7.1
cs_ale.c File Reference
#include "cs_boundary_conditions.h"
#include "cs_boundary_zone.h"
#include "cs_cell_to_vertex.h"
#include "cs_cdo_connect.h"
#include "cs_cdo_main.h"
#include "cs_domain.h"
#include "cs_domain_setup.h"
#include "cs_equation.h"
#include "cs_equation_iterative_solve.h"
#include "cs_face_viscosity.h"
#include "cs_field_pointer.h"
#include "cs_gui_mobile_mesh.h"
#include "cs_interface.h"
#include "cs_math.h"
#include "cs_mesh_bad_cells.h"
#include "cs_time_step.h"
#include "cs_ale.h"
+ Include dependency graph for cs_ale.c:
void cs_f_ale_get_pointers (int **iale)
void cs_ale_update_mesh_quantities (cs_real_t *min_vol, cs_real_t *max_vol, cs_real_t *tot_vol)
 Compute cell and face centers of gravity, cell volumes and update bad cells. More...
void cs_ale_project_displacement (const int ale_bc_type[], const cs_real_3_t *meshv, const cs_real_33_t gradm[], const cs_real_3_t *claale, const cs_real_33_t *clbale, const cs_real_t *dt, cs_real_3_t *disp_proj)
 Project the displacement on mesh vertices (solved on cell center). More...
void cs_ale_update_mesh (const int itrale)
 Update mesh in the ALE framework. More...
void cs_ale_update_bcs (int *ale_bc_type, cs_real_3_t *b_fluid_vel)
 Update ALE BCs for required for the fluid. More...
void cs_ale_solve_mesh_velocity (const int iterns, const int *impale, const int *ale_bc_type)
 Solve a Poisson equation on the mesh velocity in ALE framework. More...
void cs_ale_activate (void)
 Activate the mesh velocity solving with CDO. More...
bool cs_ale_is_activated (void)
 Test if mesh velocity solving with CDO is activated. More...
void cs_ale_init_setup (cs_domain_t *domain)
 Setup the equations solving the mesh velocity. More...
void cs_ale_setup_boundaries (const cs_domain_t *domain)
void cs_ale_finalize_setup (cs_domain_t *domain)
 Finalize the setup stage for the equation of the mesh velocity. More...
void cs_ale_destroy_all (void)
 Free the main structure related to the ALE mesh velocity solving. More...
int cs_glob_ale = 0
◆ cs_ale_activate()
void cs_ale_activate ( void  )
◆ cs_ale_destroy_all()
void cs_ale_destroy_all ( void  )
◆ cs_ale_finalize_setup()
void cs_ale_finalize_setup ( cs_domain_t domain)
◆ cs_ale_init_setup()
void cs_ale_init_setup ( cs_domain_t domain)
Setup the equations related to mesh deformation.
◆ cs_ale_is_activated()
bool cs_ale_is_activated ( void  )
true if mesh velocity solving with CDO is requested, false otherwise
◆ cs_ale_project_displacement()
void cs_ale_project_displacement ( const int  ale_bc_type[],
const cs_real_3_t meshv,
const cs_real_3_t claale,
const cs_real_33_t clbale,
const cs_real_t dt,
cs_real_3_t disp_proj
[in]ale_bc_typeType of boundary for ALE
[in]meshvMesh velocity
[in]gradmMesh velocity gradient (du_i/dx_j : gradv[][i][j])
[in]claaleBoundary conditions A
[in]clbaleBoundary conditions B
[in]dtTime step
[out]disp_projDisplacement projected on vertices
◆ cs_ale_setup_boundaries()
void cs_ale_setup_boundaries ( const cs_domain_t domain)
[in]domainpointer to a cs_domain_t structure
◆ cs_ale_solve_mesh_velocity()
void cs_ale_solve_mesh_velocity ( const int  iterns,
const int *  impale,
const int *  ale_bc_type
It also updates the mesh displacement so that it can be used to update mass fluxes (due to mesh displacement).
[in]iternsNavier-Stokes iteration number
[in]impaleIndicator for fixed node displacement
◆ cs_ale_update_bcs()
void cs_ale_update_bcs ( int *  ale_bc_type,
cs_real_3_t b_fluid_vel
[out]ale_bc_typetype of ALE bcs
[out]b_fluid_velFluid velocity at boundary faces
◆ cs_ale_update_mesh()
void cs_ale_update_mesh ( const int  itrale)
[in]itralenumber of the current ALE iteration
◆ cs_ale_update_mesh_quantities()
void cs_ale_update_mesh_quantities ( cs_real_t min_vol,
cs_real_t max_vol,
cs_real_t tot_vol
[out]min_volMinimum cell volume
[out]max_volMaximum cell volume
[out]tot_volTotal cell volume
◆ cs_f_ale_get_pointers()
void cs_f_ale_get_pointers ( int **  iale)
◆ cs_glob_ale
int cs_glob_ale = 0
