cs_space_disc_t Struct Reference
Space discretisation options descriptor. More...
#include <cs_parameters.h>
+ Collaboration diagram for cs_space_disc_t:
Data Fields
int imvisf
int imrgra
int iflxmw
int itbrrb
Members of the space discretisation structure are publicly accessible, to allow for concise syntax, as they are expected to be used in many places.
Field Documentation
◆ iflxmw
iflxmw
method to compute interior mass flux due to ALE mesh velocity
  • 0: based on nodes displacement
  • 1: based on cell center mesh velocity
◆ imrgra
imrgra
type of gradient reconstruction
  • 0: Green-Gauss with iterative handling of non-orthogonalities
  • 1: standard least squares method
  • 2: least squares method with extended neighborhood
  • 3: least squares method with reduced extended neighborhood
  • 4: Green-Gauss with least squares gradient face values
  • 5: Green-Gauss with least squares gradient over extended neighborhood face values
  • 6: Green-Gauss with least squares gradient over reduced extended neighborhood face values
  • 7: Green-Gauss with face values based on cell to vertex interpolation
◆ imvisf
imvisf
face viscosity field interpolation
  • 1: harmonic
  • 0: arithmetic (default)
◆ itbrrb
itbrrb
accurate treatment of the wall temperature (reconstruction of wall temperature)
  • 1: true
  • 0: false (default) (see condli, useful in case of coupling with syrthes)
