1 #ifndef __CS_EQUATION_PARAM_H__ 2 #define __CS_EQUATION_PARAM_H__ 86 #define CS_EQUATION_LOCKED (1 << 0) 87 #define CS_EQUATION_UNSTEADY (1 << 1) 88 #define CS_EQUATION_CONVECTION (1 << 2) 89 #define CS_EQUATION_DIFFUSION (1 << 3) 90 #define CS_EQUATION_CURLCURL (1 << 4) 91 #define CS_EQUATION_GRADDIV (1 << 5) 92 #define CS_EQUATION_REACTION (1 << 6) 93 #define CS_EQUATION_FORCE_VALUES (1 << 7) 94 #define CS_EQUATION_USER_HOOK (1 << 8) 95 #define CS_EQUATION_USER_TRIGGERED (1 << 9) 117 #define CS_EQUATION_POST_BALANCE (1 << 0) 118 #define CS_EQUATION_POST_PECLET (1 << 1) 119 #define CS_EQUATION_POST_UPWIND_COEF (1 << 2) 120 #define CS_EQUATION_POST_NORMAL_FLUX (1 << 3) 1141 assert(eqp != NULL);
1158 assert(eqp != NULL);
1178 assert(eqp != NULL);
1198 assert(eqp != NULL);
1218 assert(eqp != NULL);
1238 assert(eqp != NULL);
1258 assert(eqp != NULL);
1278 assert(eqp != NULL);
1299 assert(eqp != NULL);
1320 assert(eqp != NULL);
1346 assert(eqp != NULL);
1372 if (eqp->
name == NULL)
1374 if (strcmp(eqp->
name, name) == 0)
1419 cs_equation_create_param(
const char *name,
1548 const char *keyval);
1839 const char *z_name);
1857 const char *z_name);
1872 const char *z_name);
cs_param_advection_strategy_t adv_strategy
Definition: cs_equation_param.h:645
Definition: cs_equation_param.h:1102
cs_hodge_param_t graddiv_hodgep
Definition: cs_equation_param.h:602
cs_adv_field_t * adv_field
Definition: cs_equation_param.h:648
cs_enforcement_param_t * cs_equation_add_face_dof_enforcement(cs_equation_param_t *eqp, cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t ref_value[], const cs_real_t face_values[])
Add an enforcement of the value of degrees of freedom located at the mesh faces. The spatial discreti...
Definition: cs_equation_param.c:3296
#define restrict
Definition: cs_defs.h:142
int imligr
Definition: cs_equation_param.h:452
Definition: cs_equation_param.h:1090
cs_real_t theta
Definition: cs_equation_param.h:556
Definition: cs_equation_param.h:1107
cs_xdef_t * cs_equation_add_volume_mass_injection_by_qov(cs_equation_param_t *eqp, const char *z_name, double *quantity)
Add a new volume mass injection definition source term by initializing a cs_xdef_t structure...
Definition: cs_equation_param.c:3045
int iwgrec
Definition: cs_equation_param.h:454
Definition: cs_advection_field.h:149
cs_flag_t flag
Definition: cs_equation_param.h:206
int ndircl
Definition: cs_equation_param.h:440
Definition: cs_equation_param.h:1110
cs_flag_t process_flag
Definition: cs_equation_param.h:213
Definition: cs_field.h:125
int imvisf
Definition: cs_equation_param.h:450
cs_xdef_t ** ic_defs
Definition: cs_equation_param.h:521
cs_param_advection_form_t adv_formulation
Definition: cs_equation_param.h:643
int verbosity
Definition: cs_equation_param.h:197
cs_param_assemble_omp_strategy_t
Definition: cs_param_cdo.h:92
Definition: cs_equation_param.h:177
Definition: cs_equation_param.h:1092
Definition: cs_equation_param.h:1088
cs_xdef_t * cs_equation_add_bc_by_dof_func(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
Define and initialize a new structure to set a boundary condition related to the given cs_equation_pa...
Definition: cs_equation_param.c:2373
cs_equation_type_t type
Definition: cs_equation_param.h:185
void cs_equation_param_set(cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
Set a parameter attached to a keyname in a cs_equation_param_t structure.
Definition: cs_equation_param.c:1514
Definition: cs_equation_param.h:1120
The term related to the curl-curl operator is needed.
Definition: cs_equation_param.h:90
cs_xdef_t * cs_equation_add_ic_by_value(cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
Define the initial condition for the unknown related to this equation This definition can be done on ...
