cs_sdm.h File Reference
Include dependency graph for cs_sdm.h:
Data Structures
struct  cs_sdm_block_t
struct  cs_sdm_t
Macros
#define CS_SDM_BY_BLOCK   (1 << 0) /* Matrix is defined by block */
#define CS_SDM_SYMMETRIC   (1 << 1) /* Matrix is symmetric by construction */
#define CS_SDM_SHARED_VAL   (1 << 2) /* Matrix is not owner of its values */
Typedefs
typedef void cs_sdm_product_t(const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Generic prototype for computing a local dense matrix-product c = a*b where c has been previously allocated.
typedef void cs_sdm_matvec_t(const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Generic prototype for computing a dense matrix-vector product mv has been previously allocated.
static cs_real_t cs_sdm_dot (int n, const cs_real_t x[], const cs_real_t y[])
 Basic dot product for a small vector For very small array sizes (3, 4, 6) prefer functions in cs_math For large array sizes ( from 10^3 to ..) prefer functions in cs_blas.
static void cs_sdm_scalvect (int n, const cs_real_t s, const cs_real_t x[], cs_real_t y[])
 Multiply a small vector by a scalar coefficient: y = s x For very small array sizes (3, 4, 6) prefer functions in cs_math For large array sizes ( from 10^3 to ..) prefer functions in cs_blas.
static void cs_sdm_add_scalvect (int n, const cs_real_t s, const cs_real_t x[], cs_real_t y[])
 Multiply a small vector by a scalar coefficient: y += s x For very small array sizes (3, 4, 6) prefer functions in cs_math For large array sizes ( from 10^3 to ..) prefer functions in cs_blas.
static void cs_sdm_symm_ur (cs_sdm_t *mat)
 Set the lower left according to the upper right part in order to get a symmetric matrix.
cs_sdm_t * cs_sdm_create (cs_flag_t flag, int n_max_rows, int n_max_cols)
 Allocate and initialize a cs_sdm_t structure Most generic function to create a cs_sdm_t structure.
cs_sdm_t * cs_sdm_square_create (int n_max_rows)
 Allocate and initialize a cs_sdm_t structure Case of a square matrix.
cs_sdm_t * cs_sdm_create_copy (const cs_sdm_t *m)
 Allocate a cs_sdm_t structure and initialized it with the copy of the matrix m in input.
cs_sdm_t * cs_sdm_create_transpose (cs_sdm_t *mat)
 Define a new matrix which is its transpose.
cs_sdm_t * cs_sdm_block_create (int n_max_blocks_by_row, int n_max_blocks_by_col, const int max_row_block_sizes[], const int max_col_block_sizes[])
 Allocate and initialize a cs_sdm_t structure.
cs_sdm_t * cs_sdm_block33_create (int n_max_blocks_by_row, int n_max_blocks_by_col)
 Allocate and initialize a cs_sdm_t structure by block when the block size is constant and equal to 3.
static void cs_sdm_map_array (int n_max_rows, int n_max_cols, cs_sdm_t *m, cs_real_t *array)
 Map an array into a predefined cs_sdm_t structure. This array is shared and the lifecycle of this array is not managed by the cs_sdm_t structure.
cs_sdm_t * cs_sdm_free (cs_sdm_t *mat)
 Free a cs_sdm_t structure.
static void cs_sdm_init (int n_rows, int n_cols, cs_sdm_t *mat)
 Initialize a cs_sdm_t structure Case of a square matrix.
static void cs_sdm_square_init (int n_rows, cs_sdm_t *mat)
void cs_sdm_block_init (cs_sdm_t *m, int n_row_blocks, int n_col_blocks, const int row_block_sizes[], const int col_block_sizes[])
 Initialize the pattern of cs_sdm_t structure defined by block The matrix should have been allocated before calling this function.
void cs_sdm_block33_init (cs_sdm_t *m, int n_row_blocks, int n_col_blocks)
 Initialize the pattern of cs_sdm_t structure defined by 3x3 block The matrix should have been allocated before calling this function.
