7.1
cs_volume_mass_injection.c File Reference
#include "cs_array.h"
#include "cs_field_pointer.h"
#include "cs_math.h"
#include "cs_time_step.h"
#include "cs_volume_mass_injection.h"
+ Include dependency graph for cs_volume_mass_injection.c:
void cs_f_volume_mass_injection_get_arrays (int var_id, cs_lnum_t *ncesmp, cs_lnum_t **icetsm, int **itpsmp, cs_real_t **smcelp)
void cs_volume_mass_injection_flag_zones (void)
 Flag volume zones with the appropriate CS_VOLUME_ZONE_MASS_SOURCE_TERM flag when at least one volume mass injection on that zone is present. More...
void cs_volume_mass_injection_build_lists (cs_lnum_t n_cells, cs_lnum_t cell_num[], int cell_zone_id[])
 Build the list and zone ids of cells with volume mass injection. More...
void cs_volume_mass_injection_eval (int nvar, cs_lnum_t ncesmp, int itypsm[], cs_real_t smacel[])
 Evaluate contributions to volume mass injection. More...
void cs_volume_mass_injection_get_arrays (const cs_field_t *f, cs_lnum_t *ncesmp, cs_lnum_t **icetsm, int **itpsmp, cs_real_t **smcelp, cs_real_t **gamma)
 Return pointers to the mass source term arrays. More...
Volume mass injection and associated source terms computation.
◆ cs_f_volume_mass_injection_get_arrays()
void cs_f_volume_mass_injection_get_arrays ( int  var_id,
cs_lnum_t ncesmp,
cs_lnum_t **  icetsm,
int **  itpsmp,
cs_real_t **  smcelp
◆ cs_volume_mass_injection_build_lists()
void cs_volume_mass_injection_build_lists ( cs_lnum_t  n_cells,
int  cell_zone_id[]
[in]n_cellsnumber of cells in mass source term zones
[out]cell_numnumbers (1-based) cells in mass source term zones
[out]cell_zone_idassociated zone ids
◆ cs_volume_mass_injection_eval()
void cs_volume_mass_injection_eval ( int  nvar,
cs_lnum_t  ncesmp,
int  itypsm[],
cs_real_t  smacel[]
[in]nvartotal number of variables
[in]ncesmpnumber of cells with mass source term
[in]itypsmmass source type for the working variable size: [nvar][ncesmp]
[in]smacelvalues of the variables associated to the mass source (for the pressure variable, smacel is the mass flux) size: [nvar][ncesmp]
◆ cs_volume_mass_injection_flag_zones()
void cs_volume_mass_injection_flag_zones ( void  )
This is necessary for the reverse zone indexing required by the legacy code to function with defintions that are partially unrolled an not purely zone-based.
◆ cs_volume_mass_injection_get_arrays()
void cs_volume_mass_injection_get_arrays ( const cs_field_t f,
cs_lnum_t ncesmp,
int **  itpsmp,
cs_real_t **  smcelp,
cs_real_t **  gamma
[in]fpointer to associated field
[out]ncesmpnumber of cells with mass source terms
[out]icetsmpointet to source mass cells list (1-based numbering)
[out]itpsmpmass source type for the working variable (see cs_user_mass_source_terms)
[out]s_typemass source types (0: ambient value, 1: s_val value)
[out]smcelppointer to mass source values
[out]gammapointer to flow mass value