Definition: cs_equation_param.c:1916
cs_param_dof_reduction_t dof_reduction
Definition: cs_equation_param.h:218
Definition: cs_equation_param.h:163
cs_param_bc_enforce_t
Definition: cs_param_types.h:483
cs_param_space_scheme_t space_scheme
Definition: cs_equation_param.h:217
void cs_equation_param_copy_from(const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fid)
Copy the settings from one cs_equation_param_t structure to another one. The name is not copied...
Definition: cs_equation_param.c:1234
cs_real_t upwind_portion
Definition: cs_equation_param.h:647
Definition: cs_equation_param.h:1112
double epsilo
Definition: cs_equation_param.h:459
double epsrgr
Definition: cs_equation_param.h:461
int istat
Definition: cs_equation_param.h:438
int space_poly_degree
Definition: cs_equation_param.h:224
cs_property_t ** reaction_properties
Definition: cs_equation_param.h:672
cs_xdef_t ** volume_mass_injections
Definition: cs_equation_param.h:709
cs_xdef_t * cs_equation_add_bc_by_field(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_field_t *field)
Define and initialize a new structure to set a boundary condition related to the given equation struc...
Definition: cs_equation_param.c:2224
void cs_equation_add_curlcurl(cs_equation_param_t *eqp, cs_property_t *property, int inversion)
Associate a new term related to the curl-curl operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.c:2598
cs_param_advection_extrapol_t adv_extrapol
Definition: cs_equation_param.h:646
Definition: cs_equation_param.h:1099
int imrgra
Definition: cs_equation_param.h:451
cs_real_t strong_pena_bc_coeff
Definition: cs_equation_param.h:505
Definition: cs_equation_param.h:1097
cs_property_t * curlcurl_property
Definition: cs_equation_param.h:587
cs_xdef_t * cs_equation_add_bc_by_value(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values)
Definition: cs_equation_param.c:2085
Definition: cs_equation_param.h:1095
cs_xdef_t * cs_equation_add_source_term_by_val(cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a constant value...
Definition: cs_equation_param.c:2768
int n_enforcements
Definition: cs_equation_param.h:729
cs_enforcement_param_t * cs_equation_add_cell_enforcement(cs_equation_param_t *eqp, cs_lnum_t n_cells, const cs_lnum_t elt_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[])
Add an enforcement of the value related to the degrees of freedom associated to the list of selected ...
Definition: cs_equation_param.c:3365
cs_param_time_scheme_t time_scheme
Definition: cs_equation_param.h:555
Choice of how to handle the advection term in an equation.
Definition: cs_param_types.h:352
Activate a user hook to get a fine control of the discretization process during the cellwise building...
Definition: cs_equation_param.h:94
Definition: cs_equation_param.h:1103
Structure and routines handling the SLES settings stored inside a cs_param_sles_t structure...
cs_equation_param_t * cs_equation_param_create(const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc)
Create a cs_equation_param_t structure.
Definition: cs_equation_param.c:1047
cs_xdef_t * cs_equation_add_bc_by_array(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index)
Definition: cs_equation_param.c:2146
Definition: cs_defs.h:322
Unsteady term is needed.
Definition: cs_equation_param.h:87
Definition: cs_equation_param.h:1115
cs_property_t * time_property
Definition: cs_equation_param.h:554
Definition: cs_equation_param.h:1091
cs_real_t weak_pena_bc_coeff
Definition: cs_equation_param.h:506
void cs_equation_param_set_sles(cs_equation_param_t *eqp)
Set parameters for initializing SLES structures used for the resolution of the linear system...
Definition: cs_equation_param.c:1550
Choice of how to extrapolate the advection field in the advection term.
Definition: cs_param_types.h:386
Definition: cs_equation_param.h:1117
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
void cs_equation_add_sliding_condition(cs_equation_param_t *eqp, const char *z_name)
Define and initialize a new structure to set a sliding boundary condition related to the given equati...
Definition: cs_equation_param.c:2531
Definition: cs_equation_param.h:162
void cs_equation_param_clear(cs_equation_param_t *eqp)
Free the contents of a cs_equation_param_t.
Definition: cs_equation_param.c:1406
Definition: cs_equation_param.h:1118
Definition: cs_equation_param.h:160
void cs_equation_remove_bc(cs_equation_param_t *eqp, const char *z_name)
Remove boundary condition from the given equation param structure for a given zone.
Definition: cs_equation_param.c:2487
Definition: cs_param_types.h:180
cs_equation_param_t * cs_equation_param_free(cs_equation_param_t *eqp)
Free a cs_equation_param_t.