void cs_sdm_block_33_to_xyz (const cs_sdm_t *mb33, cs_sdm_t *mbxyz)
 Convert a matrix with each entry is a 3x3 block into a matrix with a block for each component x,y,z.
static void cs_sdm_copy (cs_sdm_t *recv, const cs_sdm_t *send)
 Copy a cs_sdm_t structure into another cs_sdm_t structure which has been already allocated.
cs_sdm_t * cs_sdm_block_create_copy (const cs_sdm_t *mref)
 Allocate and initialize a cs_sdm_t structure w.r.t. to a given matrix.
static cs_sdm_t * cs_sdm_get_block (const cs_sdm_t *const m, int row_block_id, int col_block_id)
 Get a specific block in a cs_sdm_t structure defined by block.
static void cs_sdm_get_col (const cs_sdm_t *m, int col_id, cs_real_t *col_vals)
 Get a copy of a column in a preallocated vector.
static void cs_sdm_copy_block (const cs_sdm_t *m, const short int r_id, const short int c_id, const short int nr, const short int nc, cs_sdm_t *b)
 Copy a block of a matrix into a sub-matrix starting from (r_id, c_id) with a size of nr rows and nc cols.
static void cs_sdm_scale (cs_real_t scaling, cs_sdm_t *m)
 Multiply a matrix with the scaling factor given as parameter.
static void cs_sdm_transpose_and_update (const cs_sdm_t *m, cs_sdm_t *mt)
 transpose and copy a matrix into another one already shaped sub-matrix starting from (r_id, c_id)
void cs_sdm_multiply (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a local dense matrix-product c = a*b c has been previously allocated.
static void cs_sdm_33_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense 3x3 matrix-vector product mv has been previously allocated.
static void cs_sdm_multiply_r1c3_rowrow (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Specific version: a (1x3) and b (3x1)
void cs_sdm_multiply_rowrow (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Generic version: all compatible sizes.
void cs_sdm_multiply_rowrow_sym (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Generic version: all compatible sizes Result is known to be symmetric.
void cs_sdm_block_multiply_rowrow (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Case of a matrix defined by block.
void cs_sdm_block_multiply_rowrow_sym (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Case of matrices defined by block. Results is known to be symmetric.
void cs_sdm_square_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a small square matrix mv has been previously allocated.
void cs_sdm_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a rectangular matrix mv has been previously allocated.
void cs_sdm_update_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a rectangular matrix mv has been previously allocated and initialized Thus mv is updated inside this function.
void cs_sdm_matvec_transposed (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a rectangular matrix which is transposed. mv has been previously allocated. mv is updated inside this function. Don't forget to initialize mv if needed.
void cs_sdm_block_add (cs_sdm_t *mat, const cs_sdm_t *add)
 Add two matrices defined by block: loc += add.
void cs_sdm_block_add_mult (cs_sdm_t *mat, cs_real_t mult_coef, const cs_sdm_t *add)
 Add two matrices defined by block: loc += mult_coef * add.
void cs_sdm_block_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a rectangular matrix defined by block mv has been previously allocated.
void cs_sdm_add (cs_sdm_t *mat, const cs_sdm_t *add)
 Add two small dense matrices: loc += add.
void cs_sdm_add_mult (cs_sdm_t *mat, cs_real_t alpha, const cs_sdm_t *add)
 Add two small dense matrices: loc += alpha*add.
void cs_sdm_add_block (cs_sdm_t *mat, const short int r_id, const short int c_id, const short int nr, const short int nc, const cs_sdm_t *add)
 Add a block of a matrix into a sub-matrix starting from (r_id, c_id) with a size of nr rows and nc cols.
void cs_sdm_add_block_topleft (cs_sdm_t *mat, const short int nr, const short int nc, const cs_sdm_t *add)
 Add a block of a matrix into a sub-matrix starting from (0, 0) with a size of nr rows and nc cols.
void cs_sdm_square_add_transpose (cs_sdm_t *mat, cs_sdm_t *tr)
 Define a new matrix by adding the given matrix with its transpose. Keep the transposed matrix for a future use.
