- Parameters
◆ cs_turbulence_free()
- Parameters
| [in,out] | p_turb_struct | pointer to the structure to free |
◆ cs_turbulence_init_setup()
- Parameters
| [in,out] | tbs | pointer to the structure to initialize |
| [in] | mom_eq | pointer to the structure mom_eq |
◆ cs_turbulence_init_values()
- Parameters
◆ cs_turbulence_param_create()
- Returns
- a pointer to a new allocated cs_turbulence_param_t structure
