typedef void | cs_basis_func_eval_all_at_point_t(const void *bf, const cs_real_t coords[3], cs_real_t *eval) |
| Generic prototype for evaluating all basis functions at a given point.
typedef void | cs_basis_func_eval_at_point_t(const void *bf, const cs_real_t coords[3], short int start, short int end, cs_real_t *eval) |
| Generic prototype for evaluating a set of basis functions at a given point.
typedef void | cs_basis_func_setup_t(void *pbf, const cs_cell_mesh_t *cm, const short int id, const cs_real_t center[3], cs_cell_builder_t *cb) |
| Generic prototype for setting up a set of basis functions.
typedef void | cs_basis_func_compute_proj_t(void *pbf, const cs_cell_mesh_t *cm, const short int id) |
| Generic prototype for computing the projector to the space spanned by the basis functions.
typedef void | cs_basis_func_compute_facto_t(void *pbf) |
| Generic prototype for computing the Modified Choloesky factorization of the projection matrix (mass matrix) related to the basis function.
typedef void | cs_basis_func_project_t(const void *pbf, const cs_real_t *array, cs_real_t *dof) |
| Generic prototype for projecting an array on the polynomial basis function. This results from the application of a Modified Choloesky factorization which should be performed before calling this function. The input array is defined as follows: int_elem v.phi_i for all i in the basis. v is a function to estimate.
typedef void | cs_basis_func_dump_proj_t(const void *pbf) |
| Generic prototype for printing the projector matrix related to the given basis function.
◆ CS_BASIS_FUNC_GRADIENT
#define CS_BASIS_FUNC_GRADIENT (1 << 1) /* 2: Basis functions for gradient */ |
◆ CS_BASIS_FUNC_MONOMIAL
#define CS_BASIS_FUNC_MONOMIAL (1 << 0) /* 1: Use mononial basis functions */ |
◆ cs_basis_func_compute_facto_t
typedef void cs_basis_func_compute_facto_t(void *pbf) |
- Parameters
◆ cs_basis_func_compute_proj_t
typedef void cs_basis_func_compute_proj_t(void *pbf, const cs_cell_mesh_t *cm, const short int id) |
- Parameters
◆ cs_basis_func_dump_proj_t
typedef void cs_basis_func_dump_proj_t(const void *pbf) |
- Parameters
◆ cs_basis_func_eval_all_at_point_t
typedef void cs_basis_func_eval_all_at_point_t(const void *bf, const cs_real_t coords[3], cs_real_t *eval) |
- Parameters
[in] | bf | pointer to be cast into a cs_basis_func_t structure |
[in] | coords | point coordinates |
[in,out] | eval | vector containing the evaluations of the functions |
◆ cs_basis_func_eval_at_point_t
typedef void cs_basis_func_eval_at_point_t(const void *bf, const cs_real_t coords[3], short int start, short int end, cs_real_t *eval) |
- Parameters
[in] | start | starts evaluating basis function from this id-1 |
[in] | end | ends evaluating basis function at this id |
◆ cs_basis_func_project_t
typedef void cs_basis_func_project_t(const void *pbf, const cs_real_t *array, cs_real_t *dof) |
- Parameters
[in] | pbf | pointer to be cast into a cs_basis_func_t structure |
[in] | array | array to project |
[in,out] | dof | projection of the array (= DoF values in this basis) |
◆ cs_basis_func_setup_t
- Parameters
[in,out] | pbf | pointer to be cast into a cs_basis_func_t structure |
[in] | cm | pointer to a cs_cell_mesh_t |
[in] | id | id of the element to consider |
[in] | center | point used for centering the set of basis functions |
[in,out] | cb | pointer to a cs_cell_builder_t structure |
◆ cs_basis_func_copy_setup()
Copy the center and the different axis from the reference basis Up to now, only cell basis functions are handled.
- Parameters
[in] | ref | set of basis function used as a reference |
[in,out] | rcv | set of basis function where members are set |
◆ cs_basis_func_create()
Allocate a cs_basis_func_t structure.
- Parameters
[in] | flag | metadata related to the way of building basis functions |
[in] | k | order |
[in] | dim | 2 or 3 geometrical dimension |
- Returns
- a pointer to the new cs_basis_func_t
- Parameters
[in] | k | polynomial order |
[in] | dim | 2 or 3 w.r.t. the geometrical dimension |
- Returns
◆ cs_basis_func_dump()
◆ cs_basis_func_fprintf()
void cs_basis_func_fprintf |
FILE * | fp, |
const char * | fname, |
const cs_basis_func_t * | pbf ) |
Print a cs_basis_func_t structure Print into the file f if given otherwise open a new file named fname if given otherwise print into the standard output.
- Parameters
[in] | fp | pointer to a file structure or null |
[in] | fname | filename or null |
[in] | pbf | pointer to the cs_basis_func_t structure to dump |
[in] | fp | pointer to a file structure or nullptr |
[in] | fname | filename or nullptr |
◆ cs_basis_func_free()
◆ cs_basis_func_get_hho_flag()
Get options for basis functions when using HHO schemes.
- Parameters
[out] | face_flag | pointer to options related to face basis functinos |
[out] | cell_flag | pointer to options related to cell basis functinos |
◆ cs_basis_func_get_poly_order()
Get the polynomial order of the given basis.
- Parameters
[in] | bf | set of basis functions |
- Returns
- the polynomial order
◆ cs_basis_func_grad_create()
Allocate a cs_basis_func_t structure which is associated to an existing set of basis functions. Up to now, only cell basis functions are handled. Building a projection matrix is not possible in this case.
- Parameters
- Returns
- a pointer to the new cs_basis_func_t for gradient of the current basis functions
◆ cs_basis_func_set_hho_flag()
Set options for basis functions when using HHO schemes.
- Parameters
[in] | face_flag | options related to face basis functinos |
[in] | cell_flag | options related to cell basis functinos |