void cs_sdm_square_2symm (cs_sdm_t *mat)
 Set the given matrix to two times its symmetric part mat --> mat + mat_tr = 2*symm(mat)
void cs_sdm_square_asymm (cs_sdm_t *mat)
 Set the given matrix into its anti-symmetric part.
void cs_sdm_block_square_asymm (cs_sdm_t *mat)
 Set the given block matrix into its anti-symmetric part.
void cs_sdm_33_sym_qr_compute (const cs_real_t m[9], cs_real_t Qt[9], cs_real_t R[6])
 Decompose a matrix into the matrix product Q.R Case of a 3x3 symmetric matrix.
void cs_sdm_33_lu_compute (const cs_sdm_t *m, cs_real_t facto[9])
 LU factorization of a small dense 3x3 matrix.
void cs_sdm_lu_compute (const cs_sdm_t *m, cs_real_t facto[])
 LU factorization of a small dense matrix. Small means that the number m->n_rows is less than 100 for instance.
void cs_sdm_33_lu_solve (const cs_real_t facto[9], const cs_real_t rhs[3], cs_real_t sol[3])
 Solve a system A.sol = rhs using a LU factorization of A (a small 3x3 dense matrix).
void cs_sdm_lu_solve (cs_lnum_t n_rows, const cs_real_t facto[], const cs_real_t *rhs, cs_real_t *sol)
 Solve a system A.sol = rhs using a LU factorization of A (a small dense matrix).
void cs_sdm_33_ldlt_compute (const cs_sdm_t *m, cs_real_t facto[6])
 LDL^T: Modified Cholesky decomposition of a 3x3 SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf.
void cs_sdm_44_ldlt_compute (const cs_sdm_t *m, cs_real_t facto[10])
 LDL^T: Modified Cholesky decomposition of a 4x4 SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf.
void cs_sdm_66_ldlt_compute (const cs_sdm_t *m, cs_real_t facto[21])
 LDL^T: Modified Cholesky decomposition of a 6x6 SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf.
void cs_sdm_ldlt_compute (const cs_sdm_t *m, cs_real_t *facto, cs_real_t *dkk)
 LDL^T: Modified Cholesky decomposition of a SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf.
void cs_sdm_33_ldlt_solve (const cs_real_t facto[6], const cs_real_t rhs[3], cs_real_t sol[3])
 Solve a 3x3 matrix with a modified Cholesky decomposition (L.D.L^T) The solution should be already allocated Ref. http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf.
void cs_sdm_44_ldlt_solve (const cs_real_t facto[10], const cs_real_t rhs[4], cs_real_t x[4])
 Solve a 4x4 matrix with a modified Cholesky decomposition (L.D.L^T) The solution should be already allocated Ref. http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf.
void cs_sdm_66_ldlt_solve (const cs_real_t f[21], const cs_real_t b[6], cs_real_t x[6])
 Solve a 6x6 matrix with a modified Cholesky decomposition (L.D.L^T) The solution should be already allocated Ref. http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf.
void cs_sdm_ldlt_solve (int n_rows, const cs_real_t *facto, const cs_real_t *rhs, cs_real_t *sol)
 Solve a SPD matrix with a L.D.L^T (Modified Cholesky decomposition) The solution should be already allocated Reference: http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf.
double cs_sdm_test_symmetry (const cs_sdm_t *mat)
 Test if a matrix is symmetric. Return 0. if the extradiagonal differences are lower thann the machine precision.
void cs_sdm_simple_dump (const cs_sdm_t *mat)
 Dump a small dense matrix.
void cs_sdm_dump (cs_lnum_t parent_id, const cs_lnum_t *row_ids, const cs_lnum_t *col_ids, const cs_sdm_t *mat)
void cs_sdm_fprintf (FILE *fp, const char *fname, cs_real_t thd, const cs_sdm_t *m)
 Print a cs_sdm_t structure not defined by block Print into the file f if given otherwise open a new file named fname if given otherwise print into the standard output The usage of threshold allows one to compare more easier matrices without taking into account numerical roundoff.
void cs_sdm_block_dump (cs_lnum_t parent_id, const cs_sdm_t *mat)
 Dump a small dense matrix defined by blocks.
void cs_sdm_block_fprintf (FILE *fp, const char *fname, cs_real_t thd, const cs_sdm_t *m)
 Print a cs_sdm_t structure which is defined by block Print into the file f if given otherwise open a new file named fname if given otherwise print into the standard output The usage of threshold allows one to compare more easier matrices without taking into account numerical roundoff.