Definition: cs_equation_param.c:1490
cs_enforcement_param_t ** enforcement_params
Definition: cs_equation_param.h:730
bool cs_equation_param_has_robin_bc(const cs_equation_param_t *eqp)
Ask if the parameter settings of the equation has requested the treatment of Robin boundary condition...
Definition: cs_equation_param.c:1885
cs_xdef_t ** source_terms
Definition: cs_equation_param.h:689
int icoupl
Definition: cs_equation_param.h:455
int n_volume_mass_injections
Definition: cs_equation_param.h:708
Convection term is needed.
Definition: cs_equation_param.h:88
Definition: cs_equation_param.h:1116
int iconv
Definition: cs_equation_param.h:437
Definition: cs_param_types.h:100
Definition: cs_equation_param.h:1094
double climgr
Definition: cs_equation_param.h:462
double thetav
Definition: cs_equation_param.h:456
int cs_equation_add_reaction(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the reaction operator for the equation associated to the given cs_equ...
Definition: cs_equation_param.c:2730
Definition: cs_equation_param.h:1100
double blend_st
Definition: cs_equation_param.h:458
cs_xdef_t * cs_equation_add_source_term_by_dof_func(cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a DoF function...
Definition: cs_equation_param.c:2874
cs_param_assemble_omp_strategy_t omp_assembly_choice
Definition: cs_equation_param.h:755
Definition: cs_equation_param.h:1105
int dim
Definition: cs_equation_param.h:1113
Definition: cs_equation_param.h:1089
Definition: cs_equation_param.h:1096
int ircflu
Definition: cs_equation_param.h:453
cs_xdef_t * cs_equation_add_bc_by_analytic(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define and initialize a new structure to set a boundary condition related to the given equation param...
Definition: cs_equation_param.c:2293
cs_property_t * diffusion_property
Definition: cs_equation_param.h:571
Definition: cs_equation_param.h:1106
double blencv
Definition: cs_equation_param.h:457
int idften
Definition: cs_equation_param.h:443
Definition: cs_equation_param.h:1093
char *restrict name
Definition: cs_equation_param.h:184
cs_property_t * adv_scaling_property
Definition: cs_equation_param.h:649
Definition: cs_equation_param.h:1101
Definition: cs_equation_param.h:1108
cs_xdef_t * cs_equation_add_source_term_by_array(cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an array...
Definition: cs_equation_param.c:2935
void cs_equation_add_xdef_bc(cs_equation_param_t *eqp, cs_xdef_t *xdef)
Set a boundary condition from an existing cs_xdef_t structure The lifecycle of the cs_xdef_t structur...
Definition: cs_equation_param.c:2057
int n_ic_defs
Definition: cs_equation_param.h:520
Definition: cs_equation_param.h:159
cs_xdef_t * cs_equation_add_ic_by_qov(cs_equation_param_t *eqp, const char *z_name, double quantity)
Definition: cs_equation_param.c:1964
Definition: cs_xdef.h:154
int ischcv
Definition: cs_equation_param.h:445
The term related to the grad-div operator is needed.
Definition: cs_equation_param.h:91
int n_source_terms
Definition: cs_equation_param.h:688
Add an algebraic manipulation to set the value of a given set of interior degrees of freedom...
Definition: cs_equation_param.h:93
int nswrgr
Definition: cs_equation_param.h:448
cs_property_t * graddiv_property
Definition: cs_equation_param.h:603
cs_hodge_param_t curlcurl_hodgep
Definition: cs_equation_param.h:586
int iwarni
Definition: cs_equation_param.h:198
cs_equation_key_t
List of available keys for setting the parameters of an equation.
Definition: cs_equation_param.h:1086
Definition: cs_equation_param.h:158
int idircl
Definition: cs_equation_param.h:439
cs_equation_type_t
Type of equations managed by the solver.
Definition: cs_equation_param.h:156
cs_param_sles_t * sles_param
Definition: cs_equation_param.h:744
void cs_equation_add_time(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the time derivative operator for the equation associated to the given...
Definition: cs_equation_param.c:2655
int isstpc
Definition: cs_equation_param.h:447
void cs_equation_add_advection(cs_equation_param_t *eqp, cs_adv_field_t *adv_field)
Associate a new term related to the advection operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.c:2680
int nswrsm
Definition: cs_equation_param.h:449
Definition: cs_equation_param.h:164
cs_param_bc_enforce_t default_enforcement
Definition: cs_equation_param.h:504
Definition: cs_defs.h:316
int n_reaction_terms
Definition: cs_equation_param.h:671
cs_param_advection_scheme_t adv_scheme
Definition: cs_equation_param.h:644
int iswdyn
Definition: cs_equation_param.h:444
int n_bc_defs
Definition: cs_equation_param.h:501
int ibdtso
Definition: cs_equation_param.h:446
Definition: cs_equation_param.h:166
cs_xdef_t * cs_equation_add_source_term_by_analytic(cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an analytical fu...
