51 #define CS_TREE_NODE_CHAR (1 << 0) 52 #define CS_TREE_NODE_INT (1 << 1) 53 #define CS_TREE_NODE_REAL (1 << 2) 54 #define CS_TREE_NODE_BOOL (1 << 3) 56 #define CS_TREE_NODE_TAG (1 << 4) 213 const char *tag_str);
295 cs_tree_node_set_value_bool(cs_tree_node_t *node,
345 cs_tree_node_set_value_int(cs_tree_node_t *node,
395 cs_tree_node_set_value_real(cs_tree_node_t *node,
416 const char *child_name);
433 const char *child_name);
451 const char *child_name);
468 const char *child_name);
513 const char *tag_value);
528 const cs_tree_node_t *node);
603 static inline cs_tree_node_t *
604 cs_tree_get_node_with_tag(cs_tree_node_t *node,
607 const char *tag_value)
633 static inline cs_tree_node_t *
634 cs_tree_get_or_add_node(cs_tree_node_t *node,
673 static inline cs_tree_node_t *
674 cs_tree_add_child_str(cs_tree_node_t *
parent,
696 static inline cs_tree_node_t *
697 cs_tree_add_child_bool(cs_tree_node_t *
parent,
719 static inline cs_tree_node_t *
720 cs_tree_add_child_int(cs_tree_node_t *
parent,
742 static inline cs_tree_node_t *
743 cs_tree_add_child_real(cs_tree_node_t *
parent,
787 const char *sub_path);
809 cs_tree_node_t *current,
810 const char *sub_path);
855 cs_tree_node_t *current,
874 const char *sub_path);
908 const cs_tree_node_t *node);
char * name
Definition: cs_tree.h:67
void cs_tree_node_set_values_real(cs_tree_node_t *node, int n, const cs_real_t *val)
Assign an array of real values to a node.
Definition: cs_tree.c:976
cs_tree_node_t * cs_tree_find_node_simple(cs_tree_node_t *root, const char *name)
Retrieve the pointer to a node's descendants matching a given name.
Definition: cs_tree.c:1615
const int * cs_tree_node_get_child_values_int(cs_tree_node_t *node, const char *child_name)
Return an array of integer values associated to a child node if present.
Definition: cs_tree.c:1060
cs_tree_node_t * cs_tree_find_node_next_simple(cs_tree_node_t *root, cs_tree_node_t *current, const char *name)
Retrieve the pointer to the next node with a given name and following a given node in a depth-first o...
Definition: cs_tree.c:1648
cs_tree_node_t * cs_tree_node_get_next_of_name(cs_tree_node_t *node)
Return the next sibling node with the same name (type) as a given node.
Definition: cs_tree.c:506
Definition: cs_defs.h:495
void cs_tree_dump(cs_log_t log, int depth, const cs_tree_node_t *node)
Dump a cs_tree_node_t structure starting from a given node.
Definition: cs_tree.c:1768
int size
Definition: cs_tree.h:72
cs_tree_node_t * prev
Definition: cs_tree.h:78
cs_tree_node_t * cs_tree_node_get_child(cs_tree_node_t *node, const char *name)
Return a child node with a given name.
Definition: cs_tree.c:474
const bool * cs_tree_node_get_child_values_bool(cs_tree_node_t *node, const char *child_name)
Return array of boolean values associated to a child node if present.
Definition: cs_tree.c:1033
int cs_tree_get_sub_node_count_simple(cs_tree_node_t *root, const char *name)
Count a node's descendants with a given name.
Definition: cs_tree.c:1743
cs_tree_node_t * cs_tree_find_node(cs_tree_node_t *root, const char *sub_path)
Retrieve the pointer to a node matching a given sub-path.
Definition: cs_tree.c:1499
void cs_tree_node_dump(cs_log_t log, int depth, const cs_tree_node_t *node)
Dump a cs_tree_node_t structure.
Definition: cs_tree.c:1183
const char * cs_tree_node_get_value_str(cs_tree_node_t *node)
Return a character string value associated to a node if present.