◆ CS_SDM_BY_BLOCK
◆ CS_SDM_SHARED_VAL
◆ CS_SDM_SYMMETRIC
Typedef Documentation
◆ cs_sdm_matvec_t
[in]matlocal matrix to use
[in]veclocal vector to use
[in,out]mvresult of the local matrix-vector product
◆ cs_sdm_product_t
[in]alocal dense matrix to use
[in]blocal dense matrix to use
[in,out]cresult of the local matrix-product
◆ cs_sdm_33_ldlt_compute()
void cs_sdm_33_ldlt_compute ( const cs_sdm_t * m,
cs_real_t facto[6] )
[in]mpointer to a cs_sdm_t structure
[in,out]factovector of the coefficient of the decomposition
Note
: facto is a lower triangular matrix. The first value of the j-th (zero-based) row is easily accessed: its index is j*(j+1)/2 (cf sum of the first j natural numbers). Instead of 1 on the diagonal we store the inverse of D mat in the L.D.L^T decomposition
◆ cs_sdm_33_ldlt_solve()
void cs_sdm_33_ldlt_solve ( const cs_real_t facto[6],
cs_real_t sol[3] )
[in]factovector of the coefficients of the decomposition
[in]rhsright-hand side
[in,out]solsolution
◆ cs_sdm_33_lu_compute()
void cs_sdm_33_lu_compute ( const cs_sdm_t * m,
cs_real_t facto[9] )
[in,out]factocompact storage of coefficients for the LU factorization
Note
: facto stores L the lower triangular matrix (without its diagonal entries assumed to be equal to 1) and U the upper triangular matrix.
◆ cs_sdm_33_lu_solve()
void cs_sdm_33_lu_solve ( const cs_real_t facto[9],
cs_real_t sol[3] )
[in]factocompact storage of coefficients for the LU factorization (should be allocated to the right size, i.e. n_rows*n_rows)
[in,out]solsolution
Note
◆ cs_sdm_33_matvec()
void cs_sdm_33_matvec ( const cs_sdm_t * mat,
const cs_real_t * vec,
cs_real_t * mv )
inlinestatic
◆ cs_sdm_33_sym_qr_compute()
void cs_sdm_33_sym_qr_compute ( const cs_real_t m[9],
cs_real_t Qt[9],
cs_real_t R[6] )
[in]mmatrix values
[in,out]Qttransposed of matrix Q
[in,out]Rvector of the coefficient of the decomposition
Note
: R is an upper triangular matrix. Stored in a compact way.
j= 0, 1, 2 i=0| 0| 1| 2| i=1 | 4| 5| i=2 6|
◆ cs_sdm_44_ldlt_compute()
void cs_sdm_44_ldlt_compute ( const cs_sdm_t * m,
cs_real_t facto[10] )
Note
◆ cs_sdm_44_ldlt_solve()
void cs_sdm_44_ldlt_solve ( const cs_real_t facto[10],
cs_real_t x[4] )
[in,out]xsolution
◆ cs_sdm_66_ldlt_compute()
void cs_sdm_66_ldlt_compute ( const cs_sdm_t * m,
cs_real_t facto[21] )
Note
◆ cs_sdm_66_ldlt_solve()
void cs_sdm_66_ldlt_solve ( const cs_real_t f[21],
cs_real_t x[6] )
[in]fvector of the coefficients of the decomposition
[in]bright-hand side
[in,out]xsolution
◆ cs_sdm_add()
void cs_sdm_add ( cs_sdm_t * mat,
const cs_sdm_t * add )
[in,out]matlocal matrix storing the result
[in]addvalues to add to mat
◆ cs_sdm_add_block()
void cs_sdm_add_block ( cs_sdm_t * mat,
const short int nr,
const short int nc,
[in]r_idrow index
[in]c_idcolumn index
[in]nrnumber of rows to extract
[in]ncnumber of column to extract
◆ cs_sdm_add_block_topleft()
void cs_sdm_add_block_topleft ( cs_sdm_t * mat,
const short int nr,
const short int nc,
◆ cs_sdm_add_mult()
void cs_sdm_add_mult ( cs_sdm_t * mat,
cs_real_t alpha,
[in]alphamultiplicative coefficient