Definition: cs_equation_param.c:2817
unsigned short int cs_flag_t
Definition: cs_defs.h:324
Definition: cs_param_types.h:207
cs_param_bc_type_t
Definition: cs_param_types.h:439
double relaxv
Definition: cs_equation_param.h:463
int idifft
Definition: cs_equation_param.h:442
cs_xdef_t * cs_equation_add_ic_by_analytic(cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define the initial condition for the unknown related to this equation. This definition can be done on...
Definition: cs_equation_param.c:2011
Definition: cs_param_types.h:354
cs_xdef_t * cs_equation_add_volume_mass_injection_by_analytic(cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
Definition: cs_equation_param.c:3093
void cs_equation_param_log(const cs_equation_param_t *eqp)
Print the detail of a cs_equation_param_t structure.
Definition: cs_equation_param.c:1605
bool do_lumping
Definition: cs_equation_param.h:535
Definition: cs_equation_param.h:500
cs_hodge_param_t reaction_hodgep
Definition: cs_equation_param.h:670
cs_xdef_t ** bc_defs
Definition: cs_equation_param.h:502
Definition: cs_param_types.h:319
Definition: cs_equation_param.h:1104
cs_xdef_t * cs_equation_find_bc(cs_equation_param_t *eqp, const char *z_name)
Return pointer to existing boundary condition definition structure for the given equation param struc...
Definition: cs_equation_param.c:2450
Definition: cs_equation_param.h:1114
Definition: cs_equation_param.h:1098
Reaction term is needed.
Definition: cs_equation_param.h:92
cs_enforcement_param_t * cs_equation_add_vertex_dof_enforcement(cs_equation_param_t *eqp, cs_lnum_t n_vertices, const cs_lnum_t vertex_ids[], const cs_real_t ref_value[], const cs_real_t vtx_values[])
Add an enforcement of the value of degrees of freedom located at the mesh vertices. The spatial discretization scheme for the given equation has to be CDO vertex-based or CDO vertex+cell-based schemes.
Definition: cs_equation_param.c:3152
cs_hodge_param_t diffusion_hodgep
Definition: cs_equation_param.h:570
void cs_equation_add_advection_scaling_property(cs_equation_param_t *eqp, cs_property_t *property)
Associate a scaling property to the advection.
Definition: cs_equation_param.c:2704
Diffusion term is needed. A scalar-/vector-valued Laplacian with div .grad.
Definition: cs_equation_param.h:89
Definition: cs_param_types.h:355
int idiff
Definition: cs_equation_param.h:441
cs_enforcement_param_t * cs_equation_add_edge_dof_enforcement(cs_equation_param_t *eqp, cs_lnum_t n_edges, const cs_lnum_t edge_ids[], const cs_real_t ref_value[], const cs_real_t edge_values[])
Add an enforcement of the value of degrees of freedom located at the mesh edges. The spatial discreti...
Definition: cs_equation_param.c:3223
Definition: cs_param_types.h:242
Definition: cs_equation_param.h:1109
Definition: cs_equation_param.h:1111
Definition: cs_param_types.h:275
void cs_equation_param_last_stage(cs_equation_param_t *eqp)
Last modification of the cs_equation_param_t structure before launching the computation.
Definition: cs_equation_param.c:1573
cs_hodge_param_t time_hodgep
Definition: cs_equation_param.h:553
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator...
Definition: cs_hodge.h:154
cs_xdef_t * cs_equation_add_volume_mass_injection_by_value(cs_equation_param_t *eqp, const char *z_name, double *val)
Definition: cs_equation_param.c:2997
Structure storing all metadata related to the resolution of a linear system with an iterative solver...
Definition: cs_param_sles.h:62
Set of data defining an enforcement.
Definition: cs_enforcement.h:89
void cs_equation_add_diffusion(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the Laplacian operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.c:2572
double epsrsm
Definition: cs_equation_param.h:460
void cs_equation_add_graddiv(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the grad-div operator for the equation associated to the given cs_equ...
Definition: cs_equation_param.c:2629
Definition: cs_equation_param.h:161
