Here is a list of all struct and union fields with links to the structures/unions they belong to:
- b -
- b : cs_field_bc_coeffs_t
- b01_w_eqp : cs_gwf_tpf_t
- b1 : cs_coal_model_t
- b10_h_eqp : cs_gwf_tpf_t
- b11_max_size : cs_saddle_solver_context_block_pcd_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- b11_range_set : cs_saddle_solver_context_block_pcd_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- b1_tilda : cs_saddle_solver_context_alu_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- b2 : cs_coal_model_t
- b22_max_size : cs_saddle_solver_context_block_pcd_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- b_cells : cs_mesh_t
- b_climgr : cs_equation_param_t
- b_def_ids : cs_property_t
- b_defs : cs_property_t
- b_diff_flux_rc : cs_equation_param_t
- b_dist : cs_cdo_quantities_t, cs_mesh_quantities_t
- b_f_face_factor : cs_mesh_quantities_t
- b_face_cells : cs_mesh_t
- b_face_center : cs_cdo_quantities_t
- b_face_cog : cs_mesh_quantities_t
- b_face_family : cs_mesh_t
- b_face_normal : cs_cdo_quantities_t, cs_mesh_quantities_t
- b_face_numbering : cs_mesh_t
- b_face_surf : cs_cdo_quantities_t, cs_mesh_quantities_t
- b_face_u_normal : cs_cdo_quantities_t, cs_mesh_quantities_t
- b_face_vtx_connect_size : cs_mesh_t
- b_face_vtx_idx : cs_mesh_t
- b_face_vtx_lst : cs_mesh_t
- b_gradient_r : cs_equation_param_t
- b_proj : cs_at_opt_interp_t
- b_sym_flag : cs_mesh_quantities_t
- bad_cell_flag : cs_mesh_quantities_t
- balance : cs_cdo_balance_t
- barrier() : cs_execution_context
- base_diameter : cs_lagr_agglomeration_model_t, cs_lagr_fragmentation_model_t
- bbox : cs_medcoupling_mesh_t
- bbox_depth : cs_join_stats_t
- bbox_layout : cs_join_stats_t
- bc : cs_field_bc_coeffs_t
- bc_coeffs : cs_field_t
- bc_defs : cs_equation_param_t
- bc_type : cs_ale_data_t
- bd : cs_field_bc_coeffs_t
- bdy_def_ids : cs_adv_field_t
- bdy_field_id : cs_adv_field_t
- bdy_flag : cs_equation_builder_t
- bdy_flux_defs : cs_adv_field_t
- bdy_potential_flux : cs_pressure_correction_cdo_t
- bdy_pressure_incr : cs_navsto_projection_t, cs_pressure_correction_cdo_t
- benchmark : cs_opts_t
- beta : cs_iter_algo_param_aac_t, cs_navsto_param_boussinesq_t, cs_saddle_solver_context_gkb_t
- bf : cs_field_bc_coeffs_t
- bf2v : cs_cdo_connect_t
- bf_flag : cs_cell_sys_t
- bf_ids : cs_cell_sys_t
- bf_t : cs_hho_builder_t
- bf_type : cs_cdofb_navsto_builder_t, cs_navsto_system_t
- bface_shift : cs_cell_mesh_t
- bflux_field_id : cs_cdocb_scaleq_t, cs_cdoeb_vecteq_t, cs_cdofb_vecteq_t, cs_cdovb_vecteq_t, cs_macfb_vecteq_t
- blencv : var_cal_opt, cs_equation_param_t
- blend_st : var_cal_opt, cs_equation_param_t
- block11_sles_param : cs_param_saddle_t
- block21_op : cs_cdocb_scaleq_t
- block_analysis : cs_param_mumps_t
- block_desc : cs_sdm_t
- block_factories : cs_equation_system_t
- block_pointer : cs_cdo_system_block_t
- block_size : cs_block_dist_info_t
- block_var_dim : cs_equation_system_param_t
- blocks : cs_cdo_system_helper_t, cs_sdm_block_t
- blr_threshold : cs_param_mumps_t
- bnd_dir : cs_cfd_sys_cplbc_t
- boundaries : cs_domain_t, cs_navsto_param_t
- boundary_conditions_mapped_set() : boundary_conditions_mapped_set
- boundary_flag : fvm_nodal_section_t
- boundary_flux_id : cs_equation_t
- boundary_flux_val : cs_gwf_darcy_flux_t
- boundary_measure : cs_zone_t
- boundary_term : cs_cdo_balance_t
- boussinesq_param : cs_navsto_param_t
- box_mem_final : cs_join_stats_t
- box_mem_required : cs_join_stats_t
- brij : cs_les_balance_t
- btui : cs_les_balance_t
- budsgsfullij : cs_les_balance_rij_t
- budsgsij : cs_les_balance_rij_t
- budsgstui : cs_les_balance_tui_t
- budsgstuifull : cs_les_balance_tui_t
- budsgsvar : cs_les_balance_tui_t
- budsgsvarfull : cs_les_balance_tui_t
- buffer : fvm_to_histogram_writer_t
- buffer_size : cs_matrix_row_info_t
- build_system : cs_equation_t
- builder : cs_equation_t, cs_equation_core_t
- bulk_density : cs_gwf_soil_t
- bym : cs_combustion_gas_model_t
