#include "cdo/cs_cdo_bc.h"#include "cdo/cs_cdo_connect.h"#include "cdo/cs_cdo_local.h"#include "cdo/cs_cdo_quantities.h"#include "cdo/cs_equation_param.h"#include "cdo/cs_macfb_builder.h"#include "base/cs_time_step.h"#include "cdo/cs_xdef_eval.h"Go to the source code of this file.
| typedef void | cs_cdo_apply_boundary_t(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Apply a boundary condition for a given face (inlet, outlet, wall, sliding wall, symmetry...) | |
| typedef void | cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Enforcement of a boundary condition (Dirichlet, Robin, sliding...) | |
| void | cs_equation_bc_init_boundary_flux (cs_real_t t_eval, const cs_cdo_quantities_t *cdoq, const cs_equation_param_t *eqp, cs_real_t *values) |
| Set the values for the normal boundary flux stemming from the Neumann boundary conditions (zero is left where a Dirichlet is set. This can be updated later on) | |
| void | cs_equation_bc_set_cw_vb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_flag_t vtx_bc_flag[], const cs_real_t dir_values[], cs_real_t t_eval, cs_cell_sys_t *csys, cs_cell_builder_t *cb) |
| Set the BC into a cellwise view of the current system. Case of vertex-based schemes. | |
| void | cs_equation_bc_set_cw_eb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb) |
| Set the BC into a cellwise view of the current system. Case of edge-based schemes. | |
| void | cs_equation_bc_set_cw_fb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb) |
| Set the BC into a cellwise view of the current system. Case of CDO Face-based schemes. | |
| void | cs_equation_bc_set_cw_macfb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_macfb_builder_t *macb, cs_cell_sys_t *csys) |
| Set the BC into a cellwise view of the current system. Case of MAC Face-based schemes. | |
| void | cs_equation_bc_set_cw_cb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb) |
| Set the BC into a cellwise view of the current system. Case of Face-based schemes. | |
| void | cs_equation_bc_set_vertex_flag (const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *vflag) |
| Define an array of flags for each vertex collecting the flags of associated boundary faces. | |
| void | cs_equation_bc_set_edge_flag (const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *edge_flag) |
| Define an array of flags for each edge collecting the flags of associated boundary faces. | |
| void | cs_equation_bc_dirichlet_at_vertices (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_flag_t *bcflag, cs_real_t *values) |
| Compute the values of the Dirichlet BCs when DoFs are attached to vertices. | |
| void | cs_equation_bc_dirichlet_at_faces (const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_real_t t_eval, cs_real_t *values) |
| Compute the values of the Dirichlet BCs at boundary faces. This can be applied to CDO face-based schemes (DoFs are attached to primal faces), to CDO cell-based schemes or even to FV schemes. | |
| void | cs_equation_compute_neumann_svb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values) |
| Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to a vertex-based schemes (Vb or VCb) Case of the Neumann BCs i.e. Neumann is defined by a scalar. | |
| void | cs_equation_compute_full_neumann_svb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values) |
| Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to a vertex-based schemes (Vb or VCb) Case of the full Neumann BCs i.e. Neumann is defined by a vector. | |
| void | cs_equation_compute_neumann_sfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values) |
| Compute the values of the Neumann BCs when DoFs are attached to the face f. Case of scalar-valued equation (not full Neumann BCs) | |
| void | cs_equation_compute_full_neumann_sfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values) |
| Compute the values of the Neumann BCs when DoFs are attached to the face f. Case of scalar-valued equation with a full Neumann BC definition. | |
| void | cs_equation_compute_neumann_vfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values) |
| Compute the values of the Neumann BCs at the face f when DoFs are attached to faces. Case of vector-valued equation (not the full Neumann) | |