◆ cs_sdm_add_scalvect()
void cs_sdm_add_scalvect ( int n,
const cs_real_t s,
cs_real_t y[] )
inlinestatic
[in]nsize of arrays x and y (small)
[in]sscalar coefficient
[in]xinput array
[in,out]youtput array
◆ cs_sdm_block33_create()
cs_sdm_t * cs_sdm_block33_create ( int n_max_blocks_by_row,
int n_max_blocks_by_col )
[in]n_max_blocks_by_rowmax number of blocks in a row
[in]n_max_blocks_by_colmax number of blocks in a column
a new allocated cs_sdm_t structure
◆ cs_sdm_block33_init()
void cs_sdm_block33_init ( cs_sdm_t * m,
int n_row_blocks,
int n_col_blocks )
[in,out]m
[in]n_row_blocksnumber of blocks in a row
[in]n_col_blocksnumber of blocks in a column
◆ cs_sdm_block_33_to_xyz()
void cs_sdm_block_33_to_xyz ( const cs_sdm_t * mb33,
cs_sdm_t * mbxyz )
[in]mb33pointer to a matrix
[in,out]mbxyzpointer to a matrix to build (but allocated)
◆ cs_sdm_block_add()
void cs_sdm_block_add ( cs_sdm_t * mat,
◆ cs_sdm_block_add_mult()
void cs_sdm_block_add_mult ( cs_sdm_t * mat,
[in]mult_coefmultiplicative coefficient
◆ cs_sdm_block_create()
cs_sdm_t * cs_sdm_block_create ( int n_max_blocks_by_row,
const int max_col_block_sizes[] )
[in]max_row_block_sizesmax number of rows by block in a column
[in]max_col_block_sizesmax number of columns by block in a row
◆ cs_sdm_block_create_copy()
cs_sdm_t * cs_sdm_block_create_copy ( const cs_sdm_t * mref)
[in]mrefpointer to a matrix to copy
a new allocated cs_sdm_t structure which is a copy of mref
◆ cs_sdm_block_dump()
void cs_sdm_block_dump ( cs_lnum_t parent_id,
const cs_sdm_t * mat )
[in]parent_idid of the related parent entity
[in]matpointer to the cs_sdm_t structure
◆ cs_sdm_block_fprintf()
void cs_sdm_block_fprintf ( FILE * fp,
const char * fname,
cs_real_t thd,
const cs_sdm_t * m )
[in]fppointer to a file structure or null
[in]fnamefilename or null
[in]thdthreshold (below this value --> set 0)
[in]mpointer to the cs_sdm_t structure
[in]fppointer to a file structure or nullptr
[in]fnamefilename or nullptr
◆ cs_sdm_block_init()
void cs_sdm_block_init ( cs_sdm_t * m,
int n_row_blocks,
int n_col_blocks,
const int col_block_sizes[] )
[in,out]m
[in]row_block_sizesnumber of rows by block in a column
[in]col_block_sizesnumber of columns by block in a row
◆ cs_sdm_block_matvec()
void cs_sdm_block_matvec ( const cs_sdm_t * mat,
cs_real_t * mv )
[in]veclocal vector to use (size = mat->n_cols)
[in,out]mvresult of the operation (size = mat->n_rows)
◆ cs_sdm_block_multiply_rowrow()
void cs_sdm_block_multiply_rowrow ( const cs_sdm_t * a,
const cs_sdm_t * b,
cs_sdm_t * c )
[in]alocal matrix to use
[in]blocal matrix to use
[in,out]cresult of the local matrix-product (already allocated) is updated
◆ cs_sdm_block_multiply_rowrow_sym()
void cs_sdm_block_multiply_rowrow_sym ( const cs_sdm_t * a,
const cs_sdm_t * b,
cs_sdm_t * c )
◆ cs_sdm_block_square_asymm()
void cs_sdm_block_square_asymm ( cs_sdm_t * mat)
[in,out]matsmall dense matrix defined by block to transform
◆ cs_sdm_copy()
void cs_sdm_copy ( cs_sdm_t * recv,
const cs_sdm_t * send )
inlinestatic
[in,out]recvpointer to a cs_sdm_t struct.
