1 #ifndef __CS_CDOFB_PRIV_H__ 2 #define __CS_CDOFB_PRIV_H__ 129 cs_cdofb_priv_t *eqc);
cs_cdo_enforce_bc_t * enforce_dirichlet
Definition: cs_cdofb_priv.h:85
cs_lnum_t n_faces
Definition: cs_cdofb_priv.h:60
void() cs_cdofb_adv_close_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Operation done after the matrix related to the advection term has been defined.
Definition: cs_cdo_advection.h:136
void() cs_cdofb_adv_build_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Build the cellwise advection operator for CDO-Fb schemes The local matrix related to this operator is...
Definition: cs_cdo_advection.h:116
cs_real_t * rc_tilda
Definition: cs_cdofb_priv.h:70
cs_hodge_t ** diffusion_hodge
Definition: cs_cdofb_priv.h:83
void() cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Enforcement of a boundary condition (Dirichlet, Robin, sliding...)
Definition: cs_equation_bc.h:89
int var_field_id
Definition: cs_cdofb_priv.h:55
cs_hodge_compute_t * get_mass_matrix
Definition: cs_cdofb_priv.h:105
cs_cdofb_adv_scheme_t * advection_scheme
Definition: cs_cdofb_priv.h:97
cs_hodge_compute_t * get_stiffness_matrix
Definition: cs_cdofb_priv.h:84
cs_hodge_param_t mass_hodgep
Definition: cs_cdofb_priv.h:103
Definition: cs_hodge.h:186
cs_cdofb_adv_close_hook_t * advection_close
Definition: cs_cdofb_priv.h:96
cs_hodge_t ** mass_hodge
Definition: cs_cdofb_priv.h:104
Definition: cs_defs.h:322
int bflux_field_id
Definition: cs_cdofb_priv.h:56
cs_cdo_enforce_bc_t * enforce_sliding
Definition: cs_cdofb_priv.h:87
cs_real_t * face_values_pre
Definition: cs_cdofb_priv.h:66
void * advection_input
Definition: cs_cdofb_priv.h:99
cs_real_t * source_terms
Definition: cs_cdofb_priv.h:79
cs_lnum_t n_dofs
Definition: cs_cdofb_priv.h:61
cs_real_t * acf_tilda
Definition: cs_cdofb_priv.h:71
cs_cdo_enforce_bc_t * enforce_robin_bc
Definition: cs_cdofb_priv.h:86
void() cs_cdofb_adv_open_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb)
Perform preprocessing such as the computation of the advection flux at the expected location in order...
Definition: cs_cdo_advection.h:71
Definition: cs_defs.h:316
void() cs_cdofb_adv_scheme_t(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Define the local convection operator in CDO-Fb schemes. Case of an operator that should be assemble i...
Definition: cs_cdo_advection.h:92
cs_cdofb_adv_open_hook_t * advection_open
Definition: cs_cdofb_priv.h:94
Definition: cs_cdofb_priv.h:51
bool() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell...
Definition: cs_hodge.h:221
void cs_cdofb_set_advection_function(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, cs_cdofb_priv_t *eqc)
Set the advection-related parameters in the context structure of CDO face-based schemes.
Definition: cs_cdofb_priv.c:90
Definition: cs_cdofb_priv.h:65
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator...
Definition: cs_hodge.h:154
cs_cdofb_adv_build_t * advection_main
Definition: cs_cdofb_priv.h:95
