#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdarg.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem.h"#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_assert.h"#include "base/cs_base.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "base/cs_parameters_check.h"#include "base/cs_physical_constants.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "base/cs_physical_properties.h"#include "base/cs_prototypes.h"#include "base/cs_restart_default.h"#include "base/cs_thermal_model.h"#include "mesh/cs_mesh_location.h"#include "turb/cs_turbulence_model.h"#include "pprt/cs_combustion_model.h"#include "pprt/cs_physical_model.h"#include "rayt/cs_rad_transfer.h"#include "cogz/cs_combustion_gas.h"Functions | |
| void | cs_f_combustion_map_variables (void) |
| void | cs_f_combustion_map_properties (int iym_c[]) |
| cs_combustion_gas_model_t * | cs_combustion_gas_set_model (cs_combustion_gas_model_type_t type) |
| Activate gas combustion model. | |
| void | cs_combustion_gas_set_thermochemical_data_file (const char *file_name) |
| Set the thermochemical data file name. | |
| void | cs_combustion_gas_setup (void) |
| Specific setup operations for gas combustion models. | |
| void | cs_combustion_gas_log_setup (void) |
| Print the gas combustion module options to setup.log. | |
| void | cs_combustion_gas_add_variable_fields (void) |
| Add variable fields for gas combustion models. | |
| void | cs_combustion_gas_add_property_fields (void) |
| Add property fields for gas combustion models. | |
| void | cs_combustion_gas_yg2xye (const cs_real_t yg[], cs_real_t ye[], cs_real_t xe[]) |
| Compute molar and mass fractions of elementary species Ye, Xe (fuel, O2, CO2, H2O, N2) from global species Yg (fuel, oxidant, products) | |
| cs_combustion_gas_model_t * | cs_glob_combustion_gas_model = NULL |
Gas combustion model.
| void cs_combustion_gas_add_property_fields | ( | void | ) |
| void cs_combustion_gas_add_variable_fields | ( | void | ) |
| void cs_combustion_gas_log_setup | ( | void | ) |
| cs_combustion_gas_model_t * cs_combustion_gas_set_model | ( | cs_combustion_gas_model_type_t | type | ) |
| [in] | type | gas combustion model type |
Steady flamelet model
| void cs_combustion_gas_set_thermochemical_data_file | ( | const char * | file_name | ) |
| [in] | file_name | name of the file. |
| void cs_combustion_gas_setup | ( | void | ) |
| [in] | yg | global mass fraction |
| [out] | ye | elementary mass fraction |
| [out] | xe | elementary molar fraction |
| void cs_f_combustion_map_properties | ( | int | iym_c[] | ) |
| void cs_f_combustion_map_variables | ( | void | ) |
| cs_combustion_gas_model_t* cs_glob_combustion_gas_model = NULL |
Combustion model parameters structure