[in]sendpointer to a cs_sdm_t struct.
◆ cs_sdm_copy_block()
void cs_sdm_copy_block ( const cs_sdm_t * m,
const short int nr,
const short int nc,
cs_sdm_t * b )
inlinestatic
[in]mpointer to cs_sdm_t structure
[in]r_idrow index
[in,out]bsubmatrix
◆ cs_sdm_create()
cs_sdm_t * cs_sdm_create ( cs_flag_t flag,
int n_max_rows,
int n_max_cols )
[in]flagmetadata related to a cs_sdm_t structure
[in]n_max_rowsmax number of rows
[in]n_max_colsmax number of columns
◆ cs_sdm_create_copy()
cs_sdm_t * cs_sdm_create_copy ( const cs_sdm_t * m)
[in]mpointer to a cs_sdm_t structure to copy
a pointer to a new allocated cs_sdm_t structure
◆ cs_sdm_create_transpose()
cs_sdm_t * cs_sdm_create_transpose ( cs_sdm_t * mat)
[in]matlocal matrix to transpose
a pointer to the new allocated transposed matrix
◆ cs_sdm_dot()
cs_real_t cs_sdm_dot ( int n,
const cs_real_t y[] )
inlinestatic
[in]xfirst array
[in]ysecond array
the dot product
◆ cs_sdm_dump()
void cs_sdm_dump ( cs_lnum_t parent_id,
const cs_lnum_t * row_ids,
const cs_lnum_t * col_ids,
[in]row_idslist of ids related to associated entities (or null)
[in]col_idslist of ids related to associated entities (or null)
[in]row_idslist of ids related to associated entities (or nullptr)
[in]col_idslist of ids related to associated entities (or nullptr)
◆ cs_sdm_fprintf()
void cs_sdm_fprintf ( FILE * fp,
const char * fname,
cs_real_t thd,
◆ cs_sdm_free()
cs_sdm_t * cs_sdm_free ( cs_sdm_t * mat)
[in]matpointer to a cs_sdm_t struct. to free
a null pointer
◆ cs_sdm_get_block()
cs_sdm_t * cs_sdm_get_block ( const cs_sdm_t *const m,
int row_block_id,
int col_block_id )
inlinestatic
[in]mpointer to a cs_sdm_t struct.
[in]row_block_idid of the block row, zero-based.
[in]col_block_idid of the block column, zero-based.
a pointer to a cs_sdm_t structure corresponfing to a block
◆ cs_sdm_get_col()
void cs_sdm_get_col ( const cs_sdm_t * m,
int col_id,
cs_real_t * col_vals )
inlinestatic
[in]col_idid of the column, zero-based.
