Face viscosity. More...
#include "base/cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdarg.h>#include <string.h>#include <math.h>#include <float.h>#include "bft/bft_error.h"#include "bft/bft_mem.h"#include "bft/bft_printf.h"#include "alge/cs_blas.h"#include "base/cs_dispatch.h"#include "base/cs_ext_neighborhood.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "alge/cs_gradient.h"#include "base/cs_halo.h"#include "base/cs_halo_perio.h"#include "base/cs_internal_coupling.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parall.h"#include "base/cs_parameters.h"#include "base/cs_physical_constants.h"#include "pprt/cs_physical_model.h"#include "base/cs_porous_model.h"#include "base/cs_prototypes.h"#include "base/cs_timer.h"#include "turb/cs_turbulence_model.h"#include "alge/cs_face_viscosity.h"Functions | |
| void | cs_face_viscosity_secondary (cs_real_t secvif[], cs_real_t secvib[]) |
| Computes the secondary viscosity contribution | |
| void | cs_face_viscosity (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, const int visc_mean_type, cs_real_t *restrict c_visc, cs_real_t *restrict i_visc, cs_real_t *restrict b_visc) |
| Compute the diffusion velocity at faces. | |
| void | cs_face_anisotropic_viscosity_vector (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, const int visc_mean_type, cs_real_6_t *restrict c_visc, cs_real_33_t *restrict i_visc, cs_real_t *restrict b_visc) |
| Compute the equivalent tensor viscosity at faces for a 3x3 symetric tensor. | |
| void | cs_face_anisotropic_viscosity_scalar (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_real_6_t *restrict c_visc, const int iwarnp, cs_real_2_t *restrict weighf, cs_real_t *restrict weighb, cs_real_t *restrict i_visc, cs_real_t *restrict b_visc) |
| Compute the equivalent viscosity at faces for a 3x3 symetric tensor, always using a harmonic mean. | |
Face viscosity.
| void cs_face_anisotropic_viscosity_scalar | ( | const cs_mesh_t * | m, |
| cs_real_6_t *restrict | c_visc, | ||
| const int | iwarnp, | ||
| cs_real_2_t *restrict | weighf, | ||
| cs_real_t *restrict | weighb, | ||
| cs_real_t *restrict | i_visc, | ||
| cs_real_t *restrict | b_visc ) |
| [in] | m | pointer to mesh |
| [in] | fvq | pointer to finite volume quantities |
| [in] | c_visc | cell viscosity symmetric tensor |
| [in] | iwarnp | verbosity |
| [out] | weighf | inner face weight between cells i and j |
| [out] | weighb | boundary face weight |
| [out] | i_visc | inner face viscosity (times surface divided by distance) |
| [out] | b_visc | boundary face viscosity (surface, must be consistent with flux BCs) |
| void cs_face_anisotropic_viscosity_vector | ( | const cs_mesh_t * | m, |
| const int | visc_mean_type, | ||
| cs_real_33_t *restrict | i_visc, | ||
| [in] | visc_mean_type | method to compute the viscosity at faces:
| [out] | i_visc | inner face tensor viscosity (times surface divided by distance) |
| void cs_face_viscosity | ( | const cs_mesh_t * | m, |
| cs_real_t *restrict | c_visc, | ||
i_visc,b_visc = viscosity*surface/distance, homogeneous to a rate of flow in kg/s.
Please refer to the viscfa section of the theory guide for more informations.
| [in] | c_visc | cell viscosity (scalar) |
![\[ \grad\left( (\kappa -\dfrac{2}{3} \mu) \trace( \gradt(\vect{u})) \right)
\]](form_44.png)
with:
Please refer to the visecv section of the theory guide for more informations.
| [in,out] | secvif | lambda*surface at interior faces |
| [in,out] | secvib | lambda*surface at boundary faces |
