#include "base/cs_base.h"#include "cdo/cs_basis_func.h"#include "cdo/cs_cdo_connect.h"#include "cdo/cs_property.h"#include "cdo/cs_sdm.h"#include "cdo/cs_xdef.h"Go to the source code of this file.
| struct | cs_hho_builder_t |
| cs_hho_builder_t * | cs_hho_builder_create (int order, int n_fc) |
| Allocate a cs_hho_builder_t structure. | |
| void | cs_hho_builder_free (cs_hho_builder_t **p_builder) |
| Free a cs_hho_builder_t structure. | |
| void | cs_hho_builder_cellwise_setup (const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_hho_builder_t *hhob) |
| Set-up the basis functions related to a cell, its gradient and to the faces of this cell. Compute cell and face projection and its related modified Cholesky factorization. | |
| static void | cs_hho_builder_cellbasis_setup (const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_hho_builder_t *hhob) |
| Set-up the basis functions related to a cell only. | |
| void | cs_hho_builder_compute_grad_reco (const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_cell_builder_t *cb, cs_hho_builder_t *hhob) |
| Compute the gradient operator stemming from the relation stiffness * grad_op = rhs where stiffness is a square matrix of size grd_size rhs is matrix of size (n_fc*f_size + c_size) * grd_size Hence, grad_op a matrix grd_size * (n_fc*f_size + c_size) | |
| void | cs_hho_builder_diffusion (const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_cell_builder_t *cb, cs_hho_builder_t *hhob) |
| Compute the diffusion operator. The gradient reconstruction operator has to be built just before this call (cb->aux stores the rhs) | |
| void | cs_hho_builder_reduction_from_analytic (const cs_xdef_t *def, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t red[]) |
| Compute the reduction onto the polynomial spaces (cell and faces) of a function defined by an analytical expression depending on the location and the current time red array has to be allocated before calling this function. | |
| void | cs_hho_builder_reduction_from_analytic_v (const cs_xdef_t *def, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t red[]) |
| Compute the reduction onto the polynomial spaces (cell and faces) of a function defined by an analytical expression depending on the location and the current time This function handles the vector case. | |
| void | cs_hho_builder_compute_dirichlet (const cs_xdef_t *def, short int f, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t res[]) |
| Compute the projection of the Dirichlet boundary conditions onto the polynomial spaces on faces. | |
| void | cs_hho_builder_compute_dirichlet_v (const cs_xdef_t *def, short int f, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t res[]) |
| Compute the projection of the Dirichlet boundary conditions onto the polynomial spaces on faces. Vector case. | |
inlinestatic |
| [in] | cb | pointer to a cell builder_t structure |
| [in,out] | hhob | pointer to a cs_hho_builder_t structure |
| void cs_hho_builder_cellwise_setup | ( | const cs_cell_mesh_t * | cm, |
| cs_hho_builder_t * | hhob ) |
| void cs_hho_builder_compute_dirichlet | ( | const cs_xdef_t * | def, |
| short int | f, | ||
| cs_real_t | t_eval, | ||
| cs_hho_builder_t * | hhob, | ||
| cs_real_t | res[] ) |
| [in] | f | local face id in the cellwise view of the mesh |
| [in,out] | cb | pointer to a cell builder_t structure |
| [in,out] | res | vector containing the result |
| void cs_hho_builder_compute_dirichlet_v | ( | const cs_xdef_t * | def, |
| short int | f, | ||
| void cs_hho_builder_compute_grad_reco | ( | const cs_cell_mesh_t * | cm, |
| const cs_property_data_t * | diff_pty, | ||
| [in] | diff_pty | pointer to a cs_property_data_t structure |
| cs_hho_builder_t * cs_hho_builder_create | ( | int | order, |
| int | n_fc ) |
| [in] | order | order of the polynomial basis function |
| [in] | n_fc | max. number of faces in a cell |
| void cs_hho_builder_diffusion | ( | const cs_cell_mesh_t * | cm, |
| void cs_hho_builder_free | ( | cs_hho_builder_t ** | p_builder | ) |
| [in,out] | p_builder | pointer of pointer on a cs_hho_builder_t struct. |
| void cs_hho_builder_reduction_from_analytic | ( | const cs_xdef_t * | def, |
| cs_real_t | red[] ) |
| [in,out] | red | vector containing the reduction |
| void cs_hho_builder_reduction_from_analytic_v | ( | const cs_xdef_t * | def, |