| void | cs_equation_bc_cw_robin (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *rob_values) |
| Compute the values of the Robin BCs for a face (cell-wise compute relying on the cs_cell_mesh_t structure) | |
| void | cs_equation_bc_circulation_at_edges (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, cs_real_t *values) |
| Compute the values of the circulation along primal edges lying on the domain boundary (the integral of the tangential component of vector-valued field). This is used for CDO edge-based schemes where DoFs are attached to (primal) edge-based schemes. | |
| void | cs_equation_bc_update_for_increment (cs_cell_sys_t *csys) |
| Update the boundary conditions to fullfill the constraint when an incremental solve is set. | |
| typedef void cs_cdo_apply_boundary_t(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| [in] | f | face id in the cell mesh numbering |
| [in] | pty | pointer to a cs_property_data_t structure |
| [in,out] | csys | structure storing the cell-wise system |
| typedef void cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| [in,out] | fm | pointer to a cs_face_mesh_t structure |
| [in,out] | hodge | pointer to a cs_hodge_t structure |
| void cs_equation_bc_circulation_at_edges | ( | cs_real_t | t_eval, |
| cs_real_t * | values ) |
| [in] | t_eval | time at which one evaluates the boundary cond. |
| [in] | eqp | pointer to a cs_equation_param_t |
| [in,out] | values | pointer to the array of values to set |
| void cs_equation_bc_cw_robin | ( | cs_real_t | t_eval, |
| short int | def_id, | ||
| short int | f, | ||
| double * | rob_values ) |
| [in] | def_id | id of the definition for setting the Neumann BC |
| [in] | f | local face number in the cs_cell_mesh_t |
| [in,out] | rob_values | array storing Robin values to use |
| void cs_equation_bc_dirichlet_at_faces | ( | const cs_mesh_t * | mesh, |
| const cs_cdo_bc_face_t * | face_bc, | ||
| cs_real_t | t_eval, | ||
| [in] | face_bc | pointer to a cs_cdo_bc_face_t structure |
| void cs_equation_bc_dirichlet_at_vertices | ( | cs_real_t | t_eval, |
| cs_flag_t * | bcflag, | ||
| [in,out] | bcflag | pointer to an array storing type of BC |
| void cs_equation_bc_init_boundary_flux | ( | cs_real_t | t_eval, |
| void cs_equation_bc_set_cw_cb | ( | const cs_cell_mesh_t * | cm, |
| const cs_real_t | dir_values[], | ||
| cs_cell_builder_t * | cb ) |
| [in] | dir_values | Dirichlet values associated to each face |
| [in] | dir_values | Dirichlet values associated to each vertex |
| void cs_equation_bc_set_cw_eb | ( | const cs_cell_mesh_t * | cm, |
| void cs_equation_bc_set_cw_fb | ( | const cs_cell_mesh_t * | cm, |
| void cs_equation_bc_set_cw_macfb | ( | const cs_cell_mesh_t * | cm, |
| cs_macfb_builder_t * | macb, | ||
| cs_cell_sys_t * | csys ) |
| [in,out] | macb | pointer to a cs_macfb_builder_t strucuture |
| [in] | dir_values | Dirichlet values associated to each faces |
| void cs_equation_bc_set_cw_vb | ( | const cs_cell_mesh_t * | cm, |
| const cs_flag_t | vtx_bc_flag[], | ||
| [in] | vtx_bc_flag | BC flags associated to vertices |
| void cs_equation_bc_set_edge_flag | ( | const cs_cdo_connect_t * | connect, |
| cs_flag_t * | edge_flag ) |
| [in] | face_bc | pointer to a structure collecting boundary conditions applied to faces |
| [in,out] | edge_flag | BC flag on edges to define |
| void cs_equation_bc_set_vertex_flag | ( | const cs_cdo_connect_t * | connect, |
| cs_flag_t * | vflag ) |
| [in,out] | vflag | BC flag on vertices to define |
| void cs_equation_bc_update_for_increment | ( | cs_cell_sys_t * | csys | ) |
| [in,out] | csys | pointer to the cell system structure |
| void cs_equation_compute_full_neumann_sfb | ( | cs_real_t | t_eval, |
| short int | f, | ||
| double * | neu_values ) |
| [in,out] | neu_values | array storing Neumann values for all DoFs |
| void cs_equation_compute_full_neumann_svb | ( | cs_real_t | t_eval, |
| short int | f, | ||
| [in,out] | neu_values | array storing the Neumann values for all DoFs |
| void cs_equation_compute_neumann_sfb | ( | cs_real_t | t_eval, |
| short int | f, | ||
| void cs_equation_compute_neumann_svb | ( | cs_real_t | t_eval, |
| short int | f, | ||
| void cs_equation_compute_neumann_vfb | ( | cs_real_t | t_eval, |
| short int | f, | ||
| [in,out] | neu_values | array storing Neumann values at DoFs |