[in,out]col_valsextracted values
◆ cs_sdm_init()
void cs_sdm_init ( int n_rows,
int n_cols,
cs_sdm_t * mat )
inlinestatic
[in]n_rowscurrent number of rows
[in]n_colscurrent number of columns
[in,out]matpointer to the cs_sdm_t structure to initialize
◆ cs_sdm_ldlt_compute()
void cs_sdm_ldlt_compute ( const cs_sdm_t * m,
cs_real_t * facto,
cs_real_t * dkk )
[in,out]dkkstore temporary the diagonal (size = n_rows)
Note
◆ cs_sdm_ldlt_solve()
void cs_sdm_ldlt_solve ( int n_rows,
const cs_real_t * facto,
const cs_real_t * rhs,
cs_real_t * sol )
[in]n_rowsdimension of the system to solve
[in,out]solsolution
◆ cs_sdm_lu_compute()
void cs_sdm_lu_compute ( const cs_sdm_t * m,
cs_real_t facto[] )
[in,out]factocompact storage of coefficients for the LU factorization (should be allocated to the right size, i.e. m->n_rows*m->n_rows)
Note
◆ cs_sdm_lu_solve()
void cs_sdm_lu_solve ( cs_lnum_t n_rows,
cs_real_t * sol )
[in,out]solsolution
Note
◆ cs_sdm_map_array()
void cs_sdm_map_array ( int n_max_rows,
int n_max_cols,
cs_sdm_t * m,
cs_real_t * array )
inlinestatic
[in]n_max_rowsmax. number of rows
[in]n_max_colsmax. number of columns
[in,out]mpointer to a cs_sdm_t structure to set
[in,out]arraypointer to an array of values of size equal to n_max_rows x n_max_cols
◆ cs_sdm_matvec()
void cs_sdm_matvec ( const cs_sdm_t * mat,
cs_real_t * mv )
◆ cs_sdm_matvec_transposed()
void cs_sdm_matvec_transposed ( const cs_sdm_t * mat,
cs_real_t * mv )
◆ cs_sdm_multiply()
void cs_sdm_multiply ( const cs_sdm_t * a,
const cs_sdm_t * b,
cs_sdm_t * c )
[in,out]cresult of the local matrix-product is updated
◆ cs_sdm_multiply_r1c3_rowrow()
void cs_sdm_multiply_r1c3_rowrow ( const cs_sdm_t * a,
const cs_sdm_t * b,
cs_sdm_t * c )
inlinestatic
◆ cs_sdm_multiply_rowrow()
void cs_sdm_multiply_rowrow ( const cs_sdm_t * a,
const cs_sdm_t * b,
cs_sdm_t * c )
[in,out]cresult of the local matrix-product (already allocated) is updated.
◆ cs_sdm_multiply_rowrow_sym()
void cs_sdm_multiply_rowrow_sym ( const cs_sdm_t * a,
const cs_sdm_t * b,
cs_sdm_t * c )
◆ cs_sdm_scale()
void cs_sdm_scale ( cs_real_t scaling,
cs_sdm_t * m )
inlinestatic
[in]scaling
[in,out]mpointer to cs_sdm_t structure
◆ cs_sdm_scalvect()
void cs_sdm_scalvect ( int n,
const cs_real_t s,
cs_real_t y[] )
inlinestatic
[in]xinput array
◆ cs_sdm_simple_dump()
void cs_sdm_simple_dump ( const cs_sdm_t * mat)
◆ cs_sdm_square_2symm()
void cs_sdm_square_2symm ( cs_sdm_t * mat)
[in,out]matsmall dense matrix to transform
◆ cs_sdm_square_add_transpose()
void cs_sdm_square_add_transpose ( cs_sdm_t * mat,
cs_sdm_t * tr )
[in,out]matlocal matrix to transpose and add
[in,out]trtransposed of the local matrix
◆ cs_sdm_square_asymm()
void cs_sdm_square_asymm ( cs_sdm_t * mat)
◆ cs_sdm_square_create()
cs_sdm_t * cs_sdm_square_create ( int n_max_rows)
◆ cs_sdm_square_init()
void cs_sdm_square_init ( int n_rows,
cs_sdm_t * mat )
inlinestatic
◆ cs_sdm_square_matvec()
void cs_sdm_square_matvec ( const cs_sdm_t * mat,
cs_real_t * mv )
◆ cs_sdm_symm_ur()
void cs_sdm_symm_ur ( cs_sdm_t * mat)
inlinestatic
[in,out]matpointer to a cs_sdm_t structure
◆ cs_sdm_test_symmetry()
double cs_sdm_test_symmetry ( const cs_sdm_t * mat)
[in]matpointer to the cs_sdm_t structure to test
0 if the matrix is symmetric at the machine tolerance otherwise the absolute max. value between two transposed terms
◆ cs_sdm_transpose_and_update()
void cs_sdm_transpose_and_update ( const cs_sdm_t * m,
cs_sdm_t * mt )
inlinestatic
[in,out]mtmatrix to update with the transposed of m
◆ cs_sdm_update_matvec()
void cs_sdm_update_matvec ( const cs_sdm_t * mat,
cs_real_t * mv )
