1#ifndef __CS_XDEF_EVAL_H__
2#define __CS_XDEF_EVAL_H__
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_quadrature_type_t
Type of quadrature to use when computing an integral quantity. This rationale is used for integrals a...
Definition cs_quadrature.h:84
void cs_xdef_eval_symtens_by_val(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a tensor-valued quantity for a list of elements with symmetric storage. This function compli...
Definition cs_xdef_eval.cpp:190
void cs_xdef_eval_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure)
Definition cs_xdef_eval.h:66
void cs_xdef_eval_at_vertices_by_dof_func(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at vertices using a function associated to dof (dof = degrees of freedom)...
Definition cs_xdef_eval.cpp:718
void cs_xdef_eval_at_b_faces_by_array(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at boundary faces using an array This function complies with the generic ...
Definition cs_xdef_eval.cpp:1077
void cs_xdef_eval_at_b_faces_by_dof_func(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at boundary faces using a function associated to dof (dof = degrees of fr...
Definition cs_xdef_eval.cpp:764
void cs_xdef_eval_at_cells_by_dof_func(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at primal cells using a function associated to dof (dof = degrees of free...
Definition cs_xdef_eval.cpp:672
void cs_xdef_eval_at_cells_by_analytic(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at cells using an analytic function This function complies with the gener...
Definition cs_xdef_eval.cpp:477
void cs_xdef_eval_nd_at_cells_by_array(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a nd-valued quantity at cells defined by an array. Array is assumed to be interlaced....
Definition cs_xdef_eval.cpp:896
void cs_xdef_eval_at_b_faces_by_analytic(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at border faces using an analytic function This function complies with th...
Definition cs_xdef_eval.cpp:570
void cs_xdef_eval_avg_at_b_faces_by_analytic(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, int dim, cs_real_t *eval)
Evaluate a quantity defined at border faces using an analytic function.
Definition cs_xdef_eval.cpp:1237
void cs_xdef_eval_vector_by_val(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a vector-valued quantity for a list of elements This function complies with the generic func...
Definition cs_xdef_eval.cpp:143
void cs_xdef_eval_tensor_by_time_func(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a tensor-valued quantity with only a time-dependent variation for a list of elements This fu...
Definition cs_xdef_eval.cpp:427
void cs_xdef_eval_scalar_at_cells_by_array(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a scalar-valued quantity at cells defined by an array. Array is assumed to be interlaced....
Definition cs_xdef_eval.cpp:810
void cs_xdef_eval_at_vertices_by_array(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at vertices using an array This function complies with the generic functi...
Definition cs_xdef_eval.cpp:1004
void cs_xdef_eval_scalar_by_val(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a scalar-valued quantity for a list of elements This function complies with the generic func...
Definition cs_xdef_eval.cpp:97
void cs_xdef_eval_symtens_by_time_func(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a tensor-valued quantity with a symmetric storage and with only a time-dependent variation f...
Definition cs_xdef_eval.cpp:379
void cs_xdef_eval_scalar_by_time_func(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a scalar-valued quantity with only a time-dependent variation for a list of elements This fu...
Definition cs_xdef_eval.cpp:283
void cs_xdef_eval_at_i_faces_by_analytic(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at interior faces using an analytic function. This function complies with...
Definition cs_xdef_eval.cpp:522
void cs_xdef_eval_tensor_by_val(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a tensor-valued quantity for a list of elements This function complies with the generic func...
Definition cs_xdef_eval.cpp:236
void cs_xdef_eval_cell_by_field(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity inside a cell defined using a field This function complies with the generic funct...
Definition cs_xdef_eval.cpp:1159
void cs_xdef_eval_at_vertices_by_analytic(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity defined at vertices using an analytic function This function complies with the ge...
Definition cs_xdef_eval.cpp:617
void cs_xdef_eval_vector_by_time_func(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a vector-valued quantity with only a time-dependent variation for a list of elements....
Definition cs_xdef_eval.cpp:331
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
