1#ifndef __CS_HHO_BUILDER_H__
2#define __CS_HHO_BUILDER_H__
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
void cs_hho_builder_free(cs_hho_builder_t **p_builder)
Free a cs_hho_builder_t structure.
Definition cs_hho_builder.cpp:823
void cs_hho_builder_compute_dirichlet_v(const cs_xdef_t *def, short int f, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t res[])
Compute the projection of the Dirichlet boundary conditions onto the polynomial spaces on faces....
Definition cs_hho_builder.cpp:1968
void cs_hho_builder_compute_grad_reco(const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
Compute the gradient operator stemming from the relation stiffness * grad_op = rhs where stiffness is...
Definition cs_hho_builder.cpp:916
static void cs_hho_builder_cellbasis_setup(const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
Set-up the basis functions related to a cell only.
Definition cs_hho_builder.h:134
void cs_hho_builder_compute_dirichlet(const cs_xdef_t *def, short int f, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t res[])
Definition cs_hho_builder.cpp:1840
void cs_hho_builder_diffusion(const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
Compute the diffusion operator. The gradient reconstruction operator has to be built just before this...
Definition cs_hho_builder.cpp:1156
cs_hho_builder_t * cs_hho_builder_create(int order, int n_fc)
Allocate a cs_hho_builder_t structure.
Definition cs_hho_builder.cpp:753
void cs_hho_builder_reduction_from_analytic(const cs_xdef_t *def, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t red[])
Compute the reduction onto the polynomial spaces (cell and faces) of a function defined by an analyti...
Definition cs_hho_builder.cpp:1461
void cs_hho_builder_reduction_from_analytic_v(const cs_xdef_t *def, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t red[])
Definition cs_hho_builder.cpp:1635
void cs_hho_builder_cellwise_setup(const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
Set-up the basis functions related to a cell, its gradient and to the faces of this cell....
Definition cs_hho_builder.cpp:865
Definition cs_basis_func.h:181
cs_basis_func_setup_t * setup
Definition cs_basis_func.h:199
Definition cs_cdo_local.h:60
Definition cs_cdo_local.h:202
cs_real_3_t xc
Definition cs_cdo_local.h:216
Definition cs_hho_builder.h:54
cs_sdm_t * tmp
Definition cs_hho_builder.h:68
cs_basis_func_t ** face_basis
Definition cs_hho_builder.h:61
cs_basis_func_t * grad_basis
Definition cs_hho_builder.h:63
short int n_max_face_basis
Definition cs_hho_builder.h:59
short int n_face_basis
Definition cs_hho_builder.h:58
cs_sdm_t * hdg
Definition cs_hho_builder.h:71
cs_basis_func_t * cell_basis
Definition cs_hho_builder.h:62
cs_sdm_t * grad_reco_op
Definition cs_hho_builder.h:65
cs_sdm_t * jstab
Definition cs_hho_builder.h:70
cs_sdm_t * bf_t
Definition cs_hho_builder.h:69
Structure storing the evaluation of a property and its related data.
Definition cs_property.h:223
Definition cs_xdef.h:160
