7.1
cs_sles_mumps.c File Reference
Set of functions to handle the interface with the MUMPS library to solve sparse linear system with a direct approach. More...
#include <stdarg.h>
#include "cs_fp_exception.h"
#include "cs_halo.h"
#include "cs_matrix.h"
#include "cs_timer.h"
#include "cs_sles.h"
#include "cs_sles_mumps.h"
+ Include dependency graph for cs_sles_mumps.c:
void cs_user_sles_mumps_hook (const cs_param_sles_t *slesp, void *context, DMUMPS_STRUC_C *dmumps, SMUMPS_STRUC_C *smumps)
 Function pointer for user settings of a MUMPS solver. This function is called at the end of the setup stage. More...
cs_sles_mumps_tcs_sles_mumps_define (int f_id, const char *name, const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context)
 Define and associate a MUMPS linear system solver for a given field or equation name. More...
cs_sles_mumps_tcs_sles_mumps_create (const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context)
 Create MUMPS linear system solver info and context. More...
void * cs_sles_mumps_copy (const void *context)
 Create MUMPS linear system solver info and context based on existing info and context. More...
void cs_sles_mumps_free (void *context)
 Free MUMPS linear equation solver setup context. More...
void cs_sles_mumps_destroy (void **context)
 Destroy MUMPS linear system solver info and context. More...
void cs_sles_mumps_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup MUMPS linear equation solver. More...
cs_sles_convergence_state_t cs_sles_mumps_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call MUMPS linear equation solver. More...
void cs_sles_mumps_log (const void *context, cs_log_t log_type)
 Log sparse linear equation solver info. More...
◆ cs_sles_mumps_copy()
void* cs_sles_mumps_copy ( const void *  context)
[in]contextpointer to reference info and context (actual type: cs_sles_mumps_t *)
pointer to newly created solver info object. (actual type: cs_sles_mumps_t *)
◆ cs_sles_mumps_create()
cs_sles_mumps_t* cs_sles_mumps_create ( const cs_param_sles_t slesp,
cs_sles_mumps_setup_hook_t setup_hook,
void *  context
[in]slesppointer to a cs_param_sles_t structure
[in]setup_hookpointer to optional setup epilogue function
[in,out]contextpointer to optional (untyped) value or structure for setup_hook, or NULL
pointer to associated linear system object.
◆ cs_sles_mumps_define()
cs_sles_mumps_t* cs_sles_mumps_define ( int  f_id,
const char *  name,
void *  context
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_mumps_create.
Note that this function returns a pointer directly to the sparse direct solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
[in]nameassociated name if f_id < 0, or NULL
pointer to newly created sparse direct solver info object.
◆ cs_sles_mumps_destroy()
void cs_sles_mumps_destroy ( void **  context)
[in,out]contextpointer to sparse direct solver info and context (actual type: cs_sles_mumps_t **)
◆ cs_sles_mumps_free()
void cs_sles_mumps_free ( void *  context)
[in,out]contextpointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *)
◆ cs_sles_mumps_log()
void cs_sles_mumps_log ( const void *  context,
cs_log_t  log_type
[in]contextpointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *)
[in]log_typelog type
◆ cs_sles_mumps_setup()
void cs_sles_mumps_setup ( void *  context,
const char *  name,
const cs_matrix_t a,
int  verbosity
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_sles_mumps_solve()
cs_sles_convergence_state_t cs_sles_mumps_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residue,
const cs_real_t rhs,
cs_real_t vx,
size_t  aux_size,
void *  aux_vectors
[in]amatrix
[in]precisionsolver precision
[in]r_normresidue normalization
[out]residueresidue
[in]rhsright hand side
[in,out]vxsystem solution
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if NULL)
convergence state
◆ cs_user_sles_mumps_hook()
void cs_user_sles_mumps_hook ( const cs_param_sles_t slesp,
void *  context,
DMUMPS_STRUC_C *  dmumps,
SMUMPS_STRUC_C *  smumps
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that structure should not be temporary (i.e. local);
[in]slesppointer to the related cs_param_sles_t structure
[in,out]dmumpspointer to DMUMPS_STRUC_C (double-precision)
[in,out]smumpspointer to SMUMPS_STRUC_C (single-precision)
