#include <stdarg.h>
#include "cs_tree.h"
struct | cs_solving_info_t |
struct | cs_gas_mix_species_prop_t |
struct | cs_space_disc_t |
Space discretisation options descriptor. More... | |
struct | cs_time_scheme_t |
Time scheme descriptor. More... | |
struct | cs_restart_auxiliary_t |
Additional checkpoint/restart files. More... | |
typedef cs_equation_param_t | cs_var_cal_opt_t |
Enumerations | |
enum | { CS_INDEF = 1, CS_INLET = 2, CS_OUTLET = 3, CS_SYMMETRY = 4, CS_SMOOTHWALL = 5, CS_ROUGHWALL = 6, CS_ESICF = 7, CS_SSPCF = 8, CS_SOPCF = 9, CS_EPHCF = 10, CS_EQHCF = 11, CS_COUPLED = 12, CS_COUPLED_FD = 13, CS_FREE_INLET = 14, CS_FREE_SURFACE = 15, CS_CONVECTIVE_INLET = 16 } |
enum | { CS_DRIFT_SCALAR_ON = (1 << 0), CS_DRIFT_SCALAR_ADD_DRIFT_FLUX = (1 << 1), CS_DRIFT_SCALAR_THERMOPHORESIS = (1 << 2), CS_DRIFT_SCALAR_TURBOPHORESIS = (1 << 3), CS_DRIFT_SCALAR_ELECTROPHORESIS = (1 << 4), CS_DRIFT_SCALAR_CENTRIFUGALFORCE = (1 << 5), CS_DRIFT_SCALAR_IMPOSED_MASS_FLUX = (1 << 6), CS_DRIFT_SCALAR_ZERO_BNDY_FLUX = (1 << 7), CS_DRIFT_SCALAR_ZERO_BNDY_FLUX_AT_WALLS = (1 << 8) } |
cs_space_disc_t * | cs_get_glob_space_disc (void) |
Provide access to cs_glob_space_disc. More... | |
cs_time_scheme_t * | cs_get_glob_time_scheme (void) |
Provide access to cs_glob_time_scheme. More... | |
void | cs_parameters_define_field_keys (void) |
Define general field keys. More... | |
void | cs_parameters_define_field_key_gas_mix (void) |
Define field key for condensation. More... | |
void | cs_parameters_read_restart_info (void) |
Read general restart info. More... | |
void | cs_parameters_add_variable (const char *name, int dim) |
Solved variables are always defined on cells. More... | |
void | cs_parameters_add_variable_variance (const char *name, const char *variable_name) |
Define a user variable which is a variance of another variable. More... | |
void | cs_parameters_add_property (const char *name, int dim, int location_id) |
Define a user property. More... | |
int | cs_parameters_n_added_variables (void) |
Return the number of defined user variables not added yet. More... | |
int | cs_parameters_n_added_properties (void) |
Return the number of defined user properties not added yet. More... | |
void | cs_parameters_create_added_variables (void) |
Create previously added user variables. More... | |
void | cs_parameters_create_added_properties (void) |
Create previously added user properties. More... | |
cs_field_t * | cs_parameters_add_boundary_values (cs_field_t *f) |
Define a boundary values field for a variable field. More... | |
cs_field_t * | cs_parameters_add_boundary_temperature (void) |
Define a boundary values field for temperature, if applicable. More... | |
cs_var_cal_opt_t | cs_parameters_var_cal_opt_default (void) |
Return a local variable calculation options structure, with default options. More... | |
void | cs_time_scheme_log_setup (void) |
Print the time scheme structure to setup.log. More... | |
void | cs_space_disc_log_setup (void) |
Print the space discretization structure to setup.log. More... | |
const cs_space_disc_t * | cs_glob_space_disc |
const cs_time_scheme_t * | cs_glob_time_scheme |
cs_restart_auxiliary_t * | cs_glob_restart_auxiliary |
cs_tree_node_t * | cs_glob_tree |
typedef cs_equation_param_t cs_var_cal_opt_t |
anonymous enum |
anonymous enum |
cs_space_disc_t* cs_get_glob_space_disc | ( | void | ) |
cs_time_scheme_t* cs_get_glob_time_scheme | ( | void | ) |
cs_field_t* cs_parameters_add_boundary_temperature | ( | void | ) |
When a volume temperature variable field already exists, this amounts to calling cs_parameters_add_boundary_values for that field. When such a variable does not exist but we have an Enthalpy variables, an associated temperature boundary field is returned.
cs_field_t* cs_parameters_add_boundary_values | ( | cs_field_t * | f | ) |
[in] | f | pointer to field structure |
[in,out] | f | pointer to field structure |
void cs_parameters_add_property | ( | const char * | name, |
int | dim, | ||
int | location_id | ||
[in] | name | name of property and associated field |
[in] | dim | property dimension |
[in] | location_id | id of associated mesh location |
void cs_parameters_add_variable | ( | const char * | name, |
int | dim | ||
Define a user variable.
[in] | name | name of variable and associated field |
[in] | dim | variable dimension |
void cs_parameters_add_variable_variance | ( | const char * | name, |
const char * | variable_name | ||
[in] | name | name of variance and associated field |
[in] | variable_name | name of associated variable |
void cs_parameters_create_added_properties | ( | void | ) |
void cs_parameters_create_added_variables | ( | void | ) |
void cs_parameters_define_field_key_gas_mix | ( | void | ) |
Note: this should be moved in the future to a condensation-specific file.
void cs_parameters_define_field_keys | ( | void | ) |
int cs_parameters_n_added_properties | ( | void | ) |
This number is reset to 0 when cs_parameters_create_added_properties() is called.
int cs_parameters_n_added_variables | ( | void | ) |
This number is reset to 0 when cs_parameters_create_added_variables() is called.
void cs_parameters_read_restart_info | ( | void | ) |
This updates the previous time step info.
cs_var_cal_opt_t cs_parameters_var_cal_opt_default | ( | void | ) |
void cs_space_disc_log_setup | ( | void | ) |
void cs_time_scheme_log_setup | ( | void | ) |
cs_restart_auxiliary_t* cs_glob_restart_auxiliary |
const cs_space_disc_t* cs_glob_space_disc |
const cs_time_scheme_t* cs_glob_time_scheme |
cs_tree_node_t* cs_glob_tree |
Global parameters tree structure