Definition: cs_tree.c:626
Definition: cs_defs.h:307
const int * cs_tree_node_get_values_int(cs_tree_node_t *node)
Return an array of integer values associated to a node if present.
Definition: cs_tree.c:802
cs_tree_node_t * next
Definition: cs_tree.h:80
int flag
Definition: cs_tree.h:69
void cs_tree_node_set_values_int(cs_tree_node_t *node, int n, const int *val)
Assign an array of integer values to a node.
Definition: cs_tree.c:873
void cs_tree_node_set_tag(cs_tree_node_t *node, const char *tag, const char *tag_str)
Assign a tag to a given node.
Definition: cs_tree.c:599
void cs_tree_node_set_name(cs_tree_node_t *node, const char *name)
Name or rename a node.
Definition: cs_tree.c:440
cs_tree_node_t * cs_tree_find_node_next(cs_tree_node_t *root, cs_tree_node_t *current, const char *sub_path)
Retrieve the pointer to the next node matching a given sub-path and following a given node in a depth...
Definition: cs_tree.c:1531
cs_tree_node_t * cs_tree_node_get_sibling_with_tag(cs_tree_node_t *node, const char *tag, const char *tag_value)
Retrieve the pointer to a node with a child having a given (character string) tag value...
Definition: cs_tree.c:1139
void cs_tree_node_set_values_bool(cs_tree_node_t *node, int n, const bool *val)
Assign an array of boolean values to node.
Definition: cs_tree.c:770
const cs_real_t * cs_tree_node_get_values_real(cs_tree_node_t *node)
Return an array of real values associated to a node if present.
Definition: cs_tree.c:905
char * desc
Definition: cs_tree.h:68
cs_log_t
Definition: cs_log.h:48
cs_tree_node_t * children
Definition: cs_tree.h:77
cs_tree_node_t * cs_tree_add_node(cs_tree_node_t *node, const char *path)
Add a node to a tree.
Definition: cs_tree.c:1328
const char * cs_tree_node_get_tag(cs_tree_node_t *node, const char *tag)
Search for a child node (used as a tag) with a given name, and return its associated string value...
Definition: cs_tree.c:544
void * value
Definition: cs_tree.h:71
int cs_tree_get_sub_node_count(cs_tree_node_t *root, const char *sub_path)
Count a node's descendants matching a given sub-path.
Definition: cs_tree.c:1713
cs_tree_node_t * cs_tree_add_sibling(cs_tree_node_t *sibling, const char *name)
Create and add a node in a tree at the right of the given node.
Definition: cs_tree.c:1460
const bool * cs_tree_node_get_values_bool(cs_tree_node_t *node)
Return array of boolean values associated to a node if present.
Definition: cs_tree.c:699
const cs_real_t * cs_tree_node_get_child_values_real(cs_tree_node_t *node, const char *child_name)
Return an array of real values associated to a child node if present.
Definition: cs_tree.c:1086
cs_tree_node_t * cs_tree_add_child(cs_tree_node_t *parent, const char *name)
Create and add a node in a tree below the given node.
Definition: cs_tree.c:1416
cs_tree_node_t * cs_tree_node_create(const char *name)
Create an empty node.
Definition: cs_tree.c:373
Definition: cs_defs.h:496
cs_tree_node_t * parent
Definition: cs_tree.h:76
void cs_tree_node_set_value_str(cs_tree_node_t *node, const char *val)
Assign a character string value to a node.
Definition: cs_tree.c:663
void cs_tree_node_free(cs_tree_node_t **pnode)
Free a branch in a tree starting from a node.
Definition: cs_tree.c:408
const char * cs_tree_node_get_child_value_str(cs_tree_node_t *node, const char *child_name)
Return a string value associated to a child node if present.
Definition: cs_tree.c:1007
cs_tree_node_t * cs_tree_get_node(cs_tree_node_t *node, const char *path)
Retrieve the pointer to a node matching a given path.
Definition: cs_tree.c:1358
int cs_tree_get_node_count(cs_tree_node_t *node, const char *path)
Count number of nodes sharing a given path.
Definition: cs_tree.c:1383
