7.1
cs_hodge_param_t Struct Reference
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator. More...
#include <cs_hodge.h>
+ Collaboration diagram for cs_hodge_param_t:
Data Fields
bool inv_pty
 Inversion of the property evaluation or not. More...
cs_hodge_type_t type
cs_hodge_algo_t algo
double coef
 Scaling coefficient value. More...
Field Documentation
◆ algo
Type of algorithm used to build the operator
◆ coef
double coef
Value of the coefficient scaling the stabilization part if the COST or OCS2 algorithm is used. Otherwise the value is set to 0 and ignored.
◆ inv_pty
bool inv_pty
Each Hodge operator is associated to a property. Since either the value or its reciprocal is considered, this parameter helps one to know in which situation we are. If this is set to true, then one needs to consider the reciprocal of the associated property
◆ type
Type of discrete Hodge operator
